I have a ton of custom presets that I've developed over several years. I tried importing them into CS6 by copying the custom presets from here:
\Users\<user_name>\AppData\Roaming\Adobe\Common\AME\5.0
to here:
\Users\<user_name>\AppData\Roaming\Adobe\Common\AME\6.0
I can see the custom presets in AME but only SOME of the presets in the export settings format/preset boxes from Premiere Pro CS6. e.g. AVI show up but not the presets for H264 or Windows Media formats etc (they don't appear).
Are the presets incompatible between CS5.5 and CS6 for some formats (maybe there are new settings that weren't in the old version)?
Paul.
Hi Paul,
Some of your CS5 presets are compatible, some aren't. There were some pretty significant changes to several of the encoders in CS6, so the data in the old presets won't map correctly anymore. I can't remember the full list off the top of my head, but Windows Media definitely changed. You'll need to rebuild those presets from scratch.
One confusing area is that in AME CS6 we have both a new H.264 and H.264 Blu-ray encoder, as well as the older encoders which are now marked H.264 (Legacy) and H.264 Blu-ray (Legacy). (For the record, MPEG4 also falls into this category.) If you import older presets for these formats, they should be added to the Legacy encoders, but not the new encoders.
Rather than copy/pasting the preset files into the folder, I suggest you use the Import function (under the new Preset menu or the button in the new Preset Browser) to add the files to AME CS6. You should get an appropriate warning via this method if the preset isn't compatible with any of the encoders, rather than the silent failure that occurs when you place them in the folder.
-=TimK
Tim or Paul:
when in CS 6.0 and right click presets or in the panel to import presets...where is Adobe storing our presets? I realize we can likley change this, but i can't seem to find them....i also have a full set in 5.5 that i would like to transfer over to CS 6.
Thanks,....
MAC OS by the way...
EDIT: long night-- i actually meant, presets for my EFFECT settings...that's what i'd like to import from 5.5....Sorry fot wrong reply/question in wrong thread.
Exporter Presets for AME are stored here:
Win: \Users\<user_name>\AppData\Roaming\Adobe\Common\AME\6.0\Presets
Mac: /Users/<user_name>/Library/Preferences/Adobe/Common/AME/6.0/Presets
NOTE: On Mac OS 10.7, the user Library folder is hidden by default.
Best to start a new thread about that on the Premiere Pro forum.
Inquiring minds want to know. What's new about them? Is Adobe now using the superior x264 encoder perhaps?
Still the MainConcept encoder. The upgrades that make it "new" are mostly under-the-hood changes which make a bigger difference to those of us developing the software; the old (Legacy) encoders rely on some rather crusty, old code. As previously mentioned, the reason we included the Legacy encoders is because we weren't able to wire up some of the old functionality like Surcode.
From the user-facing perspective all you'll see in the new encoders is a cleaned up UI in the Export Settings dialog. There were bug fixes and performance improvements, too, but nothing worth shouting about.
Jim, you know the drill.
I don't have that folder in my MAC and it's driving me crazy. I go to: /users/<user name>/ AND NOTHING no folder called library. Im on a Mac Pro MAC OSX 10.7.4
I have run a search for AME for Presets and nothing turns up. When I run my Media Encoder App. the custom presets are all there but I can't seem to find where they live on my computer. Any help would be greatly appreciated. Thank you in advance.
See my post above and follow the link:
Alternately, you can get to that folder using AME's assistance. Right-click on a custom preset in the Preset Browser panel and choose "Reveal Preset File".
x264 the software is free (in the GPL form) but still doesn't license you for the H.264 it creates. For that you need additional patent permission.
But..... x264pro just got launched. It is an AME / x264 integration and it does do all the patent royalties, thus making it possible, and easy, to use x264 with Adobe Creative Suite.
Tim,
I utilize the full version of the Surcode 5.1 Dolby Digital add-in which is still included on a trial basis in CS6 and I am just in the process of upgrading to CS6. Your quote above seems to imply the ability to use the Surcode 5.1 audio encoder with the legacy video encoders. As far as I have been able to tell (and a large frustration too), you have had to encode your DD 5.1 audio separately from your video in order to maintain 5.1 audio and had to import into Encore separately. So you could not use dynamic link with Pr Pro and you also had to encode the streams separately.
So are you saying that the Surcode plugin only works with the legacy encoders not the new ones? I guess if we still have to encode separately it does not really matter.
What Surcode functionality is in the old encoders that is not in the new?
With CS6, since the video encoders have been re-written, can we finally encode 5.1 Blu-Ray discs and DVD's all at once and pull them into encore that way? Or perhaps use dynamic link from Pre Pro to Encore? Or must you still encode them separately even with the new encoders.
When I heard about the CS6 programming and a few days where long-lasting annyoyances were fixed, I was hoping this item was on the list! ![]()
BJBBJB1
