Applescript: delete object from page
May 15, 2012 12:16 PM
I'm trying to remove an objects from a page with a known name.
I've name the object theLine.  It's a drawn line.  Under certain conditions, I want to delete it.
Other object is a placed graphic name theImage.  Under certain conditions, I want to delete it as well.
Keep trying various iterations, but not even coming close.
    May 15, 2012 6:55 PM   in reply to ax1e2l_b3r4a5s6s
    Hi
    does this work?
    tell application "Adobe InDesign CS5.5"
        delete (every graphic line of document 1 whose label is "SolidSigLineTop")
    end tell
    May 16, 2012 1:36 PM   in reply to ax1e2l_b3r4a5s6s
    try this
        set myDoc to active document
        tell myDoc
            try
                set AllGraphicLines to {"SolidSigLineTop", "SolidSigLineBottom"} as string
                set myGraphicline to (every graphic line whose label is in AllGraphicLines)
                delete myGraphicline
            on error
                display dialog "no graphic line/s with this name exists"
            end try
        end tell
    end tell
    May 16, 2012 4:28 PM   in reply to ax1e2l_b3r4a5s6s
    the script assumes that you have a line/stroke on your page and that the stroke is labled in "Script Label", (window/utilities/Script Label), as we
    are looking for it's label   "every graphic line whose label is"  .
    you say you've named the layer, very differnt.
    to label your stroke, select it, open "window/utilities/Script Label"  enter your strokes name, deslect the stroke, run the script, works fine here
    if you need to delete layers, let me no and ill alter the code for you.
    kp
    May 16, 2012 4:56 PM   in reply to Kevin Parrott
    heres some code to delete specific layers
        activate
        tell myDoc
            try
                set AllLayers to {"SolidSigLineTop", "SolidSigLineBottom"} as string
                set myLayer to every layer whose name is in AllLayers
                delete myLayer
            on error
                display dialog "no layer/s with this name exists"
            end try
        end tell
    end tell
    May 16, 2012 5:36 PM   in reply to ax1e2l_b3r4a5s6s
    ahh, i see, sorry, try this,  you need ot tell your doc to do what you need it ot do
        activate
        tell myDoc
            set theTopRule to the graphic line "SolidSigLineTop"
            set theBottomRule to the graphic line "SolidSigLineBottom"
            delete theTopRule
            delete theBottomRule
        end tell
    end tell
    May 16, 2012 6:34 PM   in reply to ax1e2l_b3r4a5s6s
    give this a spin
        activate
        tell myDoc
            delete theTopRule
            --delete graphic
            set PlacedImage to rectangle "TEST" -- the image is automatically place in a rectangle
            delete PlacedImage
        end tell
    end tell
