BUG: Unable to Import MP3 Files in Flash CS6
May 16, 2012 3:03 PM
Tags: #flash #bug #import #mp3 #cs6
I am unable to import mp3 files of any kind in Flash CS6. Tried import to stage, import to library, Drag and Drop... no dice. Receiving a generic error message. Tried closing out and restarting,etc. - still not working.
Anyone else having this issue?
    May 16, 2012 8:29 PM   in reply to DigitalKicker
    Please follow this process before importing the MP3 files.
    Launch the app, Press "CTRL +SHIFT+ALT" immediately
    Menu will popup  "Delete Adobe profressional settings? "
    Select Yes.
    Then try to import the MP3 files.
    Please let me know if its works.
    May 17, 2012 10:50 PM   in reply to DigitalKicker
    Did you able to  play the same mp3 in windows media player ?. Check another mp3 can import in Flash. Please share the file if you are not able to solve this issue.
    May 20, 2012 9:12 PM   in reply to DigitalKicker
    I am not sure its an issue of  the codec used in MP3. Could you please share the MP3. I will try and reply back to you.
    Jun 4, 2012 10:37 PM   in reply to DigitalKicker
    I can't import them to the stage, nor drag and drop, anymore.  But they will import to library.  But I can't get them to preview.  Sound only when I publish.
    Jun 4, 2012 11:29 PM   in reply to johnaoneal
    Please share the file, I will find out a work around for the issue.
    Jun 12, 2012 11:17 AM   in reply to Jose_Flash_ookken
    I'm in the same boat. I cannot import mp3's. I did as mentioned above and still no luck.
    This is true for ALL my files. The mp3's were also created with Soundbooth so there isn't any weird codecs either.
    Windows 7 64 bit
    Jun 13, 2012 9:29 PM   in reply to DigitalKicker
    For Flash CS6 on Win7, you need to update to QuickTime(7.7.1) and iTune(10.5.3.3) to import .mp3 files of which bitrate is larger than 192kbps..
    Jun 14, 2012 7:34 AM   in reply to Jose_Flash_ookken
    Yep that worked!
    The "update" in the library would not update the content but the drag and drop worked fine.
    Note: The path in the update dialog shows a relative path and after the drag and drop it shows an absolute path to the file
    I also had an issue with the audio being changed from stream to event.
    Oct 10, 2012 9:16 AM   in reply to Jose_Flash_ookken
    Do you need both QuickTime and iTune in order to import .mp3 files, or will the updated version of QuickTime be sufficient?
    Mar 17, 2013 12:55 AM   in reply to AM Russell
    even im not able to import the music files to timeline and library.
    when i try to import .MP3 file, its displaying an error "couldn't import the specified file.mp3"
    when i try to add .wma files, its showing an error "one or more files were not imported because there is a problem while reading them".
    any one can fix this issue?
    Mar 20, 2013 12:26 PM   in reply to DigitalKicker
    Hi my friend...
    1. Import the sound to library
    2. Select the layer you want to import
    3. Open properties dialog (ctrl + f3 or windows -> properties)
    4. with a frame selected in layer - see the sound dialog box showing in properties
    5. click the drag down and select the sound you have imported
    it's ok now
    6. you must select the sync as 'stream' for the sound to stop at the end of movie
    thanks
    Mahesh
    Apr 9, 2013 10:18 PM   in reply to DigitalKicker
    I somehow managed to import my file, but still, did not work by Draging it in. Only after update of Quicktime and iTunes, I imported my 30mb file after comverting from .mp3 -> to .wav and it worked. Thanks.
    Apr 10, 2013 9:53 AM   in reply to DigitalKicker
    I couldn't import any WAV or MP3 files into Flash Professional CS6.
    I had this issue when saving out of SoundBooth CS4.  There was a box in the Preferences>MetaData> "Include source XMP on save as"  this prevented Flash from opening the file... When I turned off the check box, MP3 and WAV files suddely worked.
    Hope this helps someone else.
    Jul 15, 2013 1:42 AM   in reply to jkell33
    I have the same Problem on my Mac OSX 10.7.5. I have the latest Quicktime Version and iTunes is also the newest Version. What do I have to do in order to import or even update mp3 files to my Flash CC project??
    Jan 6, 2014 11:12 PM   in reply to DigitalKicker
    I had the same problem. But, i used adobe media encoder and reconvert it to mp3 then import it to library and every thing became fine
    Apr 8, 2014 10:45 PM   in reply to DigitalKicker
    The only way I could get my music to import was to import it into Flash CC. For some reason it wouldn't import into Flash Cs6 though and my whole project is in Flash CS6. Is there any way to fix this or is there a specific reason why it will only import in Flash CC?
    Apr 8, 2014 10:54 PM   in reply to Ahmedy95
    I just tried the encoder and it worked! I'm so happy!!!
