This discussion is locked
Photoshop CS6 Unbelieveable bug!
May 11, 2012 8:50 AM
Hello all,
Please tell me someone is having this issue.  When I open an image in PS CS6 all is well.  Once I move the document, it snaps itself to the top left.  If I move it and try to place it somewhere else, it moves itself a little higher to the top left.  The more I move it the more it snaps higher.  If I move it over 5 times it covers the main menu bar (File   Edit   Layer   View   Filter) and so on.  This renders the app useless as you can no no longer access the native menu to do anything to the image.
I am on Windows 7x64 (SP1)  with a Wacom Tablet.  Within PS I've disabled, Tabs for windows (Both check marks) as well as Flick Panning, and animated zoom.
Any help would be appreciated.
-Patrick
Replies 1 2 Previous Next
    May 11, 2012 8:53 AM   in reply to psurace99
    Moving your query to the Photoshop forum. The experts here are better placed to help you.
  • Noel Carboni
    Dec 23, 2006
    May 11, 2012 9:09 AM   in reply to psurace99
    It's a pretty blatant bug, but some workarounds have been discovered.
    It has to do with having your Windows Taskbar up at the top of the display.
    You can work around the bug by setting your Taskbar to Auto-Hide itself.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    psurace99 wrote:
    Thank you, how can I find it there?
    http://forums.adobe.com/thread/1002791?tstart=0
    -Noel
    May 11, 2012 9:11 AM   in reply to psurace99
    Hi Patrick,
    I'm not seeing this behavior.
    Does this happen only when your images are floating in windows?
    Did it ever work correctly in Photoshop CS6?
    Have you tried resetting your preferences? (restart Photoshop and immediately press & hold Shift+Opt+Ctrl.)
    If you choose to Tile or Cascade your images, does that move the images into a normal position?
    Do you have any third party plug-ins?
    Did you move any plug-ins from a previous version of Photoshop in to CS6?
    Please restart Photoshop and press Shift immediately after, and say Yes that you want to not load your plug-ins and see if that helps.
    thanks!
    tina
    May 11, 2012 9:13 AM   in reply to tinaTS
    You guys are too fast for me!
  • Noel Carboni
    Dec 23, 2006
    May 11, 2012 9:22 AM   in reply to tinaTS
    But we can't fix the root cause of the problem, though I'll be more than happy to discuss contract work.
    -Noel
    May 11, 2012 9:24 AM   in reply to Noel Carboni
    HA, I wish.
    I'm documenting this in the knowledgebase, so this will probably help other customers, too. :-)
    May 11, 2012 10:24 AM   in reply to psurace99
    We have a bug report logged in our system and it's under investigation.
    regards,
    steve
    May 16, 2012 9:15 PM   in reply to Noel Carboni
    wow big thanks for Noel, I'm having this same issue since I'm using window with top taskbar at my office,and mac at home. hopefully Adobe can fix this soon
    May 27, 2012 7:54 PM   in reply to psurace99
    I have that bug, too.
    Photoshop CS6 in Windows 7 64bit, I also use Wacom Tablet. I can't move window correctly, I hate the bug,
    Jun 16, 2012 10:14 PM   in reply to Ellive Faninx
    I'm having the same issue, and I have my Windows taskbar at the top of the screen too.
    Someone at the top of this thread said that "some workarounds" have been discovered; is there another besides auto-hiding the taskbar? I'd really rather not do that, it messes up my workflow. I think I might just keep using CS5 until Adobe gets this bug fixed.
    Jun 17, 2012 9:12 AM   in reply to ratbagandmooch
    This bug is very annoying. The worst part is this bug was announced WELL before the final release and Adobe released the software knowing the bug existed. That's pretty unexcusable in my opinion. I can't even use CS6 with this problem, hiding the main taskbar is NOT an option for me, are they kidding?
  • Noel Carboni
    Dec 23, 2006
    Jun 17, 2012 9:20 AM   in reply to Eric Stoffers
    Another workaround is to use Tabbed view.
    Regarding the software being released after the bug having been reported during beta, that's a particular beef of mine as well about Adobe's processes...  Consider the fact that the released software has a build date of several days BEFORE the start of the public beta.
    Thing is, it's probably unreasonable to hold release until every known bug is eradicated, but this is kind of an obvious one, and it was (potential) customer-reported.
    I'm not sure what kind of meetings were held to discuss going forward with the release, but this problem and the one also found during beta where text gets corrupted and the corruption is saved in the PSD file make me wonder what would be considered a "show stopper" bug.  Add to this the fact that the help documentation really still is not done and it sure seems like the pressure to release must be unreasonable.
    Looking forward to the 13.0.1 update...
    -Noel
    Jun 17, 2012 6:25 PM   in reply to Noel Carboni
    Ugh, I hate the tabs view more than than the snap glitch. I'm not sure if any designers actually work that way, I can't imagine having multiple documents open and using tabs on a 30" monitor, not for me, defeats the purpose of it all.
    Anyhow, all these bugs are pretty bad. I had the text corruption bug as well but just assumed they fixed it before the final release. If they didn't then I'm definitely downgrading the CS5. That was a show stopper bug and a half to put it lightly.
    Exactly how can ANY bugs be allowed to go into a final release? That is insanity. Not happy.
    Jun 17, 2012 6:43 PM   in reply to Noel Carboni
    The release build came a few weeks AFTER the start of the public beta.
  • Noel Carboni
    Dec 23, 2006
    Jun 17, 2012 7:28 PM   in reply to Chris Cox
    I don't know what software you have, Chris, but the released Photoshop.exe on my system is dated 3/15/2012.
    The public beta started on what, 3/21/2012?
    -Noel
    Jul 6, 2012 3:18 AM   in reply to psurace99
    Another work around is to use Photoshop cs6 on a duel monitor, I have my desktop on one and photshop on the other, problem solved and yes my taskbar is on the top.   Really if your a graphic designer you should have more then one monitor right?  I'm not trying to be snarky here but.....  8)
    Jul 6, 2012 2:49 PM   in reply to iCjay
    HA, I say two monitors is a poor mans setup. One 28+ monitor is FAAAAR better. Who wants some black bar down the center? Not me. Get a big monitor, they are cheap these days for a nice IPS, not much more than a grand for a decent one.
    Jul 6, 2012 6:03 PM   in reply to Eric Stoffers
    There are several reasons why multiple monitors are far superior to a super-wide one.  Chief among those reasons is the ability to set them at an angle to each other so as to minimize head turning and viewing angle distortion.  The tone of your post makes it unnecessary to address other reasons in detail.  You're just trolling.
    Jul 6, 2012 6:01 PM   in reply to iCjay
    iCjay wrote:
    Another work around is to use Photoshop cs6 on a duel monitor…
    You mean dual.  Duels are against the law in civilized countries.
    Jul 6, 2012 6:08 PM   in reply to station_two
    Personally, I prefer dual large monitors, and also an NTSC calibrated monitor, to grade my video.
    Whether in PS, or PrPro, there is no substitute for monitor real estate.
    Hunt
    Jul 6, 2012 6:09 PM   in reply to station_two
    Now, when we lived in New Orleans, we often had picnics among the "Dueling Oaks."
    Hunt
    Jul 6, 2012 6:13 PM   in reply to Bill Hunt
    Dueling banjos come to mind too…
    Jul 6, 2012 6:43 PM   in reply to station_two
    Hey, being a "Son of the Deep South," I can relate there too...
    Hunt
    Jul 6, 2012 8:14 PM   in reply to station_two
    Oh thank you so much Bill and station_two for correcting me on my use of these two english words, Yes Duel, and  Dual.... God now I just can't live with myself anymore, and I now must put a gun to my head and pull the trigger.
      Thank you so much god rest my soul.
    Jul 6, 2012 8:30 PM   in reply to Eric Stoffers
    Well actually I have 3- 28inch monitors, two side by side and one in portrait mode. So I wouldn't say my setup is personally a poor mans party. If you only have one monitor when working in a professional environment then I would say your boss is either cheap or your not a professional.   Like I said I can only offer what works for me, when it comes to this crappy bug in Photoshop cs6 that's been around since FREAKING MAY, ADOBE< HOW EMBARRASSING IT MUST BE>>>>>ADOBE FAIL!!!   8(
    Not that I'm trying to beat a dead horse to death or anything.. 8)
  • Noel Carboni
    Dec 23, 2006
    Jul 7, 2012 6:34 AM   in reply to iCjay
    The world is so full of empty promises.
    -Noel
    Jul 7, 2012 7:31 AM   in reply to station_two
    If you guys are quite done bragging about the size of your equipment, I'd like to pursue the dual monitor issue. Opening Photoshop CS6 on my second monitor had occurred to me as a possible solution, and it was one of the first things I tried. But when I open files they snap to the top left corner of my primary monitor, so it's still impossible to have two images open at once. iCjay - when you did this, were you able to move images around on your desktop?
    - Julie
    Jul 7, 2012 7:41 AM   in reply to iCjay
    There is nothing to worry about. I thought that the juxtaposition of those two words was rather humorous, as you WERE "dueling" with a problem.
    I got nailed just the other day, but using "loose," where I meant "lose." A week before, I could have blamed that on a sticking O Key on my laptop, but I had just replaced the keyboard, so my excuse went out the window. Also, with that sort of thing, SpellCheck will not flag it. Guess that you could safely say that I got *loose* with "lose."
    Stuff happens... now put that gun down!
    Happy editing,
    Hunt
    Jul 7, 2012 7:47 AM   in reply to ratbagandmooch
    Julie,
    You can change the display of Images from Tabbed View, and should then be able to have multiple Images Open and, depending on their Magnification, and your monitor real estate, drag them side-by-side. That Tabbed View is not something that I use, being the "old-timer," that I am. I like to be able to see all, or at least a big part, of what I am working on, when I need multiple Images Open.
    If I am just Opening multiple Images, but working on them one at a time, I let them Tile, and do not need to see any, but the one that is being edited.
    If you have Tabbed View (the new default), try Tiling the Images. Unless I am missing something important, a click+drag should get you what you want.
    Good luck, and if I AM missing an important element, then just ignore my suggestion.
    Hunt
    Jul 7, 2012 10:32 AM   in reply to Noel Carboni
    Love u 2
    Jul 7, 2012 1:56 PM   in reply to iCjay
    "Well actually I have 3- 28inch monitors, two side by side and one in portrait mode"
    Finally I find another person who likes a portrait setup....I only have dual monitors but one is landscape (primary) and the other portrait...works for me; especially when viewing portrait docs/images....and I keep all my panels there.
    Jul 7, 2012 2:31 PM   in reply to Doug.S
    Yea well, I work in an IMAX dome and have a 360 degree view of my photoshop documents. Anything less is for newbs. Get with the times people.
    Jul 11, 2012 1:30 PM   in reply to Bill Hunt
    Thanks for the response,Hunt, but nothing seems to help. I don't like working in Tabbed View - quite often I'm moving layers between images so I like to have both/all open at the same time. However, I tried opening two images and tiling them as you suggested; the only result of that is that now, instead of snapping to the top left of my primary monitor, as they were doing, they snap to the top left of the secondary monitor. I still can't move them anywhere, on either monitor. I think I'm just going to have to stick with CS5 until they get this fixed (they WILL get it fixed, won't they?)
    Julie
    Jul 28, 2012 4:35 PM   in reply to psurace99
    This is pretty much unacceptable to me. I blame Microsoft more than Adobe; I've been using the taskbar on top for years (it actually makes much more sense, I think) and I have had issues with programs opening underneath it or not working properly since WINDOWS XP.
    Adobe needs to fix this ASAP because it's pretty sad that this new program has such a blatant and intrusive bug but the greater point here is that part of Windows needs to be re-written because it's not something software developers should be having to worry about.
    Jul 28, 2012 7:41 PM   in reply to sixthcrusifix
    I blame Adobe, Sixthcrusifix. Adobe needs to get it's head outa it's A$$.
    WINDOWS JUST WORKS NOW!!!!  What's Microsoft, is that some company or
    something?
    Jul 28, 2012 9:01 PM   in reply to sixthcrusifix
    The taskbar at the top makes TONS more sense. That's where all the other menus and app controls are, why move your mouse all the way down to the bottom, that makes NO sense. I don't understand how any serious computer user can put the taskbar at the bottom, that's just foolishness to me. It certainly makes you a little slower as you have to move your eyes and mouse further.
    I'm not bothering with CS6 until this bug is fixed, it's a total deal killer for me.
1 2 Previous Next
