Is the Premeire cs5 "Bloating" Problem back in cs6?
May 18, 2012 7:35 AM
Hey,
I have project I'm working on, its around a 4:30 music video.  The file size has went from around  50mb to now its about 500mb.
Also it is taking forever to save the video around 2-3 minutes.  Is anybody else experiencing this?  Thanks
    May 17, 2012 10:28 AM   in reply to SpaceCherryFilms
    Not yet.
    May 17, 2012 10:40 AM   in reply to SpaceCherryFilms
    Are you using Warp Stabilizer by any chance?  I've read it can cause this same issue.
    May 17, 2012 11:25 AM   in reply to SpaceCherryFilms
    There are a few threads related to Warp Stabilizer causing giant file sizes.  One good workaround is to render out an intermediary file of your Warp Stabilized clip from your sequence, and then bring it back in and replace the WS clip on the timeline.
    May 17, 2012 4:14 PM   in reply to SpaceCherryFilms
    Try clearing all your rendered files and if that doesn't work try importing that project into a new one.
    May 17, 2012 4:31 PM   in reply to SpaceCherryFilms
    There's a known bug having to do with preview files & using Save As frequently - it'll double the number of preview file references incorrectly on each iteration.  This will be fixed in the next update.  Considering the amount of cuts with software effects, I'm betting that this is what you're hitting.
    Importing your project into a new one is a good suggestion, it's likely to leave behind any preview file references.
    Cheers
    May 17, 2012 8:55 PM   in reply to Wil Renczes
    @ Will
    Is there any knowledge of any Conforming "issues" such as repeated conforming of the same files?
    ie the conforming recycles thru the media files.
    I have noticed this occuring on one of my projects.
    Maybe it it is connected to the  bloat issue.
    CS6 - Win7
    May 17, 2012 9:42 PM   in reply to shooternz
    I'm only aware of one regenerating file issue, but it's not CFA files, it's the PEK file (ie what's used for displaying waveforms) for XDCAM HD MXF files, and I believe it requires that the media is in some kind of read-only state.  That's also fixed for the upcoming dot.
    What kind of media file is constantly reconforming for you?  And is it CFA, PEK, or both?
    May 17, 2012 10:00 PM   in reply to Wil Renczes
    Hi Wil
    The files were AVCHD  (.mts files)
    Sorry I am not sure what was actually conforming.
    I cant get back onto that particular project meantime to replicate and identify anything for you.
    I have dived back into CS5.5 to do that  project based on bloating /save as issue you gave above.
    Got a film to make and finish in 48 hours...starting in 2 hours time from now. (Competition)
    I couldnt risk any issues biting me.
    May 18, 2012 5:31 AM   in reply to shooternz
    Best of luck, Shooternz! Will we get to see your 48-hour results?
    May 22, 2012 8:53 PM   in reply to Jay Gladwell
    I'm having same issue. Project has gone from about 75MB to over 3GB in the past couple of hours, with very minor changes in the actual project (I don't think i imported any new media or made new sequences - did add effects and rendered). Very frustrating.
    -sam
    May 22, 2012 9:02 PM   in reply to Wil Renczes
    How come no one's answered Wil's last question?
    May 23, 2012 9:11 PM   in reply to Wil Renczes
    Wil,
    When is the update coming?  We have a major commercial that is at a standstill because our project file size is nearly 6GB in size and we can't even open the project.  I'm sorry this is not your fault but this is very bad on Adobe's part.  This sort of elementary bug should have been discovered way, way before shipping.
    May 23, 2012 9:26 PM   in reply to PeterCorbett
    Wil, couldnt SpaceCherryFilms just delete all the preview files?
    I gues if there are a lot of renders thats impractical since they would need to be rerendered, huh.
    May 29, 2012 8:13 AM   in reply to lasvideo
    Hi Wil,
    Now that 6.01 has just rolled out, is there a timeframe for fixing the project bloat bug? Seems significant enough to throw your swat team at it and roll out and emergency patch.
    Please keep us posted.
    Ray
    May 29, 2012 9:34 AM   in reply to Ray Tragesser
    6.0.1 already contains the fix for the duplicate preview entries.  If you open & resave your project, it should shrink back down.
    Cheers
    May 29, 2012 9:38 AM   in reply to Wil Renczes
    3 cheers for Adobes timely fix!
    Jun 1, 2012 2:41 PM   in reply to SpaceCherryFilms
    The bloating you are experienceing with Warp, has nothing to do with the bloating that Wil is referring to, Im pretty sure. I think he is referring to the "Save as" bloat that created duplicate preview files when saving in that manner. Right Wil?
    Jun 1, 2012 3:12 PM   in reply to SpaceCherryFilms
    I could tell. Believe me, Adobe folks bust their butts to make sure things work.
    Jun 1, 2012 4:39 PM   in reply to lasvideo
    Yep, correct. The fix has nothing to do with the Warp Stabilizer, which generates a lot of ancillary data, and the longer the clip it's applied to, the more data gets embedded in the project.
    Aug 15, 2012 11:28 PM   in reply to Wil Renczes
    Hey Will I am having this problem with file size as well. I am cutting a feature length film and the fiile size is about 1.8gb. I am NOT using any warp stabalizers. And when I tried saving it as a new project it took just as long, if not longer to save. This project was initially started on FCP 7, but I wanted to change over to CS6 for a few reasons so I exported an xml. I don't know if there are any known issues with that that could be causing it either. In desperate need of help on this one as due dates are looming and its tough to get anything done when saving takes about 30 minutes.
    Aug 27, 2012 11:09 AM   in reply to anthony_bernard
    I was having the same issue (not using Warp Stabilizer either).  My prproj file ballooned from 100MB to 1GB in a matter of days, making it almost impossible to open.  I got my file down to a workable 200MB by doing the following: [Warning: be careful, this could be destructive if you don't work from a duplicate.  Never do this to your original project file]
    1. Duplicate your project file.
    2. Open it with a text editor (right click "open with", choose "other", then choose TextEdit on a MAC. I think on windows it is ctrl+shift right click, then choose notepad or wordpad.)
    3. Look for 2 pieces of code that look like these:
    <PreviewItem Index="7363" ObjectRef="344492"/>
         and...
    <PreviewMediaSerializer ObjectID="345345" ClassID="a3cdecce-0e72-4ad3-8b59-aa53b1b54070" Version="1">
                        <Media ObjectURef="b3a4e115-add5-4cfb-9164-dcfec34cf94e"/>
                        <ID>7c708748-9a78-1855-cc1d-d88f00000053</ID>
                        <End>23587781817600</End>
                        <Start>23172474124800</Start>
              </PreviewMediaSerializer>
    There will be many, many instances of these.  (Mine had literally Millions of entries of each snippet.)  With every iteration, the entries double in size.  My first pieces of each of these referenced roughly 50,000 pieces of media.  The next 100K, then 200K, etc.
    4. Starting at the last instance of each of these massive chunks of code; highlight them and delete. Work your way backwards (or up, as it were) and delete each progressive chunk of entries.  Being careful to not remove ALL of the entries, just the later duplicates.
    I suspect there are other areas that can be removed safely, but this is all I did.  It made the project much smaller and I was able to successfully open it.  I've been working out of it for the last 5 days and everything is still fine.  The filesize has actually gone down subsequently.
    Hopefully this is helpful.  It might be good to save a version after every time you delete a chunk, that way if you get to a point where the project won't open, you can just try the previous saved version and so forth.  I'm not saying this is the best way, just what I did to get my project back.
    Sep 8, 2012 6:56 AM   in reply to SpaceCherryFilms
    Just wanted to report my findings:
    A five camera multicam project of one hour with about 500 cuts.
    I had to stabilise most of the clips from one camera that was mast-mounted on a  breezy day. The total length of 49 stabilised clips was 7:20 (seven minutes twenty seconds). The project size grew to 184MB. When I rendered and replaced the clips (a tedious process but only took about 30 minutes to do) the project size shrank to 39MB, which is about right comparing it with similar projects.
    Possibly worth doing! Certainly it's faster to save, and since I save to Dropbox, it's faster to upload too.
    The Warp Stabiliser did a fantastic job of stabilising the clips, almost certainly saving my viewers from seasickness.
    Hope this helps someone!
    Mark
