GregB54321
Trouble connecting to Subversion
May 15, 2012 7:57 AM
Tags: #subversion #connection_problems #ubersvn
I have the latest Subversion server setup on a dedicated Mac (OS 10.7.3) acting as a server. The Subversion server was installed and configured via UberSVN management interface from WANDisco. I am using the Subversion 1.6.18 binaries. According to Adobe, any sub version of the binaries (1.6.x) should work with Dreamweaver (Subversion 1.6.8 binaries) but mentions nothing about Adobe Drive.
I setup a test repositry and successfully connected to it via Dreamweaver CS 5.5 and even checked in and checked out files with no problems. When I try to connect Drive to the repository, I get an error message saying that it cannot connect to the repository. The SVN logs show the following error:
"[error] [client 192.168.***.***] Directory index forbidden by Options directive: /opt/ubersvn/htdocs/content/dam/"
Anyone have any idea?
Has anyone successfully connected to a Subversion server via Adobe Drive 3?
    May 17, 2012 12:22 AM   in reply to GregB54321
    Hi
    Currently, Adobe Drive ships with only two out-of-box connectors, one is Adobe CQ DAM connector and another is CMIS 1.0 connector.  Meanwhile, Dreamweaver cannot work with Adobe Drive
    I don't know which connector you are using to connect to Subversion server.
    May 17, 2012 6:44 PM   in reply to GregB54321
    Please find CQ DAM info @ http://www.adobe.com/products/cq.html.
    May 17, 2012 11:40 PM   in reply to GregB54321
    I didn't hear anything about Subversion supporting the CMIS 1.0 standard, could you show a real instance? our CMIS connector allows you to connect to any server that supports the OASIS CMIS 1.0 Spec, and it was fully tested against Alfresco 3.4b community edition and Alfresco Enterprise 3.3.
    thanks
