Hi!
I am a graphic designer I like to work hand and not numbers. The new version of Ai CS6 gradients can be given for strokes. Great!
Please help me how exactly I can do it with a convenient tool 'Gradient Tool'?
Does not respond to changes in drag when I try to use the mouse to outline?
In advertising and instructions CS6 somehow strange is described ... I do not understand.
http://helpx.adobe.com/illustrator/using/gradient-panel-gradient-tool- overview.html
Regards!
HI,
In Illustrator CS6, you can definitely add a gradient to a stroke. Here's a very simple video tutorial: http://tv.adobe.com/watch/learn-illustrator-cs6/gradients-on-strokes/? go=13268.
In fact, to see the an amazing piece of artwork created using this new feature, see this short video (by Brenda Sutherland, Illustrator CS6 Product Manager) right up to the very end: http://tv.adobe.com/watch/adobe-design-center/adobe-illustrator-cs6-sn eak-peek-gradients-on-strokes/.
Go on, check it out!
Cheers,
David
@Ivan David: Thank you for your response. I asked for something else. How to use the "Gradient Tool" no gradient palete. Why are chceck "ON" you own answer as helpful?
As I explained I am a graphic designer will create a hands than numbers. I do not understand why no tool "gradient tool" works to fill but it does not work on outline.
If I get a chance to show off with a representative of Adobe's a bit like crying...
We need fair and real changes. According to me the most to do is to think about using Illustrator for themselves of their creators Illustrator.
* For example in work with new gradient tool.
- Why when you edit the gradient for the outline of the object is displayed slider gradient fill???. It's confusing and totally unnecessary.
- Why is the Gradient Tool Outline tool does not work???
- Why Control bar does not drop the Gradient icon??? What is the control bar when no controls? Control Bar cool idea but how would the developers were thinking of him as a stranger?
- Why still the option of working with the gradient tool to fill, when you edit a color marker, I can not turn on the Eyedropper tool to select a color from another object???
- Why does the apperance in the attributes panel stoke attribute does not appear easy gradient of a potential of gradient palette???
- Why can not I fast copy between objects only attribute gradient???
After all, it's easy and does not require a great job developers reach a solution to the function. I know that my naive questions now, and nobody I will not answer to them but sorrow grows. Sometimes I feel like a fly in pitch.
This is not normal.
So many years have passed, there was a lot of new tools but Adobe wants to use the same techniques as in his first product. Refresh in the new 64 bit version is also not so different to that in compared to regular equipment and are currently using... ![]()
http://www.youtube.com/watch?v=N3TDmvZma84
Sorry for the harsh words of criticism, But your answer is a perfect example that Adobe does not know what's going to people who work with Illustrator on a daily basis and as can be seen starting to irritate me tight.
Perhaps I have exaggerated expectations about the tools Adobe. I understand that there is so much work and needs, but I lack only a change of thinking about working with tools in Illustartor and reducing unnecessary clicks. Now, instead of tools to work with each other often exclusive and force running around.
Regards!
