loading charaters, swatches etc
May 16, 2012 3:50 AM
I have indesign CS5.5 and I am having trouble loading characters, styles and swatches (all pantone).  I work on a network plc and I don't know if the plug ins are installed.
    May 16, 2012 6:57 AM   in reply to Lisadjb
    Ask specific questions in the ID forum.
    Mylenium
    May 16, 2012 2:25 PM   in reply to Mylenium
    Moving this discussion to the InDesign forum.
    May 16, 2012 4:24 PM   in reply to Lisadjb
    To load character styles, open the Character Style panel, then from the panel flyout menu choose Load Character styles... and in the dialog that opens choose the .indd file that you want to take the styles from.
    To load a Pantone Swatch, open the Swatches panel and from the flyout menu choose New Color Swatch... In the Color Type dropdown choose Process or Spot, and in the Color Mode dropdown choose your pantone library of choice. You can also Load Swatches from that menu in a similar fashion to loading styles, either from another ID file, or froma a saved .ase file.
    May 17, 2012 2:22 AM   in reply to Lisadjb
    No.  Do you understand the concepts behind paragraph and character styles? These are things you define yourself for each project, or load from another document to be consistent. The only pre-loaded style is [Basic Paragraph] (which I highly recommend you don't use for anything, and never use as the basis for other styles, if you need to collaborate with other users) which contains the default font information. The problem with using [Basic Paragraph] is that it can be redefined and be different for every document, and when moving text between documents you get surprises when the receiving file has styles with the same name, but different definitions.
    May 17, 2012 2:33 AM   in reply to Lisadjb
    For corporate work you more than likely need templates, which will define the corporate styles and color swatches, that will be used as the basis for other documents.
    May 17, 2012 2:37 AM   in reply to Peter Spier
    It sounds like your company is just switching over to ID, is that correct? If so, it may well be that the task of defining these styles and saving them in templates is going to fall on your shoulders.
    Did your course cover styles? It sounds like it didn't, and that's a crime. You might want to get a copy of Sandee Cohen's Visual QuickStart Guide to InDesign, or if you feel you need something more advanced try Real World Indesign, or if you prefer video training, Lynda.com.
