I have a Windows Vista 32-bits system.
I have created 2 admin and 2 standard users.
Internet Explorer 9 (IE9) 32 bit is installed but also Chrome and Firfox are used.
For 1 admin user Flash works fine when accessing a site in IE9 that requires Flash.
For the other users, including the admin user, IE9 must be run "as adminstrator" by specifically choosing that option.
If not run "as administrator" IE9 states that Flash needs to be installed. That either leeds to Flash player not being installed (error is that it is already installed) or that after a succesful installation the problem simply occurs again (and again and again ...)
I want the standard users on the pc to be able to navigate to trusted sites without running IE9 in "as adminstrator" mode.
What do I need to do?
Can I set Adobe Flash player to be available for all the users for Vista and IE9?
Do I need to alter registry settings manually?
If yes - how and which?
Thanks in advance.
Chris,
Thanks for the reply but unfortunately it does not resolve the problem.
Other users (including the other system administrator) still need to run IE as administrator.
When in my sysadmin account the shortcuts for other users to a URL requiring Flash and using IE9 execute fine GRRRRRRR.
This is very frustrating.
On my pc Chrome aand Modzilla have no problems.
The childrens protective software I have however is based on IE.
Do you have any more suggestions?
My alternative is to downgrade IE9 to IE8 or 7 but that is also not an easy exercise ...
Thanks in advance for any input.
When running IE9 under a non-admin account
