Mikheil Abesadze
AS3 Color Tweening
May 16, 2012 12:56 AM
Have Adobe simple Color Tweening code, like this caurina code : Tweener.addTween(myClip, {_color: 0x000000, time:1, transition:"easeOut"}); ?
    May 16, 2012 1:38 AM   in reply to Mikheil Abesadze
    As per my knowledge using colorTransform is the way to color tweening in as3.
    May 16, 2012 11:51 PM   in reply to Mikheil Abesadze
    var myColor:ColorTransform = new ColorTransform();
    myColor.color = 0x000000;        //Here you can give the color whatever you want...
    myClip.transform.colorTransform = myColor;         //Here myClip is your object...
    May 17, 2012 3:52 AM   in reply to Mikheil Abesadze
    Hi ,
    U can use Tween Class To Ease,
      please use this one
    import fl.transitions.Tween;
    import fl.transitions.easing.*;
    var myTween = new Tween(myClip,'alpha',Strong.EaseIn,0,1,5,true);
    May 20, 2012 9:24 PM   in reply to Mikheil Abesadze
    import flash.utils.Timer;
    import flash.events.TimerEvent;
    import flash.geom.ColorTransform;
    var timer:Timer = new Timer(1000,0);
    var arr:Array = [0x000000,0xff0000,0x00ff00,0x0000ff,0xffff00,0xff00ff,0x00ffff];
    var carr:Array = [];
    timer.addEventListener(TimerEvent.TIMER,changeColor);
    timer.start();
    function changeColor(e:TimerEvent):void
    trace("timer");
    var color:ColorTransform = new ColorTransform();
    var num:Number = Math.floor(Math.random() * arr.length);
    color.color = arr[num];
    arr.splice(num,1);
    mc.transform.colorTransform = color;
    Try this code....
