Locked
DisplacementMapFilter problem
Guest
May 10, 2011 May 10, 2011
Did somebody's worked by DisplacementMapFilter? It don't work fine on iPhone, while on flashplayer is correct. In particular, on iPhone, the filter create a image with pseudo-random pixel, without apparent logic, why?
Maybe that filter isn't implemented?
I would create an app that deforms an image through finger got from a picture done by camera, do exist an alternative method without DisplacementMapFilter?
thanks
Development
2.8K
Adobe Employee , Aug 31, 2011 Aug 31, 2011
Looks like perhaps an authoring error?  Its not the filter that's the problem, its the inputs to the filter.   the code is using stage.mouseX / stage.mouseY to see where to apply the filter; and also previous.x/y - current.x/y to see how much to apply.
On desktop, stage.mouseX/Y are updated per pixcel changes while mouse is moving. But on mobile, with touch input, they don't. So what happens on mobile is that previous.xy - current.xy could be a large value if the two touches are far way on screen
May 12, 2011 May 12, 2011
Do you use CPU or GPU render mode ? You should use CPU to apply filter.
Here a small exemple to deforme a picture when you touch screen. (I test it on my Samsung Galaxy S)
*Sorry for french comment...
The "Img" class is a Bitmap (your picture)
The "Vague" class is a MovieClip Animation of wave (black and white).
Main Class:
package
    import flash.display.Bitmap;
    import flash.display.Sprite;
    import flash.display.StageAlign;
    import flash.display.StageScaleMode;
    import flash.events.AccelerometerEvent;
    import flash.events.Event;
    import flash.events.MouseEvent;
    import flash.events.TouchEvent;
    import flash.geom.Matrix;
    import flash.sensors.Accelerometer;
    import flash.text.TextField;
    import modules.fx.Deformation;
    import modules.utils.FPSCounter;
     * @author Michaël Chartrand
    public class Main extends Sprite {
        private var _img:Bitmap;
        private var deformation:Deformation;
        public function Main():void {
            //setup stage
            stage.scaleMode = StageScaleMode.NO_SCALE;
            stage.align = StageAlign.TOP_LEFT;
            //add handlers
            addEventListener(Event.ADDED_TO_STAGE, init);
        private function init(event:Event):void{
                //removes listener
                removeEventListener(Event.ADDED_TO_STAGE, init);
                _img = new Bitmap(new Img);
                addChild(_img);
                setupTransformBitmap();
        private function setupTransformBitmap():void{
            deformation = new Deformation(_img);
            this.addEventListener(Event.ENTER_FRAME, rappel);
            this.stage.addEventListener(MouseEvent.CLICK, ajoute);
            var fps:FPSCounter = new FPSCounter(0, 0);
            addChild(fps);
        //FONCTION rappel
        private function rappel(event:Event):void{
            deformation.appliqueEffet();
        //FONCTION ajoute
        private function ajoute(event:MouseEvent):void {
            deformation.ajouteEffet(Vague, mouseX, mouseY);
Deformation Class:
package modules.fx{
     * @author Michaël Chartrand.
    //IMPORTATIONS
    import flash.display.MovieClip;
    import flash.display.DisplayObject;
    import flash.display.BitmapData;
    import flash.filters.DisplacementMapFilter;
    import flash.filters.DisplacementMapFilterMode;
    import flash.geom.Point;
    import modules.forme.Rectangle;
    //CLASS Deformation
    public class Deformation extends MovieClip {
        //PROPRIÉTÉS
        private var _imageBitmap:BitmapData;
        private var _displacementMap:DisplacementMapFilter;
        private var _contenant:MovieClip;
        private var _rectangle:Rectangle;
        private var _objet:DisplayObject;
        //FONCTION Deformation
        public function Deformation(objet:DisplayObject) {
            //Affectation
            _objet = objet;
            //Création d'un bitmap d'après les proportion d'une image.
            _imageBitmap = new BitmapData(_objet.width, _objet.height, false, 0x000000);
            //Contenant de l'effets et du rectangle
            _contenant = new MovieClip();
            _contenant.x = _objet.x;
            _contenant.y = _objet.y;
            _contenant.visible = false;
            addChild(_contenant);
            //Forme un Rectangle
            //Arguments    :: couleurFond, transparenceFond, couleurContour, pixelContour, transparenceContour, largeur, hauteur, coinLargeur, coinHauteur
            _rectangle = new Rectangle(0x000000, 1, 0x000000, 0, 1, _objet.width, _objet.height, 0, 0);
            _rectangle.x = _objet.x;
            _rectangle.y = _objet.y;
            _contenant.addChild(_rectangle);
        //FONCTION ajouteEffet
        public function ajouteEffet(classe:Class, posX:int, posY:int):void{
            var effet:MovieClip = new classe;
            effet.x = posX;
            effet.y = posY;
            _contenant.addChild(effet);
        //FONCTION appliqueEffet
        public function appliqueEffet():void{
            //Reproduit l'image sur le bitmap
            _imageBitmap.draw(_contenant);
            //Crée le filtre de déformatiom
            _displacementMap = new DisplacementMapFilter(_imageBitmap, new Point(0, 0), 1, 1, 10, 10, DisplacementMapFilterMode.CLAMP);
            //Applique le filtre de déformation
            _objet.filters = [_displacementMap];
Guest
May 13, 2011 May 13, 2011
I will try on iPhone, for now thanks a lot
dès
Guest
May 23, 2011 May 23, 2011
I tried on iPhone setted "CPU" in tag xml, but nothing, the filter don't work fine.
When I run app in Flash CS5 publish, it work fine, but when I put ipa file into iPhone the filter don't work, in fact it draw the circle concentric that don't reflect my setting on the map.
although the source is very simple (the ImgCls() is a BitmapData that represents the image from to deform😞
package{
import flash.display.BitmapDataChannel;
import flash.display.BlendMode;
import flash.display.GradientType;
import flash.display.InterpolationMethod;
import flash.display.SpreadMethod;
import flash.text.TextFormat;
import flash.desktop.NativeApplication;
import flash.desktop.SystemIdleMode;
/* import flash.display.StageAlign;
    import flash.desktop.SystemIdleMode;  */
public class Main extends MovieClip {
private var previous:Point;
private var sprite:Sprite;
private var mouseDown:Boolean;
private var map:BitmapData;
private var softness:Array = [0,255];
private var size:uint = 60;
private var sizeMezzi:int = 30
private var hardness:uint = 2;
private var txtField:TextField;
private var imgBitmap:Bitmap;
private var ui:Sprite;
private var zero:Point = new Point();
public function Main(){
super();
addEventListener(Event.ADDED, init);
private function init(e:Event):void{
var tf:TextFormat = new TextFormat();
removeEventListener(Event.ADDED, init);
NativeApplication.nativeApplication.systemIdleMode = SystemIdleMode.KEEP_AWAKE;
sprite = new Sprite();
ui = new Sprite();
txtField = new TextField();
txtField.width = 320;
txtField.height = 480;
tf.color = 0xffffff;
tf.font = "arial";
txtField.defaultTextFormat = tf;
txtField.wordWrap = true;
ui.graphics.beginFill(0x00ff00,0);
ui.graphics.drawRect(0,0,320,480);
imgBitmap = new Bitmap(new ImgCls());
addChild(imgBitmap);
addChild(txtField);
addChild(ui);
drawSprite();
sprite.blendMode = BlendMode.INVERT;
this.addEventListener( Event.ENTER_FRAME, onEnterFrame );
ui.addEventListener( MouseEvent.MOUSE_DOWN, handleMouseDown );
ui.addEventListener( MouseEvent.MOUSE_UP, handleMouseUp );
private function drawSprite( ):void {
var matrix:Matrix = new Matrix( );
matrix.createGradientBox( size, size, 0 );
sprite.graphics.clear();
sprite.graphics.beginGradientFill( GradientType.RADIAL, [0xFF0000, 0x000000], [1, 0], softness, matrix, SpreadMethod.PAD, InterpolationMethod.LINEAR_RGB);
sprite.graphics.drawCircle( size/2, size/2, size/2 );
sprite.graphics.endFill();
createMap();
private function createMap( ):void{
map = new BitmapData( size, size, false, 128 << 16 || 128 << 8 || 128);
map.draw( sprite, new Matrix(1, 0, 0, 1, 0, 0), null, BlendMode.HARDLIGHT );
private function drawDisplacement( bmp:BitmapData, current:Point ):void {
var displFilter:DisplacementMapFilter = new DisplacementMapFilter(
bmp,
current,
BitmapDataChannel.RED,
( previous.x - current.x )*hardness,
( previous.y - current.y )*hardness,
DisplacementMapFilterMode.WRAP
imgBitmap.bitmapData.applyFilter( imgBitmap.bitmapData, imgBitmap.bitmapData.rect, zero, displFilter );
//txtField.appendText("ok ");
private function onEnterFrame( event:Event ):void{
var current:Point = new Point( stage.mouseX - sprite.width/2, stage.mouseY - sprite.height/2 );
sprite.x = current.x;
sprite.y = current.y;
if( mouseDown && (current.x != previous.x || current.y != previous.y))
drawDisplacement( map, current );
previous = current.clone();
private function handleMouseDown( event:MouseEvent ):void{
mouseDown = true;
private function handleMouseUp( event:MouseEvent ):void {
mouseDown = false;
p.s. I would to try your example but you would have to give me the "modules.forme.Rectangle" class, thanks
Jun 07, 2011 Jun 07, 2011
I have the same problem, I tried also Pixel Bender on CPU and GPU but the image isn't filtered.
Does anybody know if filtering will be possible with AIR 2.7 for iOS ?
Guest
Aug 09, 2011 Aug 09, 2011
After 3 months no reply ... why?
Adobe Employee ,
Aug 10, 2011 Aug 10, 2011
@myoscaroxy I tried your code and I am not able to see any difference in output on desktop and iOS. Could you please attach a screenshot, or file a bug at http://bugbase.adobe.com with an example?
Sanika
Guest
Aug 22, 2011 Aug 22, 2011
Adobe Employee ,
Aug 23, 2011 Aug 23, 2011
Thanks for the screenshot. I am able to reproduce the bug. It is currently under investigation.
Sanika
Guest
if you give me your email I sent you my complete project (it's easy app) so you can to accelerate the work.
thanks
Adobe Employee ,
You could report the bug yourself at http://bugbase.adobe.com along with the app sources. The bug will be visible publicly, so you will come of any updates on the bug.
Thanks.
Sanika
Guest
Adobe Employee ,
On desktop, stage.mouseX/Y are updated per pixcel changes while mouse is moving. But on mobile, with touch input, they don't. So what happens on mobile is that previous.xy - current.xy could be a large value if the two touches are far way on screen. So that leads to a large filter to apply.
So I think this is a UserError one.
On mobile:
mouseDown----------------------------------------------
previous=221,186 & current=149,311
mouseDown=true
drawDisplacement!!!!!!!
previous=221,186 & current 221,186
mouseDown=true
mouseUp----------------------------------------------
Guest
Sep 02, 2011 Sep 02, 2011
YOU HAVE RIGHT!
the displacement work fine (both  2.6 and 2.7), in my app the value that I put into the filter is left.
thaks a lot, you are a genius
May 09, 2012 May 09, 2012
myoscaroxy, do you can help me, showing your code with solution? I've the same problem. I see that problem is the x,y of Touch position, but I could not to solve this.  Thanks!!!
Guest
May 17, 2012 May 17, 2012
it's all:
private function drawSprite():void{
_size = _sizeOriginale * _scaleSprite;
_sizeMezzi = _size / 2;
matrix.createGradientBox( _size, _size, 0 );
sprite.graphics.drawCircle( _sizeMezzi, _sizeMezzi, _sizeMezzi );
createMap();
map = new BitmapData( _size, _size, false, 128 << 16 || 128 << 8 || 128);
private function drawDisplacement( bmp:BitmapData, currentX:int, currentY:int ):void{
_point.x = currentX;
_point.y = currentY;
_displFilter = new DisplacementMapFilter(
bmp,
_point,
( _previousX - currentX )*hardness,
( _previousY - currentY )*hardness,
imgBitmap.bitmapData.applyFilter( imgBitmap.bitmapData, imgBitmap.bitmapData.rect, _zero, _displFilter );
private function onTouchMove( event:Event ):void{
if (event as MouseEvent){
_currentX = MouseEvent(event).stageX  - (sprite.width * _scaleFactor)/2 ;
_currentY = MouseEvent(event).stageY  - (sprite.height* _scaleFactor)/2;
}else{
_currentX = TouchEvent(event).stageX - sprite.width/2;
_currentY = TouchEvent(event).stageY - sprite.height/2;
_currentX = imgBitmap.globalToLocal(new Point(_currentX,_currentY)).x ;
_currentY = imgBitmap.globalToLocal(new Point(_currentX,_currentY)).y ;
sprite.x = _currentX;
sprite.y = _currentY;
if (_startBeginTouch){
_previousX = _currentX;
_previousY = _currentY;
_startBeginTouch = false;
if( _mouseDown && (_currentX != _previousX || _currentY != _previousY)){
drawDisplacement( map, _currentX, _currentY);
private function onTouchBegin(e:Event):void{
_mouseDown = true;
_startBeginTouch = true;
private function onTouchEnd(e:Event):void{
_mouseDown = false;
Guest
I alarmed you that I tried to work with big image, or better, image from camera and the app becomes very slow. I tried to create an app for the image distortion but the result is wrong, what a pity!
I tried with air 3.2 on 3gs iPhone.
