I have tried in different computers, different installers and I keep getting the following errors.
Exit Code: 6
Please see specific errors and warnings below for troubleshooting. For example, ERROR: DF027, DW006 ...
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 11 error(s), 0 warning(s)
----------- Payload: {AC76BA86-1033-F400-7760-000000000005} Acrobat Professional 10.0.0.0 -----------
ERROR: DW006: Apple Package failed to install successfully.
----------- Payload: {CC006FD6-00EF-46FC-ACA0-7A28EFF44D20} Adobe Media Encoder CS6 6.0.0.0 -----------
ERROR: DF027: Unable to copy file from "/private/tmp/.tempdirQFnk2Ji6/Assets1/Adobe Media Encoder CS6.app/Contents/Frameworks/CIT/Plug-ins/CustomLanguageModel/CustomLa nguageModel.bundle/Contents/MacOS/CustomLanguageModel" to "/Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/CIT/Plug-ins/CustomLanguageModel/CustomLa nguageModel.bundle/Contents/MacOS/CustomLanguageModel" (Seq 981)
ERROR: DW063: Command ARKCopyFileCommand failed.(Seq 981)
----------- Payload: {E1C48031-9366-427F-AC04-535CEDAAD995} Acrobat X Pro 10.0.0.0 -----------
----------- Payload: {6040E054-500A-427A-9DA2-349F0FEB19D1} Adobe Illustrator CS6 Core_AdobeIllustrator16en_USLanguagePack 16.0.0.0 -----------
ERROR: DF027: Unable to copy file from "/private/tmp/.tempdirD9w1UHYR/Assets1/Application/Cool Extras.localized/en_US/Templates/Film/Banner.ait" to "/Applications/Adobe Illustrator CS6/Cool Extras.localized/en_US/Templates/Film/Banner.ait" (Seq 67)
ERROR: DW063: Command ARKCopyFileCommand failed.(Seq 67)
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Adobe Illustrator CS6 Core_AdobeIllustrator16en_USLanguagePack: Install failed
ERROR: DW050: - Adobe Illustrator CS6 Core: Failed due to Language Pack installation failure
ERROR: DW050: - Acrobat Professional: Install failed
ERROR: DW050: - Adobe Media Encoder CS6: Install failed
ERROR: DW050: - Acrobat X Pro : Install failed
Try if any of the following steps helps in resolving the problem -
1) Run any OSX updates available
2) Reboot the machine and quit any other application
3) Download a fresh copy of installer and run it locally from your machine (not from an external drive)
4) Run from a different admin account
Please update if it solves your problem or share the complete log if you encounter any error.
Already did that too, I tried 3 different computers, so I think the problems is with the installer. I even went deep in the folder and tried installing acrobat by itself and still no luck. They shipped a physical DVD that I should be getting today. Let's see if it works, if it does then the installer online is corrupted.
Here is the log file. The system is Mac Os X 10.7.4. I obtain the same error trying to install the whole suite or Illustrator by itself.
Thank you very much for your support.
Exit Code: 6
Please see specific errors and warnings below for troubleshooting. For example, ERROR: DF027, DW063 ... WARNING: DS012 ...
- 0 fatal error(s), 4 error(s), 4 warning(s)
----------- Payload: {0C4E7429-E920-4125-980E-029A87AE0A4D} AdobeColorCommonSetCMYK CS6 4.0.0.0 -----------
WARNING: DS012: LocalizeFile: Localized string not found for locale 'it_IT' try fetching for en_US(Seq 21)
WARNING: DS012: LocalizeFile: Localized string not found for locale 'it_IT' try fetching for en_US(Seq 22)
----------- Payload: {C7B1C1B3-368D-4C32-A818-83F1554EB398} AdobeColorCommonSetRGB CS6 4.0.0.0 -----------
WARNING: DS012: LocalizeFile: Localized string not found for locale 'it_IT' try fetching for en_US(Seq 11)
WARNING: DS012: LocalizeFile: Localized string not found for locale 'it_IT' try fetching for en_US(Seq 12)
----------- Payload: {AAF0D225-F129-40F2-916E-12E28DBD19ED} Adobe Illustrator CS6 Core 16.0.0.0 -----------
ERROR: DF027: Unable to copy file from "/private/tmp/.tempdirlawb0R4a/Assets1/Application/Adobe Illustrator.app/Contents/Frameworks/AdobeLinguistic.framework/Version s/3/AdobeLinguistic" to "/Applications/Adobe Illustrator CS6/Adobe Illustrator.app/Contents/Frameworks/AdobeLinguistic.framework/Version s/3/AdobeLinguistic" (Seq 1825)
ERROR: DW063: Command ARKCopyFileCommand failed.(Seq 1825)
ERROR: DW050: - Adobe Illustrator CS6 Core_AdobeIllustrator16it_ITLanguagePack: Install failed
