danbenner
Problems with Pathfinder altering shapes
May 16, 2012 8:05 AM
I haven't used Pathfinder in a while, but have recently and run into problems.
It seems to alter shapes and add stroke value instead of just slicing things apart (using the divide tool).
I've tried expanding strokes, removing strokes etc... but are there any other values I should try to reduce before dividing?
I attached a few samples. The "after" actually alters the smooth shape of an ellipse by angling the points. It also bloats up the weight of the white lines.
Is there a checklist of things I should make sure I have off, like compound paths, expanding strokes, etc?
(in this case, I turned the stroke off)
    May 16, 2012 9:52 AM   in reply to danbenner
    Illustrator CS5 or higher? Then check if "Align to pixel grid" is off.
    May 16, 2012 3:42 PM   in reply to danbenner
    DB,
    Another Guess, here. Try checking the Pathfinder Options, maybe the value is too high. I never have touch these settings but was able to replicate your issue quickly by increasing the number. I know little about them but maybe that's where illy had it's "boom-boom".
    Goodluck!
    dB
    databang
  • Mathias17
    Feb 20, 2012
    May 16, 2012 10:11 PM   in reply to dataBANG
    Nice . . . illustrated . . . example . . . there, databang hehe
    My advice - if these shapes are super small, relative to the canvas, blow them way up. Past versions of Illy didn't handle detail well at real small sizes, as if there's a image resolution issue at hand. Turn on Scale Strokes/Effects in the Prefs before you scale up.
    May 17, 2012 6:27 AM   in reply to danbenner
    Dan,
    maybe I just have some residual metadata from playing with a certain shape for too long...
    How many Anchor Points do the troublesome paths contain?
    As you know, the fewer the better and smoother, and safer.
