Clare73
Pause SWF on entering screen
May 17, 2012 6:14 AM
Hi there,
I wonder if anyone can help. I've recorded a project to show how a particular piece of software works. I've published that as an SWF and then imported it onto a slide in another Captivate project. When the slide is reached, it automatically starts playing the SWF. I'd like it to be paused on entering the slide, and then can be played when the user clicks on the play button.
Is there a way of doing this?
I'm using Captivate 5.5
Thanks in advance.
    May 17, 2012 6:26 AM   in reply to Clare73
    You just add a button in the beginning of the slide, this will pause the project and the project will resume after the user clicks on the button.
    You can also set the button to pause the slide at the beginning ar after 'x' seconds, where x is the time in seconds.
    For button, set action as 'Continue'.
    Make sure that the button is placed before the beginning of the SWF in the timeline.
    Let me know if you need more information on this.
    Aditya Kalania
    May 17, 2012 7:58 AM   in reply to Clare73
    Aditya is right, but I want to warn you: it is not a good idea to insert a CP-SWF inside another Captivate project, because this will often cause issues. Is there a particular reason why you choose this work flow instead of having the capture software slides inserted normally in the project? It would also give you a lot more control.
    Lilybiri
