walker85
Find Text in FootNotes only
May 15, 2012 12:32 PM
hi all, i work with CS5 Indesign and i'd know if there's a way or GREP expression to find text only in footnotes not in the main document. Open the find/replace window you can search in main document including footnotes but not the reverse.
Thank you
    May 15, 2012 12:55 PM   in reply to walker85
    Do you have a unique style assigned to your 'notes?
    May 16, 2012 1:13 AM   in reply to walker85
    Then you are good to go. Just make sure to specify this style in the Find Formatting box in the Find/Change dialog (you might have to press the "More Options" button to see this).
    "Footnotes" were added in CS2, and so was the option to exclude them from searching, but FIVE FULL versions later nothing -- nothing at all -- has changed since then. Somehow that led me to think I was the only one using them, ever. Glad to see I'm not!
    May 17, 2012 8:52 AM   in reply to walker85
    May 17, 2012 9:01 AM   in reply to [Jongware]
    If you want to you can join the crusade http://forums.adobe.com/message/4273963#4273963
    It's the feature request forum - that seems to go largely ignored.
    But the more people the better I suppose.
    Losing all faith in Adobe's interest in upgrading this feature.
    May 25, 2012 8:18 AM   in reply to walker85
    The top one.
    The bottom one only works for a paragraph style (and then it's value is what you would expect).
    May 28, 2012 6:59 AM   in reply to walker85
    Yeah, on occasion I get the same thing with commands that *should* work that way. Try forcing the *exact* pointer to a style down its throat -- sometimes you have to be quite explicit.
    app.findGrepPreferences.appliedParagraphStyle = app.activeDocument.paragraphStyles.item("Footnotes Style");
    By the way: this will not work if your 'notes style is inside a group. If it is, you have to drill down to the exact position using "paragraphStyleGroups" items.
