Remove synchronized connection
Aug 18, 2011 1:11 PM
So I discovered the synchronize option in my file explorer today (CF Builder 2), and I accidentally set up a synchronized connection that I don't really want.  How do I remove this connection?  I can't seem to find the remove option anywhere.
Eric Cobb
http://www.cfgears.com
http://www.ncfug.com
    Aug 18, 2011 7:57 PM   in reply to Eric Cobb
    In CFBuilder open up the File View (WINDOW>>SHOW VIEW). In there you will be able to see all of you sync connections and you should be able to delete the one you want to delete.
    Aug 24, 2011 12:05 PM   in reply to Eric Cobb
    Down at the bottom of file view you should see little globe icons for FTP, FTPS, SFTP. Click ont he little triangles to expand them and you should see your sync connecitons.
    http://12robots.com/enclosures/2011-08-24_1402.png
    Oct 13, 2011 10:37 PM   in reply to 12Robots
    I'm also having this issue. How is it done?
    Brad
    Oct 14, 2011 6:21 AM   in reply to Goet
    I already explained how it is done. Are you saying that is not working?  If so, then what isn't working?
    Jason
    May 17, 2012 9:01 AM   in reply to 12Robots
    I have the same question. I have a miss-named Synch profile attached to a CF Project. I want to remove it WITHOUT removing the ftp connection found in the File View window.
    What you are suggesting removes the FTP connection to get ride of the synch profile attached to the project. I know this will work BUT I don't want the FTP connection removed because it's associated with a properly names synch profile. I just want the miss-named profile gone. Does that make sense?
    Oct 11, 2012 2:20 AM   in reply to Fusecast
    hello guys,
    you can find a solution to remove the synchronization without removing the ftp connection at this address : http://lemmings15.wordpress.com/2012/10/11/synchronisation-avec-coldfu sion-builder-2/
    it's in french but the key words are in english.
    Dec 1, 2012 6:49 PM   in reply to lemmings_15
    Lemmings post worked for me. There were all sorts of sync connections that didn't work and the sync manager allowed me to see all of this stuff. I was also able to edit both the ftp connections and sync connections in one place. Great thing to know although not sure why it is buried so deeply.
    Now since his post is in French, here is the important part: Window=>Show View=>Other=>HTML Standard Views=>Sync Manager.
    Cheers,
    Brad
    Dec 3, 2012 1:42 AM   in reply to Goet
    I'm glad, if my blog helps you.
    I know it's in french but there is at least 2 reasons for that:
    - I'm french speaker so it's more easy for me even if i understand english correctly.
    - There is not a lot of blog talking about Coldfusion in french, so i decided to do it in french.
    Even it's in french you can pass by my blog and say something.
    If there is a request ! can translate all my articles in english.
