PNGDiver
Major features of Liquify Filter in CS6 are not working properly.
May 16, 2012 10:47 AM
Tags: #cs6 #liquify_filter
The Liquify filter in PS 13.0 x64 does not work correctly.  The Forward Warp, Magnify and Hand tools work okay, but the rest of them procuce the same strange effect of a jumbled combination of swirl and black on white dot patterns. ending with a circular "transparent" pattern. I have just installed after removing 5.5 and using the Adobe Cleaning Tool. There were multiple errors in the installation log file, which I saved. I'm running Win 7 fully patched and up to date. I have a Toshiba Tecra wiith 6GB of RAM and an ATI Radeon DH 6450M GPU.
Here is a screen shot:
All three of the non-functioning tools begin with a swirly pattern quickly being jumbled by dots and checkerboard. If you hold the click for a few seconds it ends up looking like the above image.
Could sure use some help. I use the liquify filter a lot and I don't want to waste a fortune by going back to CS55.
    May 16, 2012 11:36 AM   in reply to PNGDiver
    From what I have read Liquify in CS6 underwent some serious changes and requires more horsepower from the video card.  Check to make sure you have the latest video card drivers.
    May 16, 2012 11:48 AM   in reply to PNGDiver
    Tested video cards for Photoshop CS6
    Adobe tested the following video cards before the release of Photoshop CS6­­­. This document lists the video card by series. The minimum amount of RAM supported on video cards for Photoshop CS6 is 256 MB.
    Note: Adobe tested laptop and desktop versions of the following cards. Be sure to download the latest driver for your specific model. (Laptop and desktop versions have slightly different names.)
    nVidia GeForce 8000, 9000, 100, 200, 300, 400, 500 series
    nVidia Quadro 400, 600, 2000, 4000 (Mac & Win), CX, 5000, 6000
    AMD/ATI Radeon 2000, 3000, 4000, 5000, 6000, 7000 series
    AMD/ATI FirePro 3800, 4800, 5800, 7800, 8800, 9800, 3900, 4900, 5900, 7900
    Intel Intel HD Graphics, Intel HD Graphics P3000, Intel HD Graphics P4000
    Note: ATI X1000 series and nVidia 7000 series cards are no longer being tested and are not officially supported in CS6 – some basic GL functionality may be available for both these cards.
    May 16, 2012 1:13 PM   in reply to PNGDiver
    Adobe does have a free script cleaner which will clean up shards left when you uninstall your Adobe products.
    May 16, 2012 2:45 PM   in reply to PNGDiver
    Do you happen to have an older ATI driver installer handy? I haven't seen this particular result, but have seen some problem relating to 3D usage with the current 12.4 package.
    regards,
    steve
    May 16, 2012 4:17 PM   in reply to PNGDiver
    I neglected to notice the M part of your GPU spec. The problems I've been seeing are with the recent desktop driver version. With what you show, I do think this is driver related and nothing to do with installer 'leftovers'. But, yes, having a laptop instead of desktop card makes checking various drivers more difficult.
    One option to try, which will clarify if the driver is key, is to turn off the GPU path when invoking the filter. To do this, hold down the Alt key then click on Filter and drag down to Liquify. To indicate that the CPU is being used for compute, you should see a hairline black stroke around the image in the dialog window.
    I'm asking for info regarding mobile driver versions to see how I can help you out.
    regards,
    steve
  • Noel Carboni
    Dec 23, 2006
    May 16, 2012 4:57 PM   in reply to PNGDiver
    Follow up by requesting a display driver update through your laptop maker.  If they don't know there's a demand, they can't very well prioritize their efforts to make a new driver available.
    -Noel
    May 16, 2012 5:55 PM   in reply to PNGDiver
    Thanks for reporting back that CPU compute works as expected. We will do more digging here and let AMD know what we find. We'll also see if we can give Toshiba a heads up so that they might issue an update as well.
    I've only played a little with video driver mods a few years back trying to get Vista64 to run on my MBP. There may be some options along those lines but I don't know where best to look.
    regards,
    steve
    May 17, 2012 5:00 PM   in reply to PNGDiver
    I expect the news I'll have will be thin for a while, particularly on Toshiba issuing updates. I'll bookmark this post and report back when I have something actionable.
    The driver mod was fun. I had just received a newly released MacBook Pro w/8600m GT, was working on GPU required features and Ps was just ported to Win64 support. I wanted to see if I could get a dual boot laptop for testing while riding the train, and it mostly worked. The biggest hassle was mismatched keyboard input for shortcuts, so I needed to use a mouse peripheral. This was when Boot Camp was still beta. Needless to say, I was way outside the envelope on controlling environment variables.
    regards,
    steve
    May 19, 2012 8:56 AM   in reply to PNGDiver
    Thank you for pointing out this issue and a temporary resolution with the ALT key. I too just noticed that the bloat and pucker features were not working for me, either. I am in the process of installing updated drivers from ATI for my HD4200, but we'll see if the issue is resolved.
    Is there anything we need to know right now as far as updates or patches and their timeframe? Granted it is early but the workflow is still there
    Jun 3, 2012 11:38 PM   in reply to PNGDiver
    I just installed CS6 on a current, large iMac. LIQUIFY DOES NOT WORK! It creats a strange light box in the area every time. The filter is useless as it destroys the layer you are trying to work on. THIS IS A SERIOUS BUG, ADOBE.
    Jun 4, 2012 9:07 AM   in reply to PNGDiver
    Kim, Please post your machine configuration information. Are you running OS X version 10.7.4? Is your iMac an i7 processor? Does your Mac use the ATI Radeon HD 5750 video card? If you can include a image of the "light box" bad result it would help. We need to reproduce the problem here so we can track down the cause of the problem.
    Jun 4, 2012 11:03 AM   in reply to jworthin
    OS X 10.6.8;
    27" iMac
    2.8 GHz Intel i7 core
    16 GB RAM
    ATI Radeon HD 4850
    External cache drives disabled for this test.
    Process is:
    (a) cut and paste square area;
    (b) use large eraser to partially erase outer area of square paste area;
    (c) liquify area;
    (d) bug is in artifacts in Z-axis (mask)
    CS6 currenly unusable.
    CS3 works perfectly on same function.
    See attached file.
    Is there a way to get fixed AMD/ATI drivers? They are not on AMD/ATI web site.
    Thank you.
    Jun 4, 2012 11:41 AM   in reply to Kim Rubin
    Thanks Kim. Can you attach a CS3 version of the image so I can see exactly the difference - good vs bad? I do not understand the comment the errors are in the Z-axis(mask).
    Apple controls the drivers for their machines. Updated drivers would be included in a new releases of their OS. For you to get the latest driver you would need to upgrade to 10.7.4. This is currently the newest OS for your iMac. I think it is about $30. I do not know if this will fix your specific problem, but the driver should be better.
    Jun 5, 2012 12:22 PM   in reply to jworthin
    I purchased and installed Lion, per your suggestion, in order to supposedly
    get "updated GPU drivers". Not only did this break a huge number of apps
    (including your own CS6
    Jun 11, 2012 1:45 PM   in reply to jworthin
    So ... from this thread I got a temporary work-around which was to set the GPU mode to "basic" in the Advanced Options. This appeared to fix the problem. Except that the problem is back. So ... this critical bug remains.
    You asked "what is Z-axis (mask)"? In Photoshop any layer can have a "mask." It goes by different names, but it is a transparency channel. You ca see this easily in the above posted samples as the white background. The background is not really white in the real layer (which I cannot post in this forum because your max file size is teensy-weensie worthless), it is mostly transparent. Look again at the photo of the girl's face. Do you see those vertical and horizontal bands? or lines? They are not supposed to be there. At all. None. zero. They are 100% artifacts generated by Photoshop bug. The reason you can see these is that the transparency mask suddenly changes from one value (say, 5% transparent) to another value (say, 60% transparent) along those lines. Properly, the transparency should blend smoothly from the center (face -- opaque) to the edge ( mostly transparent).
    Jun 13, 2012 11:42 AM   in reply to Kim Rubin
    Kim, we are having trouble replicating the problem you are seeing on our iMacs. What are the dimensions of the image that show the problem? Are all images (different sizes) with transparency showing artifacts? Any information you can provide on when you see the problem and when you do not would be very helpful for tracking this down. Would it be possible for you send me the problem file via a Dropbox?
    Jun 13, 2012 12:20 PM   in reply to jworthin
    Yes. I put the photoshop file, with labeled layers, in my public dropbox folder. I have almost no experience with dropbox. What else do I need to do?  And yes, files tend to be pretty large, this sample file is under 1 mpix.
    Jun 13, 2012 12:22 PM   in reply to jworthin
    Brush size is large - 400. Pressure = 3. Push left tool. I am using a wacom intuos tablet, with current (Lion) drivers.
    Jun 13, 2012 12:43 PM   in reply to Kim Rubin
    Kim, please take this offline and contact me via notgnihtrow@yahoo.com. I will then tell you how to make the dropbox connection in email. Thanks.
Bookmarked By (1)
