alrdj70
Audio restarting from beginning on relaunch
Sep 2, 2011 6:29 AM
I have a course that is published to SCORM and imported to an LMS. There is audio on each slide and background audio. When I launch the course from the LMS, everything works fine. If I exit in the middle and then relaunch, it takes me to the slide where I left off, but the audio starts from the beginning of the course.
Any ideas on why this is happening?
    Sep 2, 2011 6:37 AM   in reply to alrdj70
    Did you apply the audio separately to each file, or as a single file spread over all the slides in the movie?
    Sep 2, 2011 7:14 AM   in reply to alrdj70
    Look at each clip listed in the Library and check the Usage Count to see that these are actually used on slides. If they ARE actually all separated onto different slides, I would suggest that something has gone awry inside Captivate and it still thinks it's dealing with a single audio file.
    You may need to export all the audio clips out as WAV files, rename them from what they were so that Captivate won't recognise them, then reimport each one back in to replace the file currently on its slide.  Perhaps that will make Cp play nicer.
    Sep 2, 2011 7:24 AM   in reply to alrdj70
    No I don't think whether you did it with MP3 or WAV would make a difference.  Just that WAV is always better for preserving audio quality.  MP3s tend to 'wear out' because they're compressed quite a bit.
    At this stage I don't have any ideas other than that your project might be corrupted.  If this is a Cp5 project, try copying all slides from it into a new blank project and see if it does the same trick there.  Sometimes that can resolve internal issues under the hood.
    May 17, 2012 12:52 PM   in reply to alrdj70
    Did you ever find out what the issue was? I am having the same problem and I am looking for a solution....  My project is not corrupted, but I don't know why the audio keeps restarting from the begining.  Any help would be great...
    May 17, 2012 6:59 PM   in reply to Julie88
    Just had another thought.
    Did you add this audio to the Background by any chance? Go to Audio > Edit and check to see if Background is greyed out or not.
    May 18, 2012 7:06 AM   in reply to RodWard
    The audio was not incorporated in the background, but thanks for the suggestion.  What I ended up doing is to set the audio to start at .1 seconds into each slide.  That seemed to work....
    May 18, 2012 8:48 AM   in reply to Julie88
    That seems to be the best thing to do. Its also discussed on Captivate Blog : http://blogs.adobe.com/captivate/2010/08/audiovideosync_in_captivate_s wf.html.
    This Blog is for Audio/Video sync issue, you may use this in future.
    May 18, 2012 10:54 AM   in reply to AdityaKalania
    Thanks for sending me the link!
