Is there a way to change the default increment for the X and Y value boxes in the Transform area of the Control panel? When I have an object selected and want to move the object by clicking the arrows beside the X and Y boxes the object moves 1/8 inch for each click. Is there a way to set that to 1/16 inch for example?
A screen grab is attached showing the area on the Control panel in question. I've checked all the Preferences settings I can find but haven't found this one yet.
Strangely mine moves to the nearest 1/4 inch. It appears to be 2X the number in the grid divisions box in the Guides and Grids tab of the preferences. When using 8 in this box, I get the 1/4 in.; when setting it to 16, it uses 1/8 in. But setting it to 32 doesn't yield 1/16 in so there must be a lower limit.
Hi
In Illustrator CS6 the increments in fields was adjusted to a more logical way..and based on the units it´s used in the document. Also Illustrator added the ability of partial increments.
So these are some rulers:
If you insert your pointer to a field and use up or down key...you will have normal increments. If you use Shift + up or down you have multiple increment. And if you use Ctrl (Cmd) + up or down you get partial increments.
But as I told...the value of normal, multiple and partial increments depends on the unit of measurement the project is currently using.
For example...in the image of Dlux the document is using inches. So these are the concepts:
In fields that works with inches with 4 decimal places:
Normal: increments 0.125
Multiple: increments 1
Partial: 0.0625
In fields that works with inches with 3 decimal places (the case of the fields highlighted in the image):
Partial: 0.06
In fields that works with inches with 2 decimal places:
Partial: 0.06
In fields that works with inches with 1 decimal places:
Partial: 0.1
Hope to be helped
Gustavo.
As Gustavo states there are ways to obtain a smaller or larger increment based on the preset.
But there is actually no way to change the actual increment unless it is accessible via the preferences which you probably do not want to mess with though some of the users here sometimes do it.
Perhaps a script might maske it workable.
Apologies for the delay getting back to this, been tied up with computer upgrades for a few days. Thanks to everyone for the input and information - it's not a huge issue but more of a minor annoyance. I had a feeling there was something I was missing, and Gustavo is absolutely right - holding down Ctrl and clicking the arrows in the Control panel boxes gives a 1/16" movement.
Clicking shift or control in addition to the arrows never occured to me - thanks for the tip ![]()
