i 'm going to make a LR catalog of about 10.000 to 15.000 photo's on wich i have to make a lot of selections. I am planning to use the stars and the colors but i 'm afraid the large number of photo's wil stop me from fast and easy working.
I can use any tip or advice about this.
15,000 images is nothing as far as that part of Lightroom is concerned. There are people with more than 10 times that number that get along just fine. The issue of speed in Lightroom lies somewhere else. Only problem is, nobody seems to know where that is. If your computer works well with Lightroom, consider yourself among the many fortunate. If it doesn't perform well, roll the dice. Maybe you'll come up with the answer.
Thanks Jim for your fast answer, the problem is that i have to collect the work of 12 photographers as fast as possible. As far as i know the fastest way is to copy the files first onto a harddisk and import them later into the LR catalog, i did not have the chance of importing hundreds of files into the LR catlog to know the difference of speed between importing into LR directly or just copying the files from the card/camera onto the external drive.
As far as my experience with the speed of LR on my computer, that will not be a problem.
Fortune? Sorry, but I have the latest hardware with 32gb of memory and LR4 is f* slow when using edits, tagging, lens correction, gps,... I have split my catalog to smaller catalogs to not be over 10k images, after this value the speed for normal work is unacceptable. So in theory there is no reason that the DB will be slow, but Adobe is just having some BIG issue which should be solved.
I have done the import of my photos to LR3.6 and it was done during 2nights, but with LR4 I would expect 2weeks...
That's not my experience. I have 12G memory and a i7-930 (two years old). LR4 is slower than LR3.6, but few delays of more than a second or two. I have 60,000 images in the catalogue. I'm not aware of any delays I experience related to size of catalogue - most seem to do with Develop Module for a single image.
Initial import might take a while. I've not had to do that since I first started using LR2 on an older machine, and I seem to recall that importing 20-30k files took an hour or two, but I might be wrong. But for me, importing from a memory card is generally limited by card speed.
