Hi Gurus
I have a very basic problem, which I nonetheless cannot solve myself. When I create buttons, I would like them to all be the same size, however I cannot see how to determine the dimensions other than by manually adjusting and then checking the result. Of course when you pass your cursor over a button you see the size (e.g. 70 x 38) but how can I make that button be 39 high instead of 38. Trying to do it manually is a hit-and-miss affair.
Thank you
Lynton
Select the button - go the the Transform section in the Properties panel. Here you can modify the size by inserting pixel values directly.
www.cpguru.com - Adobe Captivate Widgets, Tutorials, Tips and Tricks and much more..
Hello,
I do not know if Michael's correct answer will solve your issue totally? Perhaps I do misunderstand, but think you want not only to know how to resize objects more precisely (which can be done by the Transform accordion, although I prefer using shorcut keys for small resizing/moving, see: Shortcut keys for Moving/Resizing ) but also how to have the same size for all buttons. And using the Apply to all from the Transform accordion is not useful because, which I regret tremendously, this accordion will not only apply the size settings to all objects of same type (or style) but also the X-Y coordinates of its registration point (mostly top left of the bounding box) and if you use 5.5 also the rotation if the source object has a rotation. I have already asked multiple times to have the size separated from those other properties, but apparently no one else has issues with that, so request is not top priority.
Another possibility would exist if size was part of the object style, but it is not either.
I could offer some suggestions, all workarounds, but first could you tell me which version you are using and, if you are talking about Text buttons or are you willing to create your own image buttons or to replace the buttons by an image with a transparent button on top of it (you'll lose the states in that case).
Anyway, for text buttons: be sure to uncheck the AutoSize Buttons in Preferences, Defaults.
To resize buttons on the same slide to the same size, you can use the right click menu on the selection, Align, Resize to Same Size
Lilybiri
On the same topid but as a general comment.
I have often thought a "format painter" (as you have in MS Excel) would be a great addition for Captivate.
With this option you could click the object which you want to duplicate the format - for example the button as mentioned by Lynton 123 - and then click on other similar objects and on each click, the object would take on the same format as the original "master".
Seems like a good idea to me.
Noel
