i checking speed test. so this script showing like 504.254654 value.
but i don't want to after desimal(.) numbers.
(like 504 only)
value.text = String( ( ( file.size/myTimer.currentCount ) / 1024 ) * 8 );
value.text = String( int(( ( file.size/myTimer.currentCount ) / 1024 ) * 8 ));
You can just cast it to a type that doesn't support floating point values, like ints.
var splitString:String = String( ( ( file.size/myTimer.currentCount ) / 1024 ) * 8 );
var splitStringArra:Array = splitString.split('.');
value.text =
splitStringArra[0].toString();
YOu can just convert the number to an int before you convert it to a String...
value.text = String( int( ( file.size/myTimer.currentCount ) / 1024 ) * 8 );
Beat you by 5 minutes! Haha
Thank you for all.
and one more thing
in my function >= 256 this test pass visible upPass button. but not showing in this function. what am i worng?
function show_message(e:DataEvent)
tm.stop();
value.text = String( int( ( ( file.size/tm.currentCount ) / 1024 ) * 8 ) );
uploadTest();
function uploadTest()
if (Number(upSpeeds) >= 256)
upPass.visible = true;
else{
upFail.visible = false;
I think if the speed is >= 256 then you want upPass.visible = true; like you have it but if it's less then you should set upFail.visible = true;. You're currently setting its visibility to false;
Aside that, are you saying the upPass button isn't showing if the speed is greater than 256? Is the instance name (not the library name) of upPass and upFail set properly? Is the alpha also set to 1?
upFail.visible = true; is currect, that is my mistack.
i'm using trace but showing only "Fail".
i getting value in "upSpeeds" text 256 above but showing "Fail"...
else{
Can you run a trace inside that function to verify data?
e.g.:
trace("upSpeeds: " + upSpeeds); // see what the function sees
if (int(upSpeeds) > 256)
else
Typically you may see the text is correct but if the variable wasn't defined in a global scope it is not available to the function and it will trace this to output:
upSpeeds: undefined
If that's the case you know upSpeeds needs to be defined on a global level so it can be utilized in that function.
Ah then it would have traced:
upSpeeds: [object TextField]
And then you'd know why it wasn't working . Trace often if you can, it's a very simple tool to debug.
Glad you got it working and good luck!
yes really.
i am beginner, so.....some mistacks.
any way Thank you.
You are welcome and good luck!
