btvbillb
3 columns in fluid grid issue
May 18, 2012 7:29 AM
Tags: #dreamweaver #cs6 #fluid_grid
I followed a video tutorial that shows how to create 3 columns. You are instructed to create a div as a new row and then add two more divs to that row and then drag the divs to a value of 4 each. The next div row to be created would be for a footer, etc. When viewed on a desktop all of this looks fine. The issue is that when resized down to mobile size, column 2 and 3 are indented over a bit (see below). I have tried creating three divs (each in their own row) with a span of 4 each but they won't all float together in one row. Any solutions for this? Thanks.
Desktop
Mobile
    May 18, 2012 9:19 AM   in reply to btvbillb
    It's hard to say without seeing your code. But I'll hazard a wild guess that your mobile CSS needs that section to have
    float:none;
    padding:0;
    margin:0.
    display:block;
    Nancy O.
    May 18, 2012 9:40 AM   in reply to btvbillb
    That's not enough to go on.  CSS cascades.  We would need to see the Desktop, Tablet and Mobile CSS code as well as your HTML
    Nancy O.
    May 18, 2012 10:23 AM   in reply to btvbillb
    You've still got left marigins on the below <divs> once you go to a one column layout, that is causing the indent.
    @media only screen and (min-width: 481px)
    #LayoutDiv3 {
        clear: none;
        float: left;
        margin-left: 1.0989%;
        width: 32.6007%;
        display: block;
    #LayoutDiv4 {
        clear: none;
        float: left;
        width: 32.6007%;
        display: block;
    You might want to look at this tutorial its better in my opinion than what you are following:
    http://webdesignerwall.com/tutorials/responsive-design-with-css3-media -queries
    Alistapart (if that's where you are learning from) are a bit up their own backsides in my opinion and don't really cater for beginners.
