I am using spry menu in DW and I have a page called products which has a menu with some items. The question is how can I access to item menus using this link:
".../products.html#USNP"
Now I can access to a specific menu item of this page using the following link ".../products.html#tab=3" but i like to have the name of the menu items instead of the item number.
I would be appreciated if anyone can help me .
So we are talking SpryTabbedPanels where the tabs are used as your menu bar.
The out-of-thebox Spry product identifies each tab as a number and as such, only numbers can be use to open each panel.
To overcome this limitation, you can assign your expressions to corresponding numbers. I am not sure if the '#' will do the trick, thinking that you may need to assign a variable instead.
Gramps
