Modify a script help?
May 10, 2012 6:45 AM
I have a script that needs to be tweaked very slightly.  Right now this script is setup to save out files and rename them as follows:
current document file name + "-" + artboard name + (rename files from .ai to .pdf)
I need this script tweaked so that the exported file names are as follows:
artboard name + "-" + current document file name + (rename from .ai to .pdf)
Here's the script that needs to be tweaked:
#target illustrator
function artboardsToPDFs() {
     if (app.documents.length = 0) {
          return;
     } else {
          var docRef = app.activeDocument;
          var docName = docRef.name;
          var baseName = docName.replace(/.ai$/,'');
     var dF = Folder(Folder.desktop + "/AI PDF's");
          if (!dF.exists) dF.create();
          var aB = docRef.artboards;
          var autoNames = Array();
          for (var i = 0; i < aB.length; i++) {
               var abName = aB[i].name;
               autoNames.push(baseName + '_' + abName + '.ai');
          if (!docRef.saved) docRef.save();
          var aiOpts = new IllustratorSaveOptions();
          aiOpts.compatibility = Compatibility.ILLUSTRATOR13;
          aiOpts.pdfCompatible = true;
          aiOpts.saveMultipleArtboards = true;
          var saveFile = File(dF.fsName + '/' + docName);
          docRef.saveAs(saveFile, aiOpts);
          docRef.close(SaveOptions.DONOTSAVECHANGES);
          saveFile.remove();
          renameFiles(dF, autoNames);
artboardsToPDFs();
function renameFiles(dir, fL) {
     for (var i = 0; i < fL.length; i++) {
          var f = File(dir.fsName + '/' + fL[i]);
          if (f.exists) {
               var reName = f.name.replace('_','-');
               f.rename(reName);
               f = File(dir.fsName + '/' + reName);
               reName = f.name.replace(/\.ai$/,'.pdf');
               t = File(dir.fsName + '/' + reName);
               if (t.exists) t.remove();
               f.rename(reName);
    May 10, 2012 9:25 AM   in reply to timlogochair
    Tim
    Should be as easy as
    to
    autoNames.push(abName + '-' + baseName + '.ai');
    May 10, 2012 10:53 AM   in reply to timlogochair
    Sorry Tim,
    I seem to be running into the same problem as you. It's obviously not doing the function at the end of the file. I'll try to explore  more. I wish I understood how to step through the script better.
    May 16, 2012 1:51 PM   in reply to timlogochair
    Not sure if this may be the problem but don't you want
    to be
    if (app.documents.length == 0) {
    May 17, 2012 4:46 AM   in reply to Larry G. Schneider
    Actually its NOT the auto names array that you want to alter… Thats a list of names that the app will by default will create ( based on doc content ) The script goes and finds these files and changes the names afterwards…
    May 18, 2012 6:58 AM   in reply to timlogochair
    This should do you… I updated it a touch… And made it simpler to edit…
    #target illustrator
    artboardsToPDFs();
        if ( app.documents.length == 0 ) { return; }
        var aiOpts, artBds, baseName, doc, fileDef, fileRep, i, names, obj, saveFile, saveFold;
        doc = app.activeDocument;
        baseName = doc.name.replace( /.ai$/,'' );
        saveFold = Folder( Folder.desktop + "/AI PDF's" );
        if ( ! saveFold.exists ) { saveFold.create(); }
        artBds = doc.artboards;
        names = Array();
        for ( i = 0; i < artBds.length; i++ ) {
            obj = Object();
            obj.defaultName = baseName + '_' + artBds[i].name + '.ai'; // Default AI naming convention
            obj.replaceName = artBds[i].name + '-' + baseName + '.pdf'; // Script swap about
            names.push( obj );
        if ( ! doc.saved ) { doc.save(); }
        saveFile = File( saveFold + '/' + doc.name );
        doc.saveAs( saveFile, aiOpts );
        doc.close( SaveOptions.DONOTSAVECHANGES );
        saveFile.remove();
        for (  i = 0; i < names.length; i++  ) {
            fileDef = File( saveFold + '/' + names[i].defaultName );
            if ( fileDef.exists ) {
                fileRep = File( saveFold + '/' + names[i].replaceName );
                if ( fileRep.exists ) { fileRep.remove(); }
                fileDef.rename( names[i].replaceName );
    May 18, 2012 9:29 AM   in reply to Muppet Mark
    Mark,
    I'm still having a problem with the renaming portion. Here's a picture of my file called test_5.ai and the contents of the folder AI PDF's on my desktop
    It seems as though the second rename is not taking. Mac OSX 10.6.8, AICS5
    May 18, 2012 9:41 AM   in reply to Larry G. Schneider
    Larry you need to have named your artboards first… It looks like yours are AI defaults… If I recall corrrectly this was always the case for Tim…
    May 18, 2012 9:53 AM   in reply to Muppet Mark
    Thanks, Mark. I had tried earlier with named artboards and the earlier version of the script but didn't name them when testing this version.
    May 18, 2012 9:57 AM   in reply to Larry G. Schneider
    Yeah, I didn't need to bother myself with testing for Tim… Named artboards default to strings, un-named to digits never tried with mixed…? Did it work OK once you named them?
    May 18, 2012 10:25 AM   in reply to Muppet Mark
    Worked perfectly with the named artboards.
