I'd like to be able to make Clipping Paths out of Compound Shapes
May 18, 2012 12:20 AM
I'd like to be able to make Clipping Paths out of (unexpanded) Compound Shapes.
I'm kind of disappointed that we can't do that already.
I'd also like the Expand button to work like it did in CS4 again. It made sense then.
    May 18, 2012 1:28 AM   in reply to John Stanowski
    You can make clipping paths out of compound paths. Using both fill rules, you should be able use compound paths *** you use compound shapes.
    WHcih "Expand button" do you mean - there's more than one.
    May 18, 2012 1:49 AM   in reply to John Stanowski
    Hold option when you click it... no expanding. They reversed the option function in CS4.
    May 18, 2012 1:53 AM   in reply to John Stanowski
    For the shape modes "Add" and "Intersect" you can use compound paths instead.
    Please show what you need to create.
    BTW: you could also use your compound shape as an opacity mask on whatever you want to mask.
    May 18, 2012 6:45 AM   in reply to John Stanowski
    John Stanowski wrote:
    .... Most of the time when I make Compound Shapes I elect not to Expand them into Compound Paths.
    But when I need one to be a Clipping Path I have no choice though.
    It works fine here, CS5 Windows 7
    May 18, 2012 1:12 PM   in reply to John Stanowski
    Number 1. is confirmed, doesn't display any outlines when transformation tools are used. Not a big problem when using the Move tool as you can remember the point clicked, drag and when you drop the point will be under the cursor, but it is a much bigger problem if you want to scale, rotate, or skew. No feedback as to what's happening until releasing the mouse. One workaround could be creating a copy on top with making it compound path, not shape and transform both using the copy for a feedback.
    Number 2 seems to be fine here unless I'm not understanding the issue. But I created one version with compound shape and one with just compound and tried various selections and editing with the direct selection tool and it appears both behave the same.
