Pages not aligned
May 18, 2012 12:49 PM
Tags: #cs6
I design a not for profit community magazine.
For some reason page two and three on my layout ar no lining up. I notice that there are two "0" on the vertical ruler. I have no idea how to corrct this. Picture attached.  I have just upgraded from CS4 to CS6.
Would love suggestions.
    May 18, 2012 1:35 PM   in reply to senine
    New with (?) CS5 is the Pages Tool which allows varied page sizes within a document.
    Select the Page Tool (I've circled) Click one or both page icons on the Pages Panel.
    Note the controls allowed in the control bar (Circled) with one .vs two pages selected.
    Play with it, you'll set it back to zero.
    May 21, 2012 10:34 AM   in reply to senine
    After an exhaustive 3 minutes testing, (and 16,000+ impressions on the job on press and  plating several files)  I am unable to affect the x values.
    I would suggest adding two pages, select all on a problem page, copy, go to the new page Edit > Paste in Place
    the X values will be off. Select all (they would still be selected after the paste) > Object > Transform > Move  (or shift+cmd+m) enter 1 in the Horizontal
    Items to beware - if there are locked elements on the page, they will not select, select each and unlock,
    During a Paste operation, there is the option (from the layers panel flydown,) Paste Remembers Layers, turn it on, I would suggest setting it as a default. (Toggle it with no documents open when you complete the current document)
    Best i can do, post a new Topic if you get stuck.
    I'll take you up on that pint if I get a chance, but being from the States, I'm used to a slightly weaker draft.
