Coldfusion 10 IIS (Windows 7) to process .htm
May 18, 2012 May 18, 2012
I Think I have the correct stuff done in the C:\ColdFusion10\cfusion\wwwroot\WEB-INF\web.xml  ..
added the following lines...
<servlet-mapping id="coldfusion_mapping_16">
  <servlet-name>CfmServlet</servlet-name>
  <url-pattern>*.htm</url-pattern>
</servlet-mapping>
<servlet-mapping id="coldfusion_mapping_17">
  <url-pattern>*.htm/*</url-pattern>
</servlet-mapping>
I went to the IIS Manager and the Handler Mappings screen and added a Script Map for *.htm
executiable C:\ColdFusion10\config\wsconfig\2\isapi_redirect.dll .  At first I was getting a 500 error.
Restarted machine and I just get a blank page with going to a htm page.
Any suggestions?
2.6K
May 21, 2012 May 21, 2012
Did you find an answer to this? What web server are you using?
I see the web server WIndows 7. DId you get this working?
May 24, 2012 May 24, 2012
No I have not.
May 25, 2012 May 25, 2012
I have this same issue.  If someone finds the solution please post to this thread.  I just get a blank page.
Adobe Employee ,
Jun 12, 2012 Jun 12, 2012
Remove the "htm" mapping from IIS handler mapping and web.xml.
Save the file
Re-start IIS and CF
Access the test.htm page and it would work for you.
IIS handles html/htm extension files by default. If you go to your IIS handler mappings, we don't see any html mapping, if we keep a test.html page on IIS webroot, still ISS processes it.
HTH.
Rg,
Spsb
The solution from spsb84 does not work.  It serves the htm files, but does NOT process the ColdFusion code in the files.  It just serves HTML and ignores the ColdFusion.
This solution works for me... http://www.webtrenches.com/post.cfm/processing-html-htm-or-other-files-in-coldfusion-10
Adobe Employee ,
Hi tSpark,
The post was updated as per the "execution of htm pages by IIS".
We tested by just creating a test htm page {with dummy data and no CF code}, placing it on IIS and executing it.
But, if it is related to CF code in htm page and the link-->http://www.webtrenches.com/post.cfm/processing-html-htm-or-other-files-in-coldfusion-10 serves good, then, thanks!!!
Rg,
Spsb
Documentation
