hi,
this is turning into a nightmare. cannot install cs6.
sys: i7 / 920 / 12gb ram / gtx 550ti (always current drivers) / bm intensity pro - win7 / sp1 / 64bit
ran setup
all seemed ok till asked to insert 2nd disk. at which point error message said to restart and try again.
on second try there was no longer any cs6 folder on the first disk just the following folders:
cs6 speech anal models
encore cs6 functional content
premiere cs6 functional content.
tried installing direct from the premiere folder set up and received the following error message:
Exit Code: 7
Please see specific errors and warnings below for troubleshooting. For example, ERROR: DW050, DW062 ...
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 2 error(s), 0 warning(s)
----------- Payload: {614020C8-2E16-4E16-A5F0-04DE2AB96097} Adobe Premiere Pro CS6 Functional Content 6.0.0.0 -----------
ERROR: DW062: Unable to locate folder for token SharedDocuments
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Adobe Premiere Pro CS6 Functional Content: Install failed
tried a couple more times - same result. what's going on!?
thanks
5th try:
Exit Code: 7
- 0 fatal error(s), 72 error(s), 0 warning(s)
----------- Payload: {DE88AA40-6766-43D3-A755-8FC374B3D2C3} DynamiclinkSupport 6.0.0.0 -----------
----------- Payload: {539AEF15-3A2B-4A31-A587-7E90F7D9C700} Camera Profiles Installer 7.0.0.0 -----------
----------- Payload: {8706963D-5F48-47CC-998B-DAB70B089DB8} Suite Shared Configuration CS6 3.0.0.0 -----------
ERROR: DW050: - Adobe Bridge CS6 (64 Bit): Install failed
ERROR: DW050: - AdobeColorVideoProfilesAE CS6: Install failed
ERROR: DW050: - Dynamic Link Media Server: Install failed
ERROR: DW050: - CS6 Production Premium: Install failed
ERROR: DW050: - Adobe XMP Panels: Install failed
ERROR: DW050: - AdobeColorCommonSetCMYK CS6: Install failed
ERROR: DW050: - AdobeColorEU CS6: Install failed
ERROR: DW050: - Adobe Encore CS6_AdobeEncore6en_USLanguagePack: Install failed
ERROR: DW050: - SonicWrappers_ph: Install failed
ERROR: DW050: - Adobe Flash CS6_AdobeFlash12.0-en_USLanguagePack: Install failed
ERROR: DW050: - Adobe Prelude CS6 Support: Install failed
ERROR: DW050: - Adobe Photoshop CS6 Support: Install failed
ERROR: DW050: - AdobePDFL x64 CS6: Install failed
ERROR: DW050: - AdobeColorJA CS6: Install failed
ERROR: DW050: - Adobe Hunspell Linguistics Plugin CS6 x64: Install failed
ERROR: DW050: - SonicWrappers_bl: Install failed
ERROR: DW050: - Adobe Audition: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe Photoshop CS6 Core_x64: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe Player for Embedding 3.3: Install failed
ERROR: DW050: - Adobe CSXS Infrastructure CS6: Install failed
ERROR: DW050: - Adobe SpeedGrade CS6: Failed due to Language Pack installation failure
ERROR: DW050: - AdobeColorNA CS6: Install failed
ERROR: DW050: - Adobe Premiere Pro CS6: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe Prelude CS6_AdobePrelude1en_USLanguagePack: Install failed
ERROR: DW050: - Adobe Encore CS6: Failed due to Language Pack installation failure
ERROR: DW050: - AdobeMotionPicture CS6: Install failed
ERROR: DW050: - Adobe After Effects CS6: Failed due to Language Pack installation failure
ERROR: DW050: - AdobeColorPhotoshop CS6: Install failed
ERROR: DW050: - Adobe Flash CS6: Failed due to Language Pack installation failure
ERROR: DW050: - Camera Profiles Installer: Install failed
ERROR: DW050: - AdobePDFL CS6: Install failed
ERROR: DW050: - Photoshop Camera Raw 7 (64 bit): Install failed
ERROR: DW050: - Adobe SpeedGrade CS6_AdobeSpeedGrade6.0en_USLanguagePack: Install failed
ERROR: DW050: - Required Common Fonts Installation x64: Install failed
ERROR: DW050: - AdobeColorVideoProfilesCS CS6: Install failed
ERROR: DW050: - Adobe WinSoft Linguistics Plugin CS6 x64: Install failed
ERROR: DW050: - PDF Settings CS6: Install failed
ERROR: DW050: - Recommended Common Fonts Installation x64: Install failed
ERROR: DW050: - Adobe Extension Manager CS6: Install failed
ERROR: DW050: - Suite Shared Configuration CS6: Install failed
ERROR: DW050: - Adobe Player for Embedding x64 3.3: Install failed
ERROR: DW050: - Adobe WinSoft Linguistics Plugin CS6: Install failed
ERROR: DW050: - Adobe Bridge CS6: Install failed
ERROR: DW050: - Adobe After Effects CS6 Support: Install failed
ERROR: DW050: - AdobeCMaps x64 CS6: Install failed
ERROR: DW050: - Microsoft Visual C++ 2005 Redistributable Package (x64): Install failed
ERROR: DW050: - AdobeTypeSupport CS6: Install failed
ERROR: DW050: - Adobe Audition_AdobeAudition5en_USLanguagePack: Install failed
ERROR: DW050: - AdobeTypeSupport x64 CS6: Install failed
ERROR: DW050: - Adobe Mini Bridge CS6: Install failed
ERROR: DW050: - Adobe Linguistics CS6 x64: Install failed
ERROR: DW050: - AmericanEnglishSpeechAnalysisModels: Install failed
ERROR: DW050: - AdobeColorCommonSetRGB CS6: Install failed
ERROR: DW050: - Adobe Premiere Pro CS6 Support: Install failed
ERROR: DW050: - Adobe SwitchBoard 2.0: Install failed
ERROR: DW050: - Photoshop Camera Raw 7: Install failed
ERROR: DW050: - Adobe Premiere Pro CS6_AdobePremierePro6.0en_USLanguagePack: Install failed
ERROR: DW050: - AdobeHelp: Install failed
ERROR: DW050: - Adobe After Effects CS6_AdobeAfterEffects11en_USLanguagePack: Install failed
ERROR: DW050: - Adobe Encore CS6 Support: Install failed
ERROR: DW050: - Adobe Linguistics CS6: Install failed
ERROR: DW050: - DynamiclinkSupport: Install failed
ERROR: DW050: - Adobe Prelude CS6: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe Photoshop CS6 International English Language Pack_x64_AdobePhotoshop13-en_GB_x64: Install failed
ERROR: DW050: - Adobe After Effects CS6 Presets: Install failed
ERROR: DW050: - AdobeCMaps CS6: Install failed
ERROR: DW050: - Adobe CSXS Extensions CS6: Install failed
ERROR: DW050: - Adobe ExtendScript Toolkit CS6: Install failed
ERROR: DW050: - Adobe Media Encoder CS6 X64: Install failed
System Requirements
getting to be beyond a joke ;-( at least vegas loads!
