Eagle James
Word Text Boxes
May 18, 2012 10:52 PM
When converting a Word doc to a PDF, the text boxes with the text do not appear on the PDF.
    May 19, 2012 5:32 AM   in reply to Eagle James
    How do you convert? Do you use PDFMaker (Acrobat Addin/Tab) or Adobe PDF printer?
    Would you be willing to share any sample form with us? I can possibly let you know what exactly needs to be done.
    ~Sandeep V.
    May 19, 2012 1:19 PM   in reply to Eagle James
    I will guess that the graphics are there, but you are seeing a blank place holder. In that case, go to the preferences and set the display to show smoothing for both graphics and fonts as well as display large images.
    May 20, 2012 6:48 AM   in reply to Eagle James
    You mentioned Office 2010 does not support PDFmaker? Are you using Acrobat 9? For Acrobat X is compatible with 32 Office 2010.
    What are formats of the images inserted in word doc? PDF printer generally takes everything into account and shows that in PDF. Is there a sample word doc to try?
    ~Sandeep V.
    May 20, 2012 9:56 AM   in reply to Eagle James
    yeah.that's true. Acrobat 9's PDFMaker is not compatible with Office 2010. Could you check if there is an issue with a particular type of image format? I suspect PNG for they carry transparency and Bill@VT has a valid point. Put 3 different formats of images with same property and then check.
    Can't really touch the base till i try a sample document.
    May 21, 2012 11:49 AM   in reply to Eagle James
    I am sorry but i couldn't find any attachment.. ? Seems like an issue with the transparency.
