how can i reduce color predominance/dominance?
May 20, 2012 2:36 AM
Hi
is there a way to reduce or remove color (or a range of color) predominance/dominance?
i did a search for a video on youtube , and i didn't find it
i tried with the eyedropper to select a color , solid color ,blend exclusion but nothing
thanks
cheers
    May 20, 2012 3:23 AM   in reply to mantralightroom
    Unless you are talking about an overall color cast, which should be corrected at a more fundamental level using Curves or Levels, I feel the best tool for this is Selective Color.
    The other option is Hue/Saturation, but Selective Color has the huge advantage that it does not break up image integrity into pixelized or posterized zones. The downside is that the effects are more subtle, so the image must be "ballpark" right to begin with.
    To get the most out of Selective Color you need to understand how the color wheel works and what complementary colors are. For instance, to reduce the intensity of red you increase cyan %. Another way to look at it is to think of it as a CMYK tool (although it works just as well in RGB).
  • Noel Carboni
    Dec 23, 2006
    May 20, 2012 7:34 AM   in reply to mantralightroom
    It might help if you would describe your workflow a bit...
    For example, if you're opening raw files, the best answer is to get the color temperature and tint right during the raw conversion.  One way to do that is to use the white balance dropper and click on something that's supposed to be neutral gray/white, but which has a color cast.
    Another example, that's somewhat similar, if you've already opened a photo into Photoshop proper, is to do a Curves operation, press the Gray Point dropper icon, and click on something in the image that's supposed to be neutral gray/white.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 20, 2012 1:08 PM   in reply to mantralightroom
    Click on any object that's supposed to be neutral colored, but which is showing a color cast.
    See what sampling that color has done to the Temperature and Tint fields?
    No go try the things you have read here, and you'll see how they can work in your situation.  Nothing says you have to pick perfectly the first time.  Click on things until you like the color you see.
    -Noel
