I'm in the midst of adding a performance monitor to a mobile application that has no actionscript yet, I just want to test performance of animations
https://raw.github.com/mrdoob/Hi-ReS-Stats/master/src/net/hires/debug/ Stats.as that is the stats.as file I have in my root folder with the .fla
I removed the folder location "net.hires.debug" from the stats.as file
what do i need to type to load the .as file
it says to use the addchild function, I'm new to as3 and am a bit confused with classes
right now my first frame actions layer, it says
addChild (new Stats() );
and when executing this
addChild(new Stats()); it gives me error 1180: call to a possible undefined method Stats
Is the file named "stats.as" or "Stats.as" (you show it both ways)? It needs to be named Stats.as
well the downloaded file has a lowercase s for stats.as and inside the stats.as file it defines a class called Stats which i called upon as addChild(new Stats()); the actionscript window popus up as I'm typing and autofills it as Stats so i know it is properly defined.. eithor way im still getting the same error message
Scratch that, I'm an idiot.. Thanks allot, are you on these forums 24/7?? lol thank god
You're welcome... not 24/7, but I visit when I have time
