I have a Macbook Pro. All available updates from Apple. Any advise please
We had the same error with CS6. It did turn out to be a permissions error, which we discovered by looking at the installer log from within the installer program (while it was trying to install, rather than the one it spits out after it's done). That live log showed a number of sudo errors, even though root was enabled. When we tried to just run a sudo command at the terminal window and got a sudoers permission error which led us to this discussion board:
https://discussions.apple.com/thread/3680870?start=0&tstart=0
...Copy link to clipboard
What is the exact error you are getting? Also install logs will help.
Mylenium
[ 0] Sat May 5 20:14:15 2012 INFO
Visit http://www.adobe.com/go/loganalyzer/ for more information
START - Installer Session
RIBS version: 4.0.50.0
OSX version: 10.7.3
::START TIMER:: [Total Timer]
CHECK: Single instance running
CHECK : Credentials
Load Deployment File
Create Required Folders
Assuming install mode
::START TIMER:: [Bootstrap]
Perform Bootstrapping ...
:: END TIMER :: [Bootstrap] took 7124 milliseconds (7.124 seconds) DTR = 3.93038 KBPS (0.00383826 MBPS)
Looking up install source path
Sync Media DB ...
::START TIMER:: [Sync Media DB]
Pre check media db sync
End of Pre check media db sync. Exit code: 0
:: END TIMER :: [Sync Media DB] took 11625 milliseconds (11.625 seconds) DTR = 1808.52 KBPS (1.76613 MBPS)
Ready to initialize session to start with ...
::START TIMER:: [CreatePayloadSession]
-------------------- BEGIN - Updating Media Sources - BEGIN --------------------
Updated source path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard
Updating media info for: {007A2A28-D6A8-4D91-9A2B-568FF8052215}
Type: 1, Volume Order: 1, Media Name: CS5_5 Design Std 1
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeWinSoftLinguisticsPluginAll/AdobeWinSoftLinguisticsPluginAll.dmg
Updating media info for: {0175676F-8C92-49F2-9131-D0D6AD654B41}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeHelp/InstallAdobeHelp
Updating media info for: {03FB981A-5170-11E0-A90E-3CEDE2AB3DC5}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeInDesign7xAppBase2-mul/AdobeInDesign7xAppBase2-mul.dmg
Updating media info for: {08EF22BC-43B2-4B4E-BA12-52B18F418F38}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobePhotoshop12-Core/AdobePhotoshop12-Core.dmg
Updating media info for: {0AA9D11A-227D-45AB-A5D5-6F5F6E81D5E3}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeAPE3.101-mul/AdobeAPE3.101-mul.dmg
Updating media info for: {0CCF0458-5171-11E0-BC45-DC59E3AB3DC5}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeInDesign7xAppBase-mul/AdobeInDesign7xAppBase-mul.dmg
Updating media info for: {0D96CFE6-376D-44B8-808A-16F3BEB73263}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AMECore5.5All/AMECore5.5All.dmg
Updating media info for: {11E1188F-E576-47BC-B215-600C02C7EABF}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeColorNA_Recommended3_1-mul/AdobeColorNA_Recommended3_1-mul.dmg
Updating media info for: {1A1E5FF9-D0FD-42A3-8E18-E5E7E95E1AB4}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeDynamiclinkSupport5.5All/AdobeDynamiclinkSupport5.5All.dmg
Updating media info for: {1FEB691B-39ED-4343-99D6-CACDAD879D8C}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobePhotoshop12-en_GB/AdobePhotoshop12-en_GB.dmg
Updating media info for: {22C26C10-5C22-4674-A52C-100112664305}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/DeviceCentral3.5LP-en_US/DeviceCentral3.5LP-en_US.dmg
Updating media info for: {270C312D-7EC7-474C-BEB2-79CD398E02A3}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/HIL_Help_Search/HIL_Help_Search.dmg
Updating media info for: {3019BB9E-516F-11E0-AAAB-3AEBE2AB3DC5}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeInDesign7xCommonLang-en_GB/AdobeInDesign7xCommonLang-en_GB.dmg
Updating media info for: {3450d4c5-a82b-4428-a512-842ee1555a14}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeStoryExtension-mul/AdobeStoryExtension-mul.dmg
Updating media info for: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeCameraRaw6.0All/AdobeCameraRaw6.0All.dmg
Updating media info for: {3F023875-4A52-4605-9DB6-A88D4A813E8D}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeCameraRawProfile6.0All/AdobeCameraRawProfile6.0All.dmg
Updating media info for: {4058E728-84D8-45CE-8E2D-5F35BD6659A1}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeExtensionManager5.5All/AdobeExtensionManager5.5All.dmg
Updating media info for: {419B81A0-6282-456C-9B1E-8DBABA0DE2DC}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeWinSoftLinguisticsPlugin_3_5_All/AdobeWinSoftLinguisticsPlugin_3_5_All.dmg
Updating media info for: {45063C56-A2A2-4FD1-A56A-A964723EEE1E}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeColorCommonSetRGB3_1-mul/AdobeColorCommonSetRGB3_1-mul.dmg
Updating media info for: {4603E0C5-6880-4A4F-BCF8-DF1F6AE0E317}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeColorPhotoshop3_1-mul/AdobeColorPhotoshop3_1-mul.dmg
Updating media info for: {49E6D00F-3456-11E0-AE83-842B2B67A8CC}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeDeviceCentral3.5-all/AdobeDeviceCentral3.5-all.dmg
Updating media info for: {4A8546D0-CEDF-48C1-9BA1-DD5B4ADFC154}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeMiniBridge1.1-mul/AdobeMiniBridge1.1-mul.dmg
Updating media info for: {4B204697-D302-42D9-94B4-8BDDE6DD359C}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeReviewPanelCS-mul/AdobeReviewPanelCS-mul.dmg
Updating media info for: {4C08199E-0D93-4227-8325-F024E71CA7A1}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeSING3-mul/AdobeSING3-mul.dmg
Updating media info for: {4FFA83C0-007A-4DB3-955C-B5EEE73BEDAF}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/SwitchBoard2.0All/SwitchBoard2.0All.dmg
Updating media info for: {54D89F03-8EED-4FF9-BCDF-3B2E11D448A6}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeColorCommonSetCMYK3_1-mul/AdobeColorCommonSetCMYK3_1-mul.dmg
Updating media info for: {5C0FEBDA-5A0E-4FC8-91CB-229A4C1561E9}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeXMPPanelsAll-081210014320/AdobeXMPPanelsAll-081210014320.dmg
Updating media info for: {62ED7AE1-01FA-4066-97B7-1CD93A68DD0D}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeHunspellPluginAll/AdobeHunspellPluginAll.dmg
Updating media info for: {6A2E619B-E4AC-433B-A648-D458CE543A96}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeXMPPanelsAll/AdobeXMPPanelsAll.dmg
Updating media info for: {6C8DB10F-B997-4F24-B081-7BD4313CDBAA}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeIllustrator15_1en_GBLanguagePack/AdobeIllustrator15_1en_GBLanguagePack.dmg
Updating media info for: {6F3A624B-1B72-4081-96E8-23261F389C5C}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeTypeSupport10-mul/AdobeTypeSupport10-mul.dmg
Updating media info for: {71BC8278-815D-4F8C-8FA5-C6F782C73892}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeCSXSInfrastructure2.5-mul/AdobeCSXSInfrastructure2.5-mul.dmg
Updating media info for: {75CD59C0-516F-11E0-892C-26ECE2AB3DC5}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeInDesign7xCommonLang-en_US/AdobeInDesign7xCommonLang-en_US.dmg
Updating media info for: {78E6AED6-9091-425A-A2F6-47D15A2D845D}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeDesignStandard5.5-mul/AdobeDesignStandard5.5-mul.dmg
Updating media info for: {7D676EF8-BB79-4741-B799-36F3F1F8DCCB}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeColorEU_Recommended3_1-mul/AdobeColorEU_Recommended3_1-mul.dmg
Updating media info for: {83478D6E-4AA8-11E0-A479-24B1F9D7AC32}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeContentViewer-mul/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
Updating media info for: {8B4C951B-F853-4B05-B892-9D5B3CD8AC98}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobePDFSettings10-ja_JP/AdobePDFSettings10-ja_JP.dmg
Updating media info for: {93D13A00-516E-11E0-97B7-E4DEE2AB3DC5}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeInDesign7xAppLang-en_GB/AdobeInDesign7xAppLang-en_GB.dmg
Updating media info for: {99BDA97A-4AA8-11E0-9E8D-32B2F9D7AC32}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeDigitalPublishing-mul/AdobeDigitalPublishing-mul.dmg
Updating media info for: {9BA136BE-0077-41E1-AD56-56AB5D4A1A67}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeExtendScriptToolkit3.6.0-mul/AdobeExtendScriptToolkit3.6.0-mul.dmg
Updating media info for: {9F747BEC-FB4E-4830-8C58-363B8DCC26EB}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeIllustrator15_1en_USLanguagePack/AdobeIllustrator15_1en_USLanguagePack.dmg
Updating media info for: {A1181890-9FA4-11DF-A25D-A35DF04EC7B1}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeToolhints-mul/AdobeToolhints-mul.dmg
Updating media info for: {A189C479-C7CD-4E08-8CCF-D999B68C0C71}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeCameraRawProfile6.0All-181110110333/AdobeCameraRawProfile6.0All-181110110333.dmg
Updating media info for: {A2502D10-2D75-4620-8A8B-73F39D5C1243}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobePDFSettings10-mul/AdobePDFSettings10-mul.dmg
Updating media info for: {A44863BF-8DB8-4D22-88DB-5A02BE319840}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeLinguisticsAll/AdobeLinguisticsAll.dmg
Updating media info for: {A516708E-EC03-40F5-B82E-0851A44B3780}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeIllustrator15_1-mul/AdobeIllustrator15_1-mul.dmg
Updating media info for: {A80C015C-1939-42A5-AD2F-E76C7F194505}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeColorJA_ExtraSettings3_1-mul/AdobeColorJA_ExtraSettings3_1-mul.dmg
Updating media info for: {AC003BC0-704F-4F02-A72E-AC8B7044DE24}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeOutputModuleAll/AdobeOutputModuleAll.dmg
Updating media info for: {AC76BA86-1033-F400-7760-000000000005}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AcrobatProfessional10.0-EFG/Adobe Acrobat X Pro Installer.pkg
Updating media info for: {B5E12198-2A83-436B-AE2F-1F7BF65D2C14}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeColorJA_Recommended3_1-mul/AdobeColorJA_Recommended3_1-mul.dmg
Updating media info for: {BAE5212B-6651-4AD8-B26A-1B284D2665C6}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobePDFL9.9-mul/AdobePDFL9.9-mul.dmg
Updating media info for: {BD0D6363-E961-410F-8BF4-ECD8795F3923}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeCMaps3-mul/AdobeCMaps3-mul.dmg
Updating media info for: {BD85DFD4-005F-4219-8E27-C922CC4D8A61}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeCSXSExtensions2.5-mul/AdobeCSXSExtensions2.5-mul.dmg
Updating media info for: {C1646326-4AA6-11E0-AE8E-4C9CF9D7AC32}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeDigitalPublishingAppLang-en_US/AdobeDigitalPublishingAppLang-en_US.dmg
Updating media info for: {CBDD7465-CE11-4A58-9497-C370B65923F1}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeFontsRequired-mul/AdobeFontsRequired-mul.dmg
Updating media info for: {CE6E1448-516F-11E0-B3C0-13EDE2AB3DC5}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeInDesign7xAppFSet-Roman/AdobeInDesign7xAppFSet-Roman.dmg
Updating media info for: {D682C558-6F3F-4800-885C-4C5EB1B7338C}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeBuzzword-mul/AdobeBuzzword-mul.dmg
Updating media info for: {D8B9B5FB-D388-4D79-AA4B-6C09641189F6}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeUtilities3.1-mul/AdobeUtilities3.1-mul.dmg
Updating media info for: {DD18D60C-87B1-47D9-8312-67508B402FB9}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/SiteCatalystNetAverages2-mul/SiteCatalystNetAverages2-mul.dmg
Updating media info for: {E39A5ABD-516B-46F9-A042-694BBA6A4E08}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeFontsRecommended-mul/AdobeFontsRecommended-mul.dmg
Updating media info for: {E3EE510E-4AA6-11E0-A977-0A9EF9D7AC32}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeDigitalPublishingAppLang-en_GB/AdobeDigitalPublishingAppLang-en_GB.dmg
Updating media info for: {E471A41E-852F-4A85-AA74-5B82AB81C615}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeColorNA_ExtraSettings3_1-mul/AdobeColorNA_ExtraSettings3_1-mul.dmg
Updating media info for: {EB186BF2-0A84-40A2-B794-0326D3DF9973}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeVideoProfilesCS3_1-mul/AdobeVideoProfilesCS3_1-mul.dmg
Updating media info for: {ED28819E-310F-4F17-925C-C69B0A1C1F7F}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeSuiteSharedConfiguration-mul/AdobeSuiteSharedConfiguration-mul.dmg
Updating media info for: {ED9DC850-516E-11E0-9096-1FE5E2AB3DC5}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeInDesign7xAppLang-en_US/AdobeInDesign7xAppLang-en_US.dmg
Updating media info for: {EDE888ED-3BD7-4D8C-AB35-7E4C661A94D9}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobePhotoshop12-en_US/AdobePhotoshop12-en_US.dmg
Updating media info for: {EE85C227-0148-4825-B659-6A1E142571EE}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeBridge4.1-mul/AdobeBridge4.1-mul.dmg
Updating media info for: {EF45880C-DD84-46C3-A054-0BC5F76A6BBE}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobePhotoshop12-Support/AdobePhotoshop12-Support.dmg
Updating media info for: {F313167E-5172-11E0-ACE7-30C2E3AB3DC5}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeInDesign7xCommonBase-mul/AdobeInDesign7xCommonBase-mul.dmg
Updating media info for: {F8ABD584-A99C-4304-AC4B-CCFD0914D871}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeLinguistics_3_5_All/AdobeLinguistics_3_5_All.dmg
Updating media info for: {FD58D99B-9927-4226-8E00-959A4F76BD89}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeCameraRaw6.0All-181110110248/AdobeCameraRaw6.0All-181110110248.dmg
Updating media info for: {FECCB1BF-038D-41C2-861B-4560E7667005}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeColorEU_ExtraSettings3_1-mul/AdobeColorEU_ExtraSettings3_1-mul.dmg
Updating media info for: {FFC07452-6E0A-47A6-86E2-E18C9A992E7B}
Path: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/DeviceCentral3.5LP-en_GB/DeviceCentral3.5LP-en_GB.dmg
-------------------- END - Updating Media Sources - END --------------------
Supported RIBS version range: [0.0.66.0,4.0.50.0]
----------------- CreatePayloadSession: machine is x86 ---------------
______ Verify Dependency Subscribers ______
BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
{0AA9D11A-227D-45AB-A5D5-6F5F6E81D5E3} Adobe Player for Embedding 3.1 3.101.0.0: 1 (0,6)
{D8B9B5FB-D388-4D79-AA4B-6C09641189F6} Adobe Utilities CS5.5 3.1.0.0: 2 (0,3)
{3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.0.0: 3 (0,4)
{A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All 6.3.0.0: 4 (0,0)
{ED28819E-310F-4F17-925C-C69B0A1C1F7F} Suite Shared Configuration CS5.5 2.5.0.0: 5 (0,5)
{BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 3.0.0.0: 6 (0,4)
{AC003BC0-704F-4F02-A72E-AC8B7044DE24} AdobeOutputModule 3.1.0.0: 6 (0,4)
{BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 9.9.0.0: 6 (0,4)
{6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 10.0.0.0: 6 (0,4)
{4FFA83C0-007A-4DB3-955C-B5EEE73BEDAF} Adobe SwitchBoard 2.0 2.0.0.0: 7 (0,3)
{1A1E5FF9-D0FD-42A3-8E18-E5E7E95E1AB4} DynamiclinkSupport 5.5.0.0: 8 (0,2)
{0175676F-8C92-49F2-9131-D0D6AD654B41} AdobeHelp 3.4.0.0: 9 (0,5)
{71BC8278-815D-4F8C-8FA5-C6F782C73892} Adobe CSXS Infrastructure CS5.5 2.5.0.0: 10 (0,4)
{4058E728-84D8-45CE-8E2D-5F35BD6659A1} Adobe Extension Manager CS5.5 5.5.0.0: 10 (0,4)
{6A2E619B-E4AC-433B-A648-D458CE543A96} Adobe XMP Panels CS5 3.0.0.0: 10 (0,4)
{5C0FEBDA-5A0E-4FC8-91CB-229A4C1561E9} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll 3.1.0.0: 11 (0,0)
{9BA136BE-0077-41E1-AD56-56AB5D4A1A67} Adobe ExtendScript Toolkit CS5.5 3.6.0.0: 12 (2,4)
{37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw 6.0.0.0: 13 (1,3)
{FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All 6.3.0.0: 14 (0,0)
{54D89F03-8EED-4FF9-BCDF-3B2E11D448A6} AdobeColorCommonSetCMYK 3.1.0.0: 15 (0,3)
{45063C56-A2A2-4FD1-A56A-A964723EEE1E} AdobeColorCommonSetRGB 3.1.0.0: 15 (0,3)
{7D676EF8-BB79-4741-B799-36F3F1F8DCCB} AdobeColorEU CS5.5 3.1.0.0: 15 (0,3)
{FECCB1BF-038D-41C2-861B-4560E7667005} AdobeColorEU CS5.5 3.1.0.0: 15 (0,3)
{A80C015C-1939-42A5-AD2F-E76C7F194505} AdobeColorJA CS5.5 3.1.0.0: 15 (0,3)
{B5E12198-2A83-436B-AE2F-1F7BF65D2C14} AdobeColorJA CS5.5 3.1.0.0: 15 (0,3)
{11E1188F-E576-47BC-B215-600C02C7EABF} AdobeColorNA CS5.5 3.1.0.0: 15 (0,3)
{E471A41E-852F-4A85-AA74-5B82AB81C615} AdobeColorNA CS5.5 3.1.0.0: 15 (0,3)
{007A2A28-D6A8-4D91-9A2B-568FF8052215} Adobe WinSoft Linguistics Plugin CS5 1.2.0.0: 16 (0,2)
{03FB981A-5170-11E0-A90E-3CEDE2AB3DC5} Adobe InDesign CS5.5 Application Base Files2 7.5.0.0: 17 (0,1)
{CE6E1448-516F-11E0-B3C0-13EDE2AB3DC5} Adobe InDesign CS5.5 Application Feature Set Files 7.5.0.0: 17 (0,1)
{F313167E-5172-11E0-ACE7-30C2E3AB3DC5} Adobe InDesign CS5.5 Common Base Files 7.5.0.0: 17 (0,1)
{EF45880C-DD84-46C3-A054-0BC5F76A6BBE} Adobe Photoshop CS5.1 Support 12.1.0.0: 17 (0,1)
{BD85DFD4-005F-4219-8E27-C922CC4D8A61} Adobe CSXS Extensions CS5.5 2.5.0.0: 18 (0,3)
{4B204697-D302-42D9-94B4-8BDDE6DD359C} Adobe ReviewPanel CS5.5 3.0.0.0: 18 (0,3)
{8B4C951B-F853-4B05-B892-9D5B3CD8AC98} PDF Settings CS5 10.0.0.0: 18 (0,3)
{A2502D10-2D75-4620-8A8B-73F39D5C1243} PDF Settings CS5 10.0.0.0: 18 (0,3)
{E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation 1.0.0.0: 18 (0,3)
{CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation 1.0.0.0: 18 (0,3)
{EE85C227-0148-4825-B659-6A1E142571EE} Adobe Bridge CS5.1 4.1.0.0: 19 (12,3)
{A44863BF-8DB8-4D22-88DB-5A02BE319840} Adobe Linguistics CS5 5.0.0.0: 20 (0,2)
{3450d4c5-a82b-4428-a512-842ee1555a14} CSXS Story Extension 2.5.0.0: 20 (0,2)
{270C312D-7EC7-474C-BEB2-79CD398E02A3} HIL Help Search 1.0.0.0: 20 (0,2)
{DD18D60C-87B1-47D9-8312-67508B402FB9} SiteCatalyst NetAverages CS5.5 2.0.0.0: 20 (0,2)
{4A8546D0-CEDF-48C1-9BA1-DD5B4ADFC154} Adobe Mini Bridge CS5.1 1.1.0.0: 21 (1,2)
{49E6D00F-3456-11E0-AE83-842B2B67A8CC} Adobe Device Central CS5.5 3.5.0.0: 22 (3,2)
{FFC07452-6E0A-47A6-86E2-E18C9A992E7B} Adobe Device Central CS5.5_DeviceCentral3.5LP-en_GB 3.5.0.0: 23 (0,0)
{22C26C10-5C22-4674-A52C-100112664305} Adobe Device Central CS5.5_DeviceCentral3.5LP-en_US 3.5.0.0: 23 (0,0)
{D682C558-6F3F-4800-885C-4C5EB1B7338C} Adobe Buzzword CS5.5 1.0.0.0: 24 (0,1)
{83478D6E-4AA8-11E0-A479-24B1F9D7AC32} Adobe Content Viewer 1.0.0.0: 24 (0,1)
{62ED7AE1-01FA-4066-97B7-1CD93A68DD0D} Adobe Hunspell Linguistics Plugin CS5.5 1.0.0.0: 24 (0,1)
{F8ABD584-A99C-4304-AC4B-CCFD0914D871} Adobe Linguistics CS5.5 5.5.0.0: 24 (0,1)
{4C08199E-0D93-4227-8325-F024E71CA7A1} Adobe SING CS5 3.0.0.0: 24 (0,1)
{A1181890-9FA4-11DF-A25D-A35DF04EC7B1} Adobe Toolhints CS5.5 1.5.0.0: 24 (0,1)
{419B81A0-6282-456C-9B1E-8DBABA0DE2DC} Adobe WinSoft Linguistics Plugin CS5.5 1.2.0.0: 24 (0,1)
{4603E0C5-6880-4A4F-BCF8-DF1F6AE0E317} AdobeColorPhotoshop CS5.5 3.1.0.0: 24 (0,1)
{EB186BF2-0A84-40A2-B794-0326D3DF9973} AdobeColorVideoProfilesCS CS5.5 3.1.0.0: 24 (0,1)
{99BDA97A-4AA8-11E0-9E8D-32B2F9D7AC32} Digital Publishing 1.0.0.0: 24 (0,1)
{E3EE510E-4AA6-11E0-A977-0A9EF9D7AC32} Adobe Digital Publishing Application Language Files_AdobeDigitalPublishingAppLang-en_GB 1.0.0.0: 25 (0,0)
{C1646326-4AA6-11E0-AE8E-4C9CF9D7AC32} Adobe Digital Publishing Application Language Files_AdobeDigitalPublishingAppLang-en_US 1.0.0.0: 25 (0,0)
{0D96CFE6-376D-44B8-808A-16F3BEB73263} Adobe Media Encoder CS5.5 5.5.0.0: 26 (1,1)
{AC76BA86-1033-F400-7760-000000000005} Acrobat Professional 10.0.0.0: 27 (0,0)
{78E6AED6-9091-425A-A2F6-47D15A2D845D} Creative Suite 5.5 Design Standard 5.5.0.0: 28 (1,0)
{A516708E-EC03-40F5-B82E-0851A44B3780} Adobe Illustrator CS5.1 15.1.0.0: 29 (32,0)
{9F747BEC-FB4E-4830-8C58-363B8DCC26EB} Adobe Illustrator CS5.1_AdobeIllustrator15_1en_USLanguagePack 15.1.0.0: 30 (0,0)
{6C8DB10F-B997-4F24-B081-7BD4313CDBAA} Adobe Illustrator CS5.1_AdobeIllustrator15_1en_GBLanguagePack 15.1.0.0: 30 (0,0)
{08EF22BC-43B2-4B4E-BA12-52B18F418F38} Adobe Photoshop CS5.1 Core 12.1.0.0: 31 (37,0)
{1FEB691B-39ED-4343-99D6-CACDAD879D8C} Adobe Photoshop CS5.1 International English Language Pack_AdobePhotoshop12-en_GB 12.1.0.0: 32 (0,0)
{EDE888ED-3BD7-4D8C-AB35-7E4C661A94D9} Adobe Photoshop CS5.1 English Language Pack_AdobePhotoshop12-en_US 12.1.0.0: 32 (0,0)
{0CCF0458-5171-11E0-BC45-DC59E3AB3DC5} Adobe InDesign CS5.5 Application Base Files 7.5.0.0: 33 (47,0)
{ED9DC850-516E-11E0-9096-1FE5E2AB3DC5} Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-en_US 7.5.0.0: 34 (0,0)
{3019BB9E-516F-11E0-AAAB-3AEBE2AB3DC5} Adobe InDesign CS5.5 Common Language Files_AdobeInDesign7xCommonLang-en_GB 7.5.0.0: 34 (0,0)
{93D13A00-516E-11E0-97B7-E4DEE2AB3DC5} Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-en_GB 7.5.0.0: 34 (0,0)
{75CD59C0-516F-11E0-892C-26ECE2AB3DC5} Adobe InDesign CS5.5 Common Language Files_AdobeInDesign7xCommonLang-en_US 7.5.0.0: 34 (0,0)
END Operation order for all session payloads: mediaGroup (requires,satisfies)
Setting property "INSTALLDIR" to: /Applications
Setting property "installLanguage" to: en_US
Attempting to find the selected language in the set of available payload languages
Setting property "installSourcePath" to: /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard
Overwrite property "com.Adobe.PDApp.ignore_aam" to: 1
Overwrite property "userASUPath" to: /Users/jeromy/Applications/Adobe/OOBE/PDApp
Found payload actions:
Deciding what installer mode to use...
[ 0] Sat May 5 20:14:16 2012 INFO
BEGIN Setting requested payload actions
Value returned on lookup of payload: {0AA9D11A-227D-45AB-A5D5-6F5F6E81D5E3} Adobe Player for Embedding 3.1 3.101.0.0 is: false
Action string for {0AA9D11A-227D-45AB-A5D5-6F5F6E81D5E3} Adobe Player for Embedding 3.1 3.101.0.0 is none
Value returned on lookup of payload: {D8B9B5FB-D388-4D79-AA4B-6C09641189F6} Adobe Utilities CS5.5 3.1.0.0 is: false
Action string for {D8B9B5FB-D388-4D79-AA4B-6C09641189F6} Adobe Utilities CS5.5 3.1.0.0 is none
Value returned on lookup of payload: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.0.0 is: false
Action string for {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.0.0 is none
Value returned on lookup of payload: {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All 6.3.0.0 is: false
Action string for {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All 6.3.0.0 is install
Value returned on lookup of payload: {ED28819E-310F-4F17-925C-C69B0A1C1F7F} Suite Shared Configuration CS5.5 2.5.0.0 is: false
Action string for {ED28819E-310F-4F17-925C-C69B0A1C1F7F} Suite Shared Configuration CS5.5 2.5.0.0 is none
Value returned on lookup of payload: {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 3.0.0.0 is: false
Action string for {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 3.0.0.0 is none
Value returned on lookup of payload: {AC003BC0-704F-4F02-A72E-AC8B7044DE24} AdobeOutputModule 3.1.0.0 is: false
Action string for {AC003BC0-704F-4F02-A72E-AC8B7044DE24} AdobeOutputModule 3.1.0.0 is none
Value returned on lookup of payload: {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 9.9.0.0 is: false
Action string for {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 9.9.0.0 is none
Value returned on lookup of payload: {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 10.0.0.0 is: false
Action string for {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 10.0.0.0 is none
Value returned on lookup of payload: {4FFA83C0-007A-4DB3-955C-B5EEE73BEDAF} Adobe SwitchBoard 2.0 2.0.0.0 is: false
Action string for {4FFA83C0-007A-4DB3-955C-B5EEE73BEDAF} Adobe SwitchBoard 2.0 2.0.0.0 is none
Value returned on lookup of payload: {1A1E5FF9-D0FD-42A3-8E18-E5E7E95E1AB4} DynamiclinkSupport 5.5.0.0 is: false
Action string for {1A1E5FF9-D0FD-42A3-8E18-E5E7E95E1AB4} DynamiclinkSupport 5.5.0.0 is none
Value returned on lookup of payload: {0175676F-8C92-49F2-9131-D0D6AD654B41} AdobeHelp 3.4.0.0 is: false
Action string for {0175676F-8C92-49F2-9131-D0D6AD654B41} AdobeHelp 3.4.0.0 is none
Value returned on lookup of payload: {71BC8278-815D-4F8C-8FA5-C6F782C73892} Adobe CSXS Infrastructure CS5.5 2.5.0.0 is: false
Action string for {71BC8278-815D-4F8C-8FA5-C6F782C73892} Adobe CSXS Infrastructure CS5.5 2.5.0.0 is none
Value returned on lookup of payload: {4058E728-84D8-45CE-8E2D-5F35BD6659A1} Adobe Extension Manager CS5.5 5.5.0.0 is: false
Action string for {4058E728-84D8-45CE-8E2D-5F35BD6659A1} Adobe Extension Manager CS5.5 5.5.0.0 is none
Value returned on lookup of payload: {6A2E619B-E4AC-433B-A648-D458CE543A96} Adobe XMP Panels CS5 3.0.0.0 is: false
Action string for {6A2E619B-E4AC-433B-A648-D458CE543A96} Adobe XMP Panels CS5 3.0.0.0 is none
Value returned on lookup of payload: {5C0FEBDA-5A0E-4FC8-91CB-229A4C1561E9} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll 3.1.0.0 is: false
Action string for {5C0FEBDA-5A0E-4FC8-91CB-229A4C1561E9} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll 3.1.0.0 is install
Value returned on lookup of payload: {9BA136BE-0077-41E1-AD56-56AB5D4A1A67} Adobe ExtendScript Toolkit CS5.5 3.6.0.0 is: false
Action string for {9BA136BE-0077-41E1-AD56-56AB5D4A1A67} Adobe ExtendScript Toolkit CS5.5 3.6.0.0 is none
Value returned on lookup of payload: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw 6.0.0.0 is: false
Action string for {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw 6.0.0.0 is none
Value returned on lookup of payload: {FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All 6.3.0.0 is: false
Action string for {FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All 6.3.0.0 is install
Value returned on lookup of payload: {54D89F03-8EED-4FF9-BCDF-3B2E11D448A6} AdobeColorCommonSetCMYK 3.1.0.0 is: false
Action string for {54D89F03-8EED-4FF9-BCDF-3B2E11D448A6} AdobeColorCommonSetCMYK 3.1.0.0 is none
Value returned on lookup of payload: {45063C56-A2A2-4FD1-A56A-A964723EEE1E} AdobeColorCommonSetRGB 3.1.0.0 is: false
Action string for {45063C56-A2A2-4FD1-A56A-A964723EEE1E} AdobeColorCommonSetRGB 3.1.0.0 is none
Value returned on lookup of payload: {7D676EF8-BB79-4741-B799-36F3F1F8DCCB} AdobeColorEU CS5.5 3.1.0.0 is: false
Action string for {7D676EF8-BB79-4741-B799-36F3F1F8DCCB} AdobeColorEU CS5.5 3.1.0.0 is none
Value returned on lookup of payload: {FECCB1BF-038D-41C2-861B-4560E7667005} AdobeColorEU CS5.5 3.1.0.0 is: false
Action string for {FECCB1BF-038D-41C2-861B-4560E7667005} AdobeColorEU CS5.5 3.1.0.0 is none
Value returned on lookup of payload: {A80C015C-1939-42A5-AD2F-E76C7F194505} AdobeColorJA CS5.5 3.1.0.0 is: false
Action string for {A80C015C-1939-42A5-AD2F-E76C7F194505} AdobeColorJA CS5.5 3.1.0.0 is none
Value returned on lookup of payload: {B5E12198-2A83-436B-AE2F-1F7BF65D2C14} AdobeColorJA CS5.5 3.1.0.0 is: false
Action string for {B5E12198-2A83-436B-AE2F-1F7BF65D2C14} AdobeColorJA CS5.5 3.1.0.0 is none
Value returned on lookup of payload: {11E1188F-E576-47BC-B215-600C02C7EABF} AdobeColorNA CS5.5 3.1.0.0 is: false
Action string for {11E1188F-E576-47BC-B215-600C02C7EABF} AdobeColorNA CS5.5 3.1.0.0 is none
Value returned on lookup of payload: {E471A41E-852F-4A85-AA74-5B82AB81C615} AdobeColorNA CS5.5 3.1.0.0 is: false
Action string for {E471A41E-852F-4A85-AA74-5B82AB81C615} AdobeColorNA CS5.5 3.1.0.0 is none
Value returned on lookup of payload: {007A2A28-D6A8-4D91-9A2B-568FF8052215} Adobe WinSoft Linguistics Plugin CS5 1.2.0.0 is: false
Action string for {007A2A28-D6A8-4D91-9A2B-568FF8052215} Adobe WinSoft Linguistics Plugin CS5 1.2.0.0 is none
Value returned on lookup of payload: {03FB981A-5170-11E0-A90E-3CEDE2AB3DC5} Adobe InDesign CS5.5 Application Base Files2 7.5.0.0 is: false
Action string for {03FB981A-5170-11E0-A90E-3CEDE2AB3DC5} Adobe InDesign CS5.5 Application Base Files2 7.5.0.0 is none
Value returned on lookup of payload: {CE6E1448-516F-11E0-B3C0-13EDE2AB3DC5} Adobe InDesign CS5.5 Application Feature Set Files 7.5.0.0 is: false
Action string for {CE6E1448-516F-11E0-B3C0-13EDE2AB3DC5} Adobe InDesign CS5.5 Application Feature Set Files 7.5.0.0 is none
Value returned on lookup of payload: {F313167E-5172-11E0-ACE7-30C2E3AB3DC5} Adobe InDesign CS5.5 Common Base Files 7.5.0.0 is: false
Action string for {F313167E-5172-11E0-ACE7-30C2E3AB3DC5} Adobe InDesign CS5.5 Common Base Files 7.5.0.0 is none
Value returned on lookup of payload: {EF45880C-DD84-46C3-A054-0BC5F76A6BBE} Adobe Photoshop CS5.1 Support 12.1.0.0 is: false
Action string for {EF45880C-DD84-46C3-A054-0BC5F76A6BBE} Adobe Photoshop CS5.1 Support 12.1.0.0 is none
Value returned on lookup of payload: {BD85DFD4-005F-4219-8E27-C922CC4D8A61} Adobe CSXS Extensions CS5.5 2.5.0.0 is: false
Action string for {BD85DFD4-005F-4219-8E27-C922CC4D8A61} Adobe CSXS Extensions CS5.5 2.5.0.0 is none
Value returned on lookup of payload: {4B204697-D302-42D9-94B4-8BDDE6DD359C} Adobe ReviewPanel CS5.5 3.0.0.0 is: false
Action string for {4B204697-D302-42D9-94B4-8BDDE6DD359C} Adobe ReviewPanel CS5.5 3.0.0.0 is none
Value returned on lookup of payload: {8B4C951B-F853-4B05-B892-9D5B3CD8AC98} PDF Settings CS5 10.0.0.0 is: false
Action string for {8B4C951B-F853-4B05-B892-9D5B3CD8AC98} PDF Settings CS5 10.0.0.0 is none
Value returned on lookup of payload: {A2502D10-2D75-4620-8A8B-73F39D5C1243} PDF Settings CS5 10.0.0.0 is: false
Action string for {A2502D10-2D75-4620-8A8B-73F39D5C1243} PDF Settings CS5 10.0.0.0 is none
Value returned on lookup of payload: {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation 1.0.0.0 is: false
Action string for {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation 1.0.0.0 is none
Value returned on lookup of payload: {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation 1.0.0.0 is: false
Action string for {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation 1.0.0.0 is none
Value returned on lookup of payload: {EE85C227-0148-4825-B659-6A1E142571EE} Adobe Bridge CS5.1 4.1.0.0 is: false
Action string for {EE85C227-0148-4825-B659-6A1E142571EE} Adobe Bridge CS5.1 4.1.0.0 is none
Value returned on lookup of payload: {A44863BF-8DB8-4D22-88DB-5A02BE319840} Adobe Linguistics CS5 5.0.0.0 is: false
Action string for {A44863BF-8DB8-4D22-88DB-5A02BE319840} Adobe Linguistics CS5 5.0.0.0 is none
Value returned on lookup of payload: {3450d4c5-a82b-4428-a512-842ee1555a14} CSXS Story Extension 2.5.0.0 is: false
Action string for {3450d4c5-a82b-4428-a512-842ee1555a14} CSXS Story Extension 2.5.0.0 is none
Value returned on lookup of payload: {270C312D-7EC7-474C-BEB2-79CD398E02A3} HIL Help Search 1.0.0.0 is: false
Action string for {270C312D-7EC7-474C-BEB2-79CD398E02A3} HIL Help Search 1.0.0.0 is none
Value returned on lookup of payload: {DD18D60C-87B1-47D9-8312-67508B402FB9} SiteCatalyst NetAverages CS5.5 2.0.0.0 is: false
Action string for {DD18D60C-87B1-47D9-8312-67508B402FB9} SiteCatalyst NetAverages CS5.5 2.0.0.0 is none
Value returned on lookup of payload: {4A8546D0-CEDF-48C1-9BA1-DD5B4ADFC154} Adobe Mini Bridge CS5.1 1.1.0.0 is: false
Action string for {4A8546D0-CEDF-48C1-9BA1-DD5B4ADFC154} Adobe Mini Bridge CS5.1 1.1.0.0 is none
Value returned on lookup of payload: {49E6D00F-3456-11E0-AE83-842B2B67A8CC} Adobe Device Central CS5.5 3.5.0.0 is: false
Action string for {49E6D00F-3456-11E0-AE83-842B2B67A8CC} Adobe Device Central CS5.5 3.5.0.0 is none
Value returned on lookup of payload: {FFC07452-6E0A-47A6-86E2-E18C9A992E7B} Adobe Device Central CS5.5_DeviceCentral3.5LP-en_GB 3.5.0.0 is: false
Action string for {FFC07452-6E0A-47A6-86E2-E18C9A992E7B} Adobe Device Central CS5.5_DeviceCentral3.5LP-en_GB 3.5.0.0 is none
Payload {FFC07452-6E0A-47A6-86E2-E18C9A992E7B} Adobe Device Central CS5.5_DeviceCentral3.5LP-en_GB 3.5.0.0 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {22C26C10-5C22-4674-A52C-100112664305} Adobe Device Central CS5.5_DeviceCentral3.5LP-en_US 3.5.0.0 is: false
Action string for {22C26C10-5C22-4674-A52C-100112664305} Adobe Device Central CS5.5_DeviceCentral3.5LP-en_US 3.5.0.0 is none
Payload {22C26C10-5C22-4674-A52C-100112664305} Adobe Device Central CS5.5_DeviceCentral3.5LP-en_US 3.5.0.0 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {D682C558-6F3F-4800-885C-4C5EB1B7338C} Adobe Buzzword CS5.5 1.0.0.0 is: false
Action string for {D682C558-6F3F-4800-885C-4C5EB1B7338C} Adobe Buzzword CS5.5 1.0.0.0 is none
Value returned on lookup of payload: {83478D6E-4AA8-11E0-A479-24B1F9D7AC32} Adobe Content Viewer 1.0.0.0 is: false
Action string for {83478D6E-4AA8-11E0-A479-24B1F9D7AC32} Adobe Content Viewer 1.0.0.0 is none
Value returned on lookup of payload: {62ED7AE1-01FA-4066-97B7-1CD93A68DD0D} Adobe Hunspell Linguistics Plugin CS5.5 1.0.0.0 is: false
Action string for {62ED7AE1-01FA-4066-97B7-1CD93A68DD0D} Adobe Hunspell Linguistics Plugin CS5.5 1.0.0.0 is none
Value returned on lookup of payload: {F8ABD584-A99C-4304-AC4B-CCFD0914D871} Adobe Linguistics CS5.5 5.5.0.0 is: false
Action string for {F8ABD584-A99C-4304-AC4B-CCFD0914D871} Adobe Linguistics CS5.5 5.5.0.0 is none
Value returned on lookup of payload: {4C08199E-0D93-4227-8325-F024E71CA7A1} Adobe SING CS5 3.0.0.0 is: false
Action string for {4C08199E-0D93-4227-8325-F024E71CA7A1} Adobe SING CS5 3.0.0.0 is none
Value returned on lookup of payload: {A1181890-9FA4-11DF-A25D-A35DF04EC7B1} Adobe Toolhints CS5.5 1.5.0.0 is: false
Action string for {A1181890-9FA4-11DF-A25D-A35DF04EC7B1} Adobe Toolhints CS5.5 1.5.0.0 is none
Value returned on lookup of payload: {419B81A0-6282-456C-9B1E-8DBABA0DE2DC} Adobe WinSoft Linguistics Plugin CS5.5 1.2.0.0 is: false
Action string for {419B81A0-6282-456C-9B1E-8DBABA0DE2DC} Adobe WinSoft Linguistics Plugin CS5.5 1.2.0.0 is none
Value returned on lookup of payload: {4603E0C5-6880-4A4F-BCF8-DF1F6AE0E317} AdobeColorPhotoshop CS5.5 3.1.0.0 is: false
Action string for {4603E0C5-6880-4A4F-BCF8-DF1F6AE0E317} AdobeColorPhotoshop CS5.5 3.1.0.0 is none
Value returned on lookup of payload: {EB186BF2-0A84-40A2-B794-0326D3DF9973} AdobeColorVideoProfilesCS CS5.5 3.1.0.0 is: false
Action string for {EB186BF2-0A84-40A2-B794-0326D3DF9973} AdobeColorVideoProfilesCS CS5.5 3.1.0.0 is none
Value returned on lookup of payload: {99BDA97A-4AA8-11E0-9E8D-32B2F9D7AC32} Digital Publishing 1.0.0.0 is: false
Action string for {99BDA97A-4AA8-11E0-9E8D-32B2F9D7AC32} Digital Publishing 1.0.0.0 is none
Value returned on lookup of payload: {E3EE510E-4AA6-11E0-A977-0A9EF9D7AC32} Adobe Digital Publishing Application Language Files_AdobeDigitalPublishingAppLang-en_GB 1.0.0.0 is: false
Action string for {E3EE510E-4AA6-11E0-A977-0A9EF9D7AC32} Adobe Digital Publishing Application Language Files_AdobeDigitalPublishingAppLang-en_GB 1.0.0.0 is none
Payload {E3EE510E-4AA6-11E0-A977-0A9EF9D7AC32} Adobe Digital Publishing Application Language Files_AdobeDigitalPublishingAppLang-en_GB 1.0.0.0 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {C1646326-4AA6-11E0-AE8E-4C9CF9D7AC32} Adobe Digital Publishing Application Language Files_AdobeDigitalPublishingAppLang-en_US 1.0.0.0 is: false
Action string for {C1646326-4AA6-11E0-AE8E-4C9CF9D7AC32} Adobe Digital Publishing Application Language Files_AdobeDigitalPublishingAppLang-en_US 1.0.0.0 is none
Payload {C1646326-4AA6-11E0-AE8E-4C9CF9D7AC32} Adobe Digital Publishing Application Language Files_AdobeDigitalPublishingAppLang-en_US 1.0.0.0 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {0D96CFE6-376D-44B8-808A-16F3BEB73263} Adobe Media Encoder CS5.5 5.5.0.0 is: false
Action string for {0D96CFE6-376D-44B8-808A-16F3BEB73263} Adobe Media Encoder CS5.5 5.5.0.0 is none
Value returned on lookup of payload: {AC76BA86-1033-F400-7760-000000000005} Acrobat Professional 10.0.0.0 is: false
Action string for {AC76BA86-1033-F400-7760-000000000005} Acrobat Professional 10.0.0.0 is install
Value returned on lookup of payload: {78E6AED6-9091-425A-A2F6-47D15A2D845D} Creative Suite 5.5 Design Standard 5.5.0.0 is: false
Action string for {78E6AED6-9091-425A-A2F6-47D15A2D845D} Creative Suite 5.5 Design Standard 5.5.0.0 is install
Value returned on lookup of payload: {A516708E-EC03-40F5-B82E-0851A44B3780} Adobe Illustrator CS5.1 15.1.0.0 is: false
Action string for {A516708E-EC03-40F5-B82E-0851A44B3780} Adobe Illustrator CS5.1 15.1.0.0 is install
Value returned on lookup of payload: {9F747BEC-FB4E-4830-8C58-363B8DCC26EB} Adobe Illustrator CS5.1_AdobeIllustrator15_1en_USLanguagePack 15.1.0.0 is: false
Action string for {9F747BEC-FB4E-4830-8C58-363B8DCC26EB} Adobe Illustrator CS5.1_AdobeIllustrator15_1en_USLanguagePack 15.1.0.0 is none
Payload {9F747BEC-FB4E-4830-8C58-363B8DCC26EB} Adobe Illustrator CS5.1_AdobeIllustrator15_1en_USLanguagePack 15.1.0.0 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {6C8DB10F-B997-4F24-B081-7BD4313CDBAA} Adobe Illustrator CS5.1_AdobeIllustrator15_1en_GBLanguagePack 15.1.0.0 is: false
Action string for {6C8DB10F-B997-4F24-B081-7BD4313CDBAA} Adobe Illustrator CS5.1_AdobeIllustrator15_1en_GBLanguagePack 15.1.0.0 is none
Payload {6C8DB10F-B997-4F24-B081-7BD4313CDBAA} Adobe Illustrator CS5.1_AdobeIllustrator15_1en_GBLanguagePack 15.1.0.0 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {08EF22BC-43B2-4B4E-BA12-52B18F418F38} Adobe Photoshop CS5.1 Core 12.1.0.0 is: false
Action string for {08EF22BC-43B2-4B4E-BA12-52B18F418F38} Adobe Photoshop CS5.1 Core 12.1.0.0 is install
Value returned on lookup of payload: {1FEB691B-39ED-4343-99D6-CACDAD879D8C} Adobe Photoshop CS5.1 International English Language Pack_AdobePhotoshop12-en_GB 12.1.0.0 is: false
Action string for {1FEB691B-39ED-4343-99D6-CACDAD879D8C} Adobe Photoshop CS5.1 International English Language Pack_AdobePhotoshop12-en_GB 12.1.0.0 is none
Payload {1FEB691B-39ED-4343-99D6-CACDAD879D8C} Adobe Photoshop CS5.1 International English Language Pack_AdobePhotoshop12-en_GB 12.1.0.0 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {EDE888ED-3BD7-4D8C-AB35-7E4C661A94D9} Adobe Photoshop CS5.1 English Language Pack_AdobePhotoshop12-en_US 12.1.0.0 is: false
Action string for {EDE888ED-3BD7-4D8C-AB35-7E4C661A94D9} Adobe Photoshop CS5.1 English Language Pack_AdobePhotoshop12-en_US 12.1.0.0 is none
Payload {EDE888ED-3BD7-4D8C-AB35-7E4C661A94D9} Adobe Photoshop CS5.1 English Language Pack_AdobePhotoshop12-en_US 12.1.0.0 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {0CCF0458-5171-11E0-BC45-DC59E3AB3DC5} Adobe InDesign CS5.5 Application Base Files 7.5.0.0 is: false
Action string for {0CCF0458-5171-11E0-BC45-DC59E3AB3DC5} Adobe InDesign CS5.5 Application Base Files 7.5.0.0 is install
Value returned on lookup of payload: {ED9DC850-516E-11E0-9096-1FE5E2AB3DC5} Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-en_US 7.5.0.0 is: false
Action string for {ED9DC850-516E-11E0-9096-1FE5E2AB3DC5} Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-en_US 7.5.0.0 is none
Payload {ED9DC850-516E-11E0-9096-1FE5E2AB3DC5} Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-en_US 7.5.0.0 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {3019BB9E-516F-11E0-AAAB-3AEBE2AB3DC5} Adobe InDesign CS5.5 Common Language Files_AdobeInDesign7xCommonLang-en_GB 7.5.0.0 is: false
Action string for {3019BB9E-516F-11E0-AAAB-3AEBE2AB3DC5} Adobe InDesign CS5.5 Common Language Files_AdobeInDesign7xCommonLang-en_GB 7.5.0.0 is none
Payload {3019BB9E-516F-11E0-AAAB-3AEBE2AB3DC5} Adobe InDesign CS5.5 Common Language Files_AdobeInDesign7xCommonLang-en_GB 7.5.0.0 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {93D13A00-516E-11E0-97B7-E4DEE2AB3DC5} Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-en_GB 7.5.0.0 is: false
Action string for {93D13A00-516E-11E0-97B7-E4DEE2AB3DC5} Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-en_GB 7.5.0.0 is none
Payload {93D13A00-516E-11E0-97B7-E4DEE2AB3DC5} Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-en_GB 7.5.0.0 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {75CD59C0-516F-11E0-892C-26ECE2AB3DC5} Adobe InDesign CS5.5 Common Language Files_AdobeInDesign7xCommonLang-en_US 7.5.0.0 is: false
Action string for {75CD59C0-516F-11E0-892C-26ECE2AB3DC5} Adobe InDesign CS5.5 Common Language Files_AdobeInDesign7xCommonLang-en_US 7.5.0.0 is none
Payload {75CD59C0-516F-11E0-892C-26ECE2AB3DC5} Adobe InDesign CS5.5 Common Language Files_AdobeInDesign7xCommonLang-en_US 7.5.0.0 is extension payload. Aligning its action according to parent.
END Setting requested payload actions
Collected advanced path check information for INSTALLDIR
INSTALLDIR is a well-formed path
INSTALLDIR is not the root path
INSTALLDIR is on a local volume
INSTALLDIR is on a writable volume
INSTALLDIR is not on a case sensitive volume
INSTALLDIR passed path basic path validation: /Applications
::START TIMER:: [System check :{71BC8278-815D-4F8C-8FA5-C6F782C73892}]
In InstallPreSystemCheckProc
Custom action return code: 0
:: END TIMER :: [System check :{71BC8278-815D-4F8C-8FA5-C6F782C73892}] took 7 milliseconds (0.007 seconds)
::START TIMER:: [System check :{BD85DFD4-005F-4219-8E27-C922CC4D8A61}]
:: END TIMER :: [System check :{BD85DFD4-005F-4219-8E27-C922CC4D8A61}] took 9 milliseconds (0.009 seconds)
::START TIMER:: [System check :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}]
Font Installer: Fonts STI Custom Hook 1.6 Release
:: END TIMER :: [System check :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}] took 44 milliseconds (0.044 seconds)
[ 0] Sat May 5 20:14:17 2012 INFO
::START TIMER:: [System check :{CBDD7465-CE11-4A58-9497-C370B65923F1}]
:: END TIMER :: [System check :{CBDD7465-CE11-4A58-9497-C370B65923F1}] took 45 milliseconds (0.045 seconds) DTR = 21333.3 KBPS (20.8333 MBPS)
::START TIMER:: [System check :{AC76BA86-1033-F400-7760-000000000005}]
:: END TIMER :: [System check :{AC76BA86-1033-F400-7760-000000000005}] took 66 milliseconds (0.066 seconds)
[ 0] Sat May 5 20:14:18 2012 INFO
BEGIN InstallOperationsQueue Unordered operations
{007A2A28-D6A8-4D91-9A2B-568FF8052215} Adobe WinSoft Linguistics Plugin CS5 1.2.0.0: with operation install
{0175676F-8C92-49F2-9131-D0D6AD654B41} AdobeHelp 3.4.0.0: with operation install
{03FB981A-5170-11E0-A90E-3CEDE2AB3DC5} Adobe InDesign CS5.5 Application Base Files2 7.5.0.0: with operation install
{08EF22BC-43B2-4B4E-BA12-52B18F418F38} Adobe Photoshop CS5.1 Core 12.1.0.0: with operation install
{0AA9D11A-227D-45AB-A5D5-6F5F6E81D5E3} Adobe Player for Embedding 3.1 3.101.0.0: with operation install
{0CCF0458-5171-11E0-BC45-DC59E3AB3DC5} Adobe InDesign CS5.5 Application Base Files 7.5.0.0: with operation install
{0D96CFE6-376D-44B8-808A-16F3BEB73263} Adobe Media Encoder CS5.5 5.5.0.0: with operation install
{11E1188F-E576-47BC-B215-600C02C7EABF} AdobeColorNA CS5.5 3.1.0.0: with operation install
{1A1E5FF9-D0FD-42A3-8E18-E5E7E95E1AB4} DynamiclinkSupport 5.5.0.0: with operation install
{1FEB691B-39ED-4343-99D6-CACDAD879D8C} Adobe Photoshop CS5.1 International English Language Pack_AdobePhotoshop12-en_GB 12.1.0.0: with operation none
{22C26C10-5C22-4674-A52C-100112664305} Adobe Device Central CS5.5_DeviceCentral3.5LP-en_US 3.5.0.0: with operation install
{270C312D-7EC7-474C-BEB2-79CD398E02A3} HIL Help Search 1.0.0.0: with operation install
{3019BB9E-516F-11E0-AAAB-3AEBE2AB3DC5} Adobe InDesign CS5.5 Common Language Files_AdobeInDesign7xCommonLang-en_GB 7.5.0.0: with operation none
{3450d4c5-a82b-4428-a512-842ee1555a14} CSXS Story Extension 2.5.0.0: with operation install
{37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw 6.0.0.0: with operation install
{3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.0.0: with operation install
{4058E728-84D8-45CE-8E2D-5F35BD6659A1} Adobe Extension Manager CS5.5 5.5.0.0: with operation install
{419B81A0-6282-456C-9B1E-8DBABA0DE2DC} Adobe WinSoft Linguistics Plugin CS5.5 1.2.0.0: with operation install
{45063C56-A2A2-4FD1-A56A-A964723EEE1E} AdobeColorCommonSetRGB 3.1.0.0: with operation install
{4603E0C5-6880-4A4F-BCF8-DF1F6AE0E317} AdobeColorPhotoshop CS5.5 3.1.0.0: with operation install
{49E6D00F-3456-11E0-AE83-842B2B67A8CC} Adobe Device Central CS5.5 3.5.0.0: with operation install
{4A8546D0-CEDF-48C1-9BA1-DD5B4ADFC154} Adobe Mini Bridge CS5.1 1.1.0.0: with operation install
{4B204697-D302-42D9-94B4-8BDDE6DD359C} Adobe ReviewPanel CS5.5 3.0.0.0: with operation install
{4C08199E-0D93-4227-8325-F024E71CA7A1} Adobe SING CS5 3.0.0.0: with operation install
{4FFA83C0-007A-4DB3-955C-B5EEE73BEDAF} Adobe SwitchBoard 2.0 2.0.0.0: with operation install
{54D89F03-8EED-4FF9-BCDF-3B2E11D448A6} AdobeColorCommonSetCMYK 3.1.0.0: with operation install
{5C0FEBDA-5A0E-4FC8-91CB-229A4C1561E9} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll 3.1.0.0: with operation install
{62ED7AE1-01FA-4066-97B7-1CD93A68DD0D} Adobe Hunspell Linguistics Plugin CS5.5 1.0.0.0: with operation install
{6A2E619B-E4AC-433B-A648-D458CE543A96} Adobe XMP Panels CS5 3.0.0.0: with operation install
{6C8DB10F-B997-4F24-B081-7BD4313CDBAA} Adobe Illustrator CS5.1_AdobeIllustrator15_1en_GBLanguagePack 15.1.0.0: with operation none
{6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 10.0.0.0: with operation install
{71BC8278-815D-4F8C-8FA5-C6F782C73892} Adobe CSXS Infrastructure CS5.5 2.5.0.0: with operation install
{75CD59C0-516F-11E0-892C-26ECE2AB3DC5} Adobe InDesign CS5.5 Common Language Files_AdobeInDesign7xCommonLang-en_US 7.5.0.0: with operation install
{78E6AED6-9091-425A-A2F6-47D15A2D845D} Creative Suite 5.5 Design Standard 5.5.0.0: with operation install
{7D676EF8-BB79-4741-B799-36F3F1F8DCCB} AdobeColorEU CS5.5 3.1.0.0: with operation none
{83478D6E-4AA8-11E0-A479-24B1F9D7AC32} Adobe Content Viewer 1.0.0.0: with operation install
{8B4C951B-F853-4B05-B892-9D5B3CD8AC98} PDF Settings CS5 10.0.0.0: with operation none
{93D13A00-516E-11E0-97B7-E4DEE2AB3DC5} Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-en_GB 7.5.0.0: with operation none
{99BDA97A-4AA8-11E0-9E8D-32B2F9D7AC32} Digital Publishing 1.0.0.0: with operation install
{9BA136BE-0077-41E1-AD56-56AB5D4A1A67} Adobe ExtendScript Toolkit CS5.5 3.6.0.0: with operation install
{9F747BEC-FB4E-4830-8C58-363B8DCC26EB} Adobe Illustrator CS5.1_AdobeIllustrator15_1en_USLanguagePack 15.1.0.0: with operation install
{A1181890-9FA4-11DF-A25D-A35DF04EC7B1} Adobe Toolhints CS5.5 1.5.0.0: with operation install
{A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All 6.3.0.0: with operation install
{A2502D10-2D75-4620-8A8B-73F39D5C1243} PDF Settings CS5 10.0.0.0: with operation install
{A44863BF-8DB8-4D22-88DB-5A02BE319840} Adobe Linguistics CS5 5.0.0.0: with operation install
{A516708E-EC03-40F5-B82E-0851A44B3780} Adobe Illustrator CS5.1 15.1.0.0: with operation install
{A80C015C-1939-42A5-AD2F-E76C7F194505} AdobeColorJA CS5.5 3.1.0.0: with operation install
{AC003BC0-704F-4F02-A72E-AC8B7044DE24} AdobeOutputModule 3.1.0.0: with operation install
{AC76BA86-1033-F400-7760-000000000005} Acrobat Professional 10.0.0.0: with operation install
{B5E12198-2A83-436B-AE2F-1F7BF65D2C14} AdobeColorJA CS5.5 3.1.0.0: with operation none
{BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 9.9.0.0: with operation install
{BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 3.0.0.0: with operation install
{BD85DFD4-005F-4219-8E27-C922CC4D8A61} Adobe CSXS Extensions CS5.5 2.5.0.0: with operation install
{C1646326-4AA6-11E0-AE8E-4C9CF9D7AC32} Adobe Digital Publishing Application Language Files_AdobeDigitalPublishingAppLang-en_US 1.0.0.0: with operation install
{CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation 1.0.0.0: with operation install
{CE6E1448-516F-11E0-B3C0-13EDE2AB3DC5} Adobe InDesign CS5.5 Application Feature Set Files 7.5.0.0: with operation install
{D682C558-6F3F-4800-885C-4C5EB1B7338C} Adobe Buzzword CS5.5 1.0.0.0: with operation install
{D8B9B5FB-D388-4D79-AA4B-6C09641189F6} Adobe Utilities CS5.5 3.1.0.0: with operation install
{DD18D60C-87B1-47D9-8312-67508B402FB9} SiteCatalyst NetAverages CS5.5 2.0.0.0: with operation install
{E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation 1.0.0.0: with operation install
{E3EE510E-4AA6-11E0-A977-0A9EF9D7AC32} Adobe Digital Publishing Application Language Files_AdobeDigitalPublishingAppLang-en_GB 1.0.0.0: with operation none
{E471A41E-852F-4A85-AA74-5B82AB81C615} AdobeColorNA CS5.5 3.1.0.0: with operation none
{EB186BF2-0A84-40A2-B794-0326D3DF9973} AdobeColorVideoProfilesCS CS5.5 3.1.0.0: with operation install
{ED28819E-310F-4F17-925C-C69B0A1C1F7F} Suite Shared Configuration CS5.5 2.5.0.0: with operation install
{ED9DC850-516E-11E0-9096-1FE5E2AB3DC5} Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-en_US 7.5.0.0: with operation install
{EDE888ED-3BD7-4D8C-AB35-7E4C661A94D9} Adobe Photoshop CS5.1 English Language Pack_AdobePhotoshop12-en_US 12.1.0.0: with operation install
{EE85C227-0148-4825-B659-6A1E142571EE} Adobe Bridge CS5.1 4.1.0.0: with operation install
{EF45880C-DD84-46C3-A054-0BC5F76A6BBE} Adobe Photoshop CS5.1 Support 12.1.0.0: with operation install
{F313167E-5172-11E0-ACE7-30C2E3AB3DC5} Adobe InDesign CS5.5 Common Base Files 7.5.0.0: with operation install
{F8ABD584-A99C-4304-AC4B-CCFD0914D871} Adobe Linguistics CS5.5 5.5.0.0: with operation install
{FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All 6.3.0.0: with operation install
{FECCB1BF-038D-41C2-861B-4560E7667005} AdobeColorEU CS5.5 3.1.0.0: with operation install
{FFC07452-6E0A-47A6-86E2-E18C9A992E7B} Adobe Device Central CS5.5_DeviceCentral3.5LP-en_GB 3.5.0.0: with operation none
END InstallOperationsQueue Unordered operations
BEGIN InstallOperationsQueue Ordered operations
END InstallOperationsQueue Ordered operations
Payloads passed preflight validation.
[ 0] Sat May 5 20:14:19 2012 INFO
Call PreSession Custom Hook
Calling the custom action code for pre-install for payload {0AA9D11A-227D-45AB-A5D5-6F5F6E81D5E3}
::START TIMER:: [Payload Operation :{0AA9D11A-227D-45AB-A5D5-6F5F6E81D5E3}]
[ 1] Sat May 5 20:14:19 2012 INFO
Installer Operation: PayloadInstaller
Request to install payload
[ 1] Sat May 5 20:14:23 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirwXfziwEJ/Install.db
[ 1] Sat May 5 20:14:37 2012 INFO
Completing installation for payload at /private/tmp/.tempdirwXfziwEJ/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{0AA9D11A-227D-45AB-A5D5-6F5F6E81D5E3}.db
[ 0] Sat May 5 20:14:37 2012 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{0AA9D11A-227D-45AB-A5D5-6F5F6E81D5E3}] took 18034 milliseconds (18.034 seconds) DTR = 4094.04 KBPS (3.99809 MBPS)
Updating driver data - Action: Add driver entry
Updating driver data successful. Driver entry was added. ARP estimated size 0KB
User specified overrideFile:
[ 0] Sat May 5 20:14:38 2012 INFO
Successfully updated the csu inventory for {0AA9D11A-227D-45AB-A5D5-6F5F6E81D5E3} Adobe Player for Embedding 3.1 3.101.0.0 return values 0:0
Calling the custom action code for post-install for payload {0AA9D11A-227D-45AB-A5D5-6F5F6E81D5E3} Adobe Player for Embedding 3.1 3.101.0.0
Calling the custom action code for pre-install for payload {D8B9B5FB-D388-4D79-AA4B-6C09641189F6}
::START TIMER:: [Payload Operation :{D8B9B5FB-D388-4D79-AA4B-6C09641189F6}]
[ 1] Sat May 5 20:14:38 2012 INFO
[ 1] Sat May 5 20:14:39 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirHF4ZuaQd/Install.db
Completing installation for payload at /private/tmp/.tempdirHF4ZuaQd/Install.db
[ 1] Sat May 5 20:14:40 2012 INFO
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{D8B9B5FB-D388-4D79-AA4B-6C09641189F6}.db
[ 0] Sat May 5 20:14:40 2012 INFO
:: END TIMER :: [Payload Operation :{D8B9B5FB-D388-4D79-AA4B-6C09641189F6}] took 2008 milliseconds (2.008 seconds) DTR = 103.586 KBPS (0.101158 MBPS)
Successfully updated the csu inventory for {D8B9B5FB-D388-4D79-AA4B-6C09641189F6} Adobe Utilities CS5.5 3.1.0.0 return values 0:0
Calling the custom action code for post-install for payload {D8B9B5FB-D388-4D79-AA4B-6C09641189F6} Adobe Utilities CS5.5 3.1.0.0
Calling the custom action code for pre-install for payload {3F023875-4A52-4605-9DB6-A88D4A813E8D}
::START TIMER:: [Payload Operation :{3F023875-4A52-4605-9DB6-A88D4A813E8D}]
[ 1] Sat May 5 20:14:43 2012 INFO
Beginning installation for payload at /private/tmp/.tempdir4Qj5Z1F7/Install.db
[ 1] Sat May 5 20:15:24 2012 INFO
Completing installation for payload at /private/tmp/.tempdir4Qj5Z1F7/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{3F023875-4A52-4605-9DB6-A88D4A813E8D}.db
[ 0] Sat May 5 20:15:24 2012 INFO
:: END TIMER :: [Payload Operation :{3F023875-4A52-4605-9DB6-A88D4A813E8D}] took 44048 milliseconds (44.048 seconds) DTR = 3776.33 KBPS (3.68783 MBPS)
Successfully updated the csu inventory for {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.0.0 return values 0:0
Calling the custom action code for post-install for payload {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.0.0
[ 0] Sat May 5 20:15:25 2012 INFO
Initializing the INSTALLDIR with PDB data for payload {3F023875-4A52-4605-9DB6-A88D4A813E8D}
Located the INSTALLDIR for payload '{3F023875-4A52-4605-9DB6-A88D4A813E8D}' : '/Applications'
Calling the custom action code for pre-install for payload {A189C479-C7CD-4E08-8CCF-D999B68C0C71}
::START TIMER:: [Payload Operation :{A189C479-C7CD-4E08-8CCF-D999B68C0C71}]
[ 1] Sat May 5 20:15:25 2012 INFO
[ 1] Sat May 5 20:15:28 2012 INFO
CustomizedPatch property not found in database
Beginning installation for payload at /private/tmp/.tempdirLvMGhTTL/Install.db
[ 1] Sat May 5 20:18:21 2012 INFO
Completing installation for payload at /private/tmp/.tempdirLvMGhTTL/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{A189C479-C7CD-4E08-8CCF-D999B68C0C71}.db
[ 0] Sat May 5 20:18:22 2012 INFO
:: END TIMER :: [Payload Operation :{A189C479-C7CD-4E08-8CCF-D999B68C0C71}] took 177237 milliseconds (177.237 seconds) DTR = 1740.49 KBPS (1.6997 MBPS)
Successfully updated the csu inventory for {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All 6.3.0.0 return values 0:0
Calling the custom action code for post-install for payload {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All 6.3.0.0
[ 0] Sat May 5 20:18:23 2012 INFO
Calling the custom action code for pre-install for payload {ED28819E-310F-4F17-925C-C69B0A1C1F7F}
::START TIMER:: [Payload Operation :{ED28819E-310F-4F17-925C-C69B0A1C1F7F}]
[ 1] Sat May 5 20:18:23 2012 INFO
[ 1] Sat May 5 20:18:25 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirXawzL6LN/Install.db
[ 1] Sat May 5 20:18:28 2012 INFO
Completing installation for payload at /private/tmp/.tempdirXawzL6LN/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{ED28819E-310F-4F17-925C-C69B0A1C1F7F}.db
[ 0] Sat May 5 20:18:29 2012 INFO
:: END TIMER :: [Payload Operation :{ED28819E-310F-4F17-925C-C69B0A1C1F7F}] took 6014 milliseconds (6.014 seconds) DTR = 2660.46 KBPS (2.5981 MBPS)
[ 0] Sat May 5 20:18:30 2012 INFO
Successfully updated the csu inventory for {ED28819E-310F-4F17-925C-C69B0A1C1F7F} Suite Shared Configuration CS5.5 2.5.0.0 return values 0:0
Calling the custom action code for post-install for payload {ED28819E-310F-4F17-925C-C69B0A1C1F7F} Suite Shared Configuration CS5.5 2.5.0.0
Calling the custom action code for pre-install for payload {BD0D6363-E961-410F-8BF4-ECD8795F3923}
::START TIMER:: [Payload Operation :{BD0D6363-E961-410F-8BF4-ECD8795F3923}]
[ 1] Sat May 5 20:18:30 2012 INFO
[ 1] Sat May 5 20:18:32 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirSEs4Gi4o/Install.db
[ 1] Sat May 5 20:18:33 2012 INFO
Completing installation for payload at /private/tmp/.tempdirSEs4Gi4o/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{BD0D6363-E961-410F-8BF4-ECD8795F3923}.db
[ 0] Sat May 5 20:18:34 2012 INFO
:: END TIMER :: [Payload Operation :{BD0D6363-E961-410F-8BF4-ECD8795F3923}] took 4014 milliseconds (4.014 seconds) DTR = 1691.08 KBPS (1.65145 MBPS)
Successfully updated the csu inventory for {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 3.0.0.0 return values 0:0
Calling the custom action code for post-install for payload {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 3.0.0.0
Calling the custom action code for pre-install for payload {AC003BC0-704F-4F02-A72E-AC8B7044DE24}
::START TIMER:: [Payload Operation :{AC003BC0-704F-4F02-A72E-AC8B7044DE24}]
[ 1] Sat May 5 20:18:34 2012 INFO
[ 1] Sat May 5 20:18:37 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirQUHSTXTQ/Install.db
[ 1] Sat May 5 20:18:39 2012 INFO
Evaluating condition# 1(Seq 187)
Condition failed(Seq 187)
Evaluating condition# 1(Seq 188)
Condition failed(Seq 188)
Completing installation for payload at /private/tmp/.tempdirQUHSTXTQ/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{AC003BC0-704F-4F02-A72E-AC8B7044DE24}.db
[ 0] Sat May 5 20:18:39 2012 INFO
:: END TIMER :: [Payload Operation :{AC003BC0-704F-4F02-A72E-AC8B7044DE24}] took 5011 milliseconds (5.011 seconds) DTR = 1650.77 KBPS (1.61208 MBPS)
[ 0] Sat May 5 20:18:40 2012 INFO
Successfully updated the csu inventory for {AC003BC0-704F-4F02-A72E-AC8B7044DE24} AdobeOutputModule 3.1.0.0 return values 0:0
Calling the custom action code for post-install for payload {AC003BC0-704F-4F02-A72E-AC8B7044DE24} AdobeOutputModule 3.1.0.0
Calling the custom action code for pre-install for payload {BAE5212B-6651-4AD8-B26A-1B284D2665C6}
::START TIMER:: [Payload Operation :{BAE5212B-6651-4AD8-B26A-1B284D2665C6}]
[ 1] Sat May 5 20:18:40 2012 INFO
[ 1] Sat May 5 20:18:43 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirTjVgNTwg/Install.db
[ 1] Sat May 5 20:18:59 2012 INFO
Completing installation for payload at /private/tmp/.tempdirTjVgNTwg/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{BAE5212B-6651-4AD8-B26A-1B284D2665C6}.db
[ 0] Sat May 5 20:19:00 2012 INFO
:: END TIMER :: [Payload Operation :{BAE5212B-6651-4AD8-B26A-1B284D2665C6}] took 20025 milliseconds (20.025 seconds) DTR = 3486.64 KBPS (3.40492 MBPS)
Successfully updated the csu inventory for {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 9.9.0.0 return values 0:0
Calling the custom action code for post-install for payload {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 9.9.0.0
Calling the custom action code for pre-install for payload {6F3A624B-1B72-4081-96E8-23261F389C5C}
::START TIMER:: [Payload Operation :{6F3A624B-1B72-4081-96E8-23261F389C5C}]
[ 1] Sat May 5 20:19:00 2012 INFO
[ 1] Sat May 5 20:19:03 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirG4Ug05DN/Install.db
Completing installation for payload at /private/tmp/.tempdirG4Ug05DN/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{6F3A624B-1B72-4081-96E8-23261F389C5C}.db
[ 0] Sat May 5 20:19:04 2012 INFO
:: END TIMER :: [Payload Operation :{6F3A624B-1B72-4081-96E8-23261F389C5C}] took 4029 milliseconds (4.029 seconds) DTR = 1507.07 KBPS (1.47175 MBPS)
[ 0] Sat May 5 20:19:05 2012 INFO
Successfully updated the csu inventory for {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 10.0.0.0 return values 0:0
Calling the custom action code for post-install for payload {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 10.0.0.0
Calling the custom action code for pre-install for payload {4FFA83C0-007A-4DB3-955C-B5EEE73BEDAF}
::START TIMER:: [Payload Operation :{4FFA83C0-007A-4DB3-955C-B5EEE73BEDAF}]
[ 1] Sat May 5 20:19:05 2012 INFO
[ 1] Sat May 5 20:19:07 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirMWvubrCf/Install.db
Evaluating condition# 1(Seq 17)
Condition failed(Seq 17)
Checking if the folder exists "/etc/mach_init_per_user.d"(Seq 21)
Evaluating condition# 1(Seq 25)
Condition failed(Seq 25)
[ 1] Sat May 5 20:19:08 2012 INFO
Completing installation for payload at /private/tmp/.tempdirMWvubrCf/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{4FFA83C0-007A-4DB3-955C-B5EEE73BEDAF}.db
[ 0] Sat May 5 20:19:08 2012 INFO
:: END TIMER :: [Payload Operation :{4FFA83C0-007A-4DB3-955C-B5EEE73BEDAF}] took 3011 milliseconds (3.011 seconds) DTR = 1264.7 KBPS (1.23505 MBPS)
[ 0] Sat May 5 20:19:09 2012 INFO
Successfully updated the csu inventory for {4FFA83C0-007A-4DB3-955C-B5EEE73BEDAF} Adobe SwitchBoard 2.0 2.0.0.0 return values 0:0
Calling the custom action code for post-install for payload {4FFA83C0-007A-4DB3-955C-B5EEE73BEDAF} Adobe SwitchBoard 2.0 2.0.0.0
Calling the custom action code for pre-install for payload {1A1E5FF9-D0FD-42A3-8E18-E5E7E95E1AB4}
::START TIMER:: [Payload Operation :{1A1E5FF9-D0FD-42A3-8E18-E5E7E95E1AB4}]
[ 1] Sat May 5 20:19:10 2012 INFO
[ 1] Sat May 5 20:19:12 2012 INFO
Beginning installation for payload at /private/tmp/.tempdir5Ho6oDGA/Install.db
[ 1] Sat May 5 20:19:14 2012 INFO
Evaluating condition# 1(Seq 61)
Condition failed(Seq 61)
Completing installation for payload at /private/tmp/.tempdir5Ho6oDGA/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{1A1E5FF9-D0FD-42A3-8E18-E5E7E95E1AB4}.db
[ 0] Sat May 5 20:19:15 2012 INFO
:: END TIMER :: [Payload Operation :{1A1E5FF9-D0FD-42A3-8E18-E5E7E95E1AB4}] took 5052 milliseconds (5.052 seconds) DTR = 2668.25 KBPS (2.60571 MBPS)
Successfully updated the csu inventory for {1A1E5FF9-D0FD-42A3-8E18-E5E7E95E1AB4} DynamiclinkSupport 5.5.0.0 return values 0:0
Calling the custom action code for post-install for payload {1A1E5FF9-D0FD-42A3-8E18-E5E7E95E1AB4} DynamiclinkSupport 5.5.0.0
Calling the custom action code for pre-install for payload {0175676F-8C92-49F2-9131-D0D6AD654B41}
::START TIMER:: [Payload Operation :{0175676F-8C92-49F2-9131-D0D6AD654B41}]
[ 1] Sat May 5 20:19:15 2012 INFO
Installer Operation: InstallThirdPartyPayloadOperation
Installing third party payload
Running the application : /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeHelp/InstallAdobeHelp
command line arguments in order are : /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeHelp/InstallAdobeHelp
command line arguments in order are : appVersion=3.4.980
command line arguments in order are : appId=chc
command line arguments in order are : pubId=4875E02D9FB21EE389F73B8D1702B320485DF8CE.1
command line arguments in order are : installerArg1=-silent
command line arguments in order are : installerArg2=-eulaAccepted
command line arguments in order are : installerArg3=AdobeHelp.air
[ 1] Sat May 5 20:19:16 2012 INFO
Third party application output:
Third party payload completed. Testing return code: 0
[ 0] Sat May 5 20:19:16 2012 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{0175676F-8C92-49F2-9131-D0D6AD654B41}] took 1013 milliseconds (1.013 seconds) DTR = 3.94867 KBPS (0.00385612 MBPS)
The csu inventory was not updated for payload {0175676F-8C92-49F2-9131-D0D6AD654B41} AdobeHelp 3.4.0.0, value of local var is -1
Calling the custom action code for post-install for payload {0175676F-8C92-49F2-9131-D0D6AD654B41} AdobeHelp 3.4.0.0
Calling the custom action code for pre-install for payload {71BC8278-815D-4F8C-8FA5-C6F782C73892}
::START TIMER:: [Pre payload :{71BC8278-815D-4F8C-8FA5-C6F782C73892}]
In PrePayloadInstallProc
:: END TIMER :: [Pre payload :{71BC8278-815D-4F8C-8FA5-C6F782C73892}] took 1 milliseconds (0.001 seconds)
::START TIMER:: [Payload Operation :{71BC8278-815D-4F8C-8FA5-C6F782C73892}]
[ 1] Sat May 5 20:19:19 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirslaQBZJP/Install.db
[ 1] Sat May 5 20:19:43 2012 INFO
Completing installation for payload at /private/tmp/.tempdirslaQBZJP/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{71BC8278-815D-4F8C-8FA5-C6F782C73892}.db
[ 0] Sat May 5 20:19:44 2012 INFO
:: END TIMER :: [Payload Operation :{71BC8278-815D-4F8C-8FA5-C6F782C73892}] took 28051 milliseconds (28.051 seconds) DTR = 329.543 KBPS (0.321819 MBPS)
[ 0] Sat May 5 20:19:45 2012 INFO
Successfully updated the csu inventory for {71BC8278-815D-4F8C-8FA5-C6F782C73892} Adobe CSXS Infrastructure CS5.5 2.5.0.0 return values 0:0
Calling the custom action code for post-install for payload {71BC8278-815D-4F8C-8FA5-C6F782C73892} Adobe CSXS Infrastructure CS5.5 2.5.0.0
::START TIMER:: [Post payload :{71BC8278-815D-4F8C-8FA5-C6F782C73892}]
In PostPayloadInstallProc
Logged in userid (501)
Changed Owner of '/Users/jeromy/Library/Application Support/Adobe/CS5.5ServiceManager' to '501'
Changed Owner of '/Users/jeromy/Library/Application Support/Adobe/CS5.5ServiceManager/cache' to '501'
Changed Owner of '/Users/jeromy/Library/Application Support/Adobe/CS5.5ServiceManager/configuration' to '501'
Changed Owner of '/Users/jeromy/Library/Application Support/Adobe/CS5.5ServiceManager/extensions' to '501'
Changed Owner of '/Users/jeromy/Library/Application Support/Adobe/CS5.5ServiceManager/logs' to '501'
Changed Owner of '/Users/jeromy/Library/Application Support/Adobe/CS5.5ServiceManager/preference' to '501'
Changed Owner of '/Users/jeromy/Library/Application Support/Adobe/CS5.5ServiceManager/StageManager' to '501'
:: END TIMER :: [Post payload :{71BC8278-815D-4F8C-8FA5-C6F782C73892}] took 3 milliseconds (0.003 seconds) DTR = 1333.33 KBPS (1.30208 MBPS)
Calling the custom action code for pre-install for payload {4058E728-84D8-45CE-8E2D-5F35BD6659A1}
::START TIMER:: [Payload Operation :{4058E728-84D8-45CE-8E2D-5F35BD6659A1}]
[ 1] Sat May 5 20:19:45 2012 INFO
[ 1] Sat May 5 20:19:47 2012 INFO
Beginning installation for payload at /private/tmp/.tempdir4zazJlQ9/Install.db
[ 1] Sat May 5 20:20:13 2012 INFO
Completing installation for payload at /private/tmp/.tempdir4zazJlQ9/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{4058E728-84D8-45CE-8E2D-5F35BD6659A1}.db
[ 0] Sat May 5 20:20:14 2012 INFO
:: END TIMER :: [Payload Operation :{4058E728-84D8-45CE-8E2D-5F35BD6659A1}] took 29034 milliseconds (29.034 seconds) DTR = 3156.02 KBPS (3.08205 MBPS)
Successfully updated the csu inventory for {4058E728-84D8-45CE-8E2D-5F35BD6659A1} Adobe Extension Manager CS5.5 5.5.0.0 return values 0:0
Calling the custom action code for post-install for payload {4058E728-84D8-45CE-8E2D-5F35BD6659A1} Adobe Extension Manager CS5.5 5.5.0.0
Calling the custom action code for pre-install for payload {6A2E619B-E4AC-433B-A648-D458CE543A96}
::START TIMER:: [Payload Operation :{6A2E619B-E4AC-433B-A648-D458CE543A96}]
[ 1] Sat May 5 20:20:15 2012 INFO
[ 1] Sat May 5 20:20:17 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirWAmtDSYX/Install.db
[ 1] Sat May 5 20:20:23 2012 INFO
Completing installation for payload at /private/tmp/.tempdirWAmtDSYX/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{6A2E619B-E4AC-433B-A648-D458CE543A96}.db
[ 0] Sat May 5 20:20:24 2012 INFO
:: END TIMER :: [Payload Operation :{6A2E619B-E4AC-433B-A648-D458CE543A96}] took 9036 milliseconds (9.036 seconds) DTR = 637.45 KBPS (0.62251 MBPS)
Successfully updated the csu inventory for {6A2E619B-E4AC-433B-A648-D458CE543A96} Adobe XMP Panels CS5 3.0.0.0 return values 0:0
Calling the custom action code for post-install for payload {6A2E619B-E4AC-433B-A648-D458CE543A96} Adobe XMP Panels CS5 3.0.0.0
Initializing the INSTALLDIR with PDB data for payload {6A2E619B-E4AC-433B-A648-D458CE543A96}
File Exists: /Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/AMT/application.xml
Located the INSTALLDIR for payload '{6A2E619B-E4AC-433B-A648-D458CE543A96}' : '/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0'
Calling the custom action code for pre-install for payload {5C0FEBDA-5A0E-4FC8-91CB-229A4C1561E9}
::START TIMER:: [Payload Operation :{5C0FEBDA-5A0E-4FC8-91CB-229A4C1561E9}]
[ 1] Sat May 5 20:20:24 2012 INFO
[ 1] Sat May 5 20:20:26 2012 INFO
Beginning installation for payload at /private/tmp/.tempdiriGH5iQuT/Install.db
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/camera/loc/Camera_sl_SI.dat"(Seq 3)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_da_DK.dat"(Seq 5)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_ru_RU.dat"(Seq 7)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_zh_CN.dat"(Seq 9)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_de_DE.dat"(Seq 11)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_en_US.dat"(Seq 13)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/bin/loc/FileInfo_hr_HR.dat"(Seq 15)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_uk_UA.dat"(Seq 17)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_sv_SE.dat"(Seq 19)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/camera/bin/camera.swf"(Seq 21)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_nb_NO.dat"(Seq 23)
[ 1] Sat May 5 20:20:27 2012 INFO
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_lt_LT.dat"(Seq 25)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/bin/advanced.swf"(Seq 27)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_sk_SK.dat"(Seq 29)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/categories/bin/categories.swf"(Seq 31)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_pt_BR.dat"(Seq 33)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/IPTC/bin/iptc.swf"(Seq 35)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_hr_HR.dat"(Seq 37)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/history/bin/history.swf"(Seq 39)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_fr_FR.dat"(Seq 41)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/IPTCExt/bin/iptcExt.swf"(Seq 43)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_pl_PL.dat"(Seq 45)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/audioData/bin/audioData.swf"(Seq 47)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_zh_TW.dat"(Seq 49)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_ja_JP.dat"(Seq 51)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/mobile/bin/mobile.swf"(Seq 53)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/dicom/bin/dicom.swf"(Seq 55)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_it_IT.dat"(Seq 57)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/camera/loc/Camera_sv_SE.dat"(Seq 59)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/description/bin/description.swf"(Seq 61)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_cs_CZ.dat"(Seq 63)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_ro_RO.dat"(Seq 65)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/origin/bin/origin.swf"(Seq 67)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/videoData/bin/videoData.swf"(Seq 69)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_lv_LV.dat"(Seq 71)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_fi_FI.dat"(Seq 73)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_et_EE.dat"(Seq 75)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_bg_BG.dat"(Seq 77)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_hu_HU.dat"(Seq 79)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/bin/FileInfoUI.swf"(Seq 81)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/bin/FileInfoFoundation.swf"(Seq 83)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_es_ES.dat"(Seq 85)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_ko_KR.dat"(Seq 87)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_tr_TR.dat"(Seq 89)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/rawpacket/bin/rawpacket.swf"(Seq 91)
[ 1] Sat May 5 20:20:28 2012 INFO
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_sl_SI.dat"(Seq 93)
Attempting to patch file: "/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/panels/advanced/loc/Advanced_nl_NL.dat"(Seq 95)
Completing installation for payload at /private/tmp/.tempdiriGH5iQuT/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{5C0FEBDA-5A0E-4FC8-91CB-229A4C1561E9}.db
[ 0] Sat May 5 20:20:28 2012 INFO
:: END TIMER :: [Payload Operation :{5C0FEBDA-5A0E-4FC8-91CB-229A4C1561E9}] took 4081 milliseconds (4.081 seconds) DTR = 268.562 KBPS (0.262267 MBPS)
Successfully updated the csu inventory for {5C0FEBDA-5A0E-4FC8-91CB-229A4C1561E9} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll 3.1.0.0 return values 0:0
Calling the custom action code for post-install for payload {5C0FEBDA-5A0E-4FC8-91CB-229A4C1561E9} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll 3.1.0.0
Calling the custom action code for pre-install for payload {9BA136BE-0077-41E1-AD56-56AB5D4A1A67}
::START TIMER:: [Payload Operation :{9BA136BE-0077-41E1-AD56-56AB5D4A1A67}]
[ 1] Sat May 5 20:20:29 2012 INFO
[ 1] Sat May 5 20:20:31 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirI3GbMV8e/Install.db
[ 1] Sat May 5 20:20:36 2012 INFO
Evaluating condition# 1(Seq 137)
Condition failed(Seq 137)
Evaluating condition# 2(Seq 141)
Condition failed(Seq 141)
[ 1] Sat May 5 20:20:40 2012 INFO
Completing installation for payload at /private/tmp/.tempdirI3GbMV8e/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{9BA136BE-0077-41E1-AD56-56AB5D4A1A67}.db
[ 0] Sat May 5 20:20:41 2012 INFO
:: END TIMER :: [Payload Operation :{9BA136BE-0077-41E1-AD56-56AB5D4A1A67}] took 12018 milliseconds (12.018 seconds) DTR = 2338.49 KBPS (2.28368 MBPS)
Successfully updated the csu inventory for {9BA136BE-0077-41E1-AD56-56AB5D4A1A67} Adobe ExtendScript Toolkit CS5.5 3.6.0.0 return values 0:0
Calling the custom action code for post-install for payload {9BA136BE-0077-41E1-AD56-56AB5D4A1A67} Adobe ExtendScript Toolkit CS5.5 3.6.0.0
Calling the custom action code for pre-install for payload {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3}
::START TIMER:: [Payload Operation :{37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3}]
[ 1] Sat May 5 20:20:41 2012 INFO
[ 1] Sat May 5 20:20:44 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirseiy78ld/Install.db
Evaluating condition# 1(Seq 2)
Condition failed(Seq 2)
[ 1] Sat May 5 20:20:48 2012 INFO
Completing installation for payload at /private/tmp/.tempdirseiy78ld/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3}.db
[ 0] Sat May 5 20:20:48 2012 INFO
:: END TIMER :: [Payload Operation :{37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3}] took 7014 milliseconds (7.014 seconds) DTR = 3862.56 KBPS (3.77203 MBPS)
[ 0] Sat May 5 20:20:49 2012 INFO
Successfully updated the csu inventory for {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw 6.0.0.0 return values 0:0
Calling the custom action code for post-install for payload {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw 6.0.0.0
Initializing the INSTALLDIR with PDB data for payload {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3}
File Exists: /Library/Application Support/Adobe/Camera Raw 6/AMT/component.xml
Located the INSTALLDIR for payload '{37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3}' : '/Applications'
Calling the custom action code for pre-install for payload {FD58D99B-9927-4226-8E00-959A4F76BD89}
::START TIMER:: [Payload Operation :{FD58D99B-9927-4226-8E00-959A4F76BD89}]
[ 1] Sat May 5 20:20:49 2012 INFO
[ 1] Sat May 5 20:20:52 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirU7x6g0Zl/Install.db
[ 1] Sat May 5 20:20:58 2012 INFO
Evaluating condition# 1(Seq 92)
Condition failed(Seq 92)
Evaluating condition# 1(Seq 93)
Condition failed(Seq 93)
Completing installation for payload at /private/tmp/.tempdirU7x6g0Zl/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{FD58D99B-9927-4226-8E00-959A4F76BD89}.db
[ 0] Sat May 5 20:20:59 2012 INFO
:: END TIMER :: [Payload Operation :{FD58D99B-9927-4226-8E00-959A4F76BD89}] took 10088 milliseconds (10.088 seconds) DTR = 2979.38 KBPS (2.90955 MBPS)
Successfully updated the csu inventory for {FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All 6.3.0.0 return values 0:0
Calling the custom action code for post-install for payload {FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All 6.3.0.0
Calling the custom action code for pre-install for payload {54D89F03-8EED-4FF9-BCDF-3B2E11D448A6}
::START TIMER:: [Payload Operation :{54D89F03-8EED-4FF9-BCDF-3B2E11D448A6}]
[ 1] Sat May 5 20:20:59 2012 INFO
[ 1] Sat May 5 20:21:02 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirllFZwgXS/Install.db
[ 1] Sat May 5 20:21:05 2012 INFO
Completing installation for payload at /private/tmp/.tempdirllFZwgXS/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{54D89F03-8EED-4FF9-BCDF-3B2E11D448A6}.db
[ 0] Sat May 5 20:21:05 2012 INFO
:: END TIMER :: [Payload Operation :{54D89F03-8EED-4FF9-BCDF-3B2E11D448A6}] took 6012 milliseconds (6.012 seconds) DTR = 21.9561 KBPS (0.0214415 MBPS)
[ 0] Sat May 5 20:21:06 2012 INFO
Successfully updated the csu inventory for {54D89F03-8EED-4FF9-BCDF-3B2E11D448A6} AdobeColorCommonSetCMYK 3.1.0.0 return values 0:0
Calling the custom action code for post-install for payload {54D89F03-8EED-4FF9-BCDF-3B2E11D448A6} AdobeColorCommonSetCMYK 3.1.0.0
Calling the custom action code for pre-install for payload {45063C56-A2A2-4FD1-A56A-A964723EEE1E}
::START TIMER:: [Payload Operation :{45063C56-A2A2-4FD1-A56A-A964723EEE1E}]
[ 1] Sat May 5 20:21:06 2012 INFO
[ 1] Sat May 5 20:21:07 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirjQTWJs63/Install.db
Collection adbeadbeadbeadbeadbeadbeadbeadb already exists(Seq 1)
Completing installation for payload at /private/tmp/.tempdirjQTWJs63/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{45063C56-A2A2-4FD1-A56A-A964723EEE1E}.db
[ 0] Sat May 5 20:21:08 2012 INFO
:: END TIMER :: [Payload Operation :{45063C56-A2A2-4FD1-A56A-A964723EEE1E}] took 2012 milliseconds (2.012 seconds) DTR = 33.7972 KBPS (0.0330051 MBPS)
Successfully updated the csu inventory for {45063C56-A2A2-4FD1-A56A-A964723EEE1E} AdobeColorCommonSetRGB 3.1.0.0 return values 0:0
Calling the custom action code for post-install for payload {45063C56-A2A2-4FD1-A56A-A964723EEE1E} AdobeColorCommonSetRGB 3.1.0.0
Calling the custom action code for pre-install for payload {FECCB1BF-038D-41C2-861B-4560E7667005}
::START TIMER:: [Payload Operation :{FECCB1BF-038D-41C2-861B-4560E7667005}]
[ 1] Sat May 5 20:21:08 2012 INFO
[ 1] Sat May 5 20:21:10 2012 INFO
Beginning installation for payload at /private/tmp/.tempdiruIuuvFZe/Install.db
Completing installation for payload at /private/tmp/.tempdiruIuuvFZe/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{FECCB1BF-038D-41C2-861B-4560E7667005}.db
[ 0] Sat May 5 20:21:11 2012 INFO
:: END TIMER :: [Payload Operation :{FECCB1BF-038D-41C2-861B-4560E7667005}] took 3032 milliseconds (3.032 seconds) DTR = 25.066 KBPS (0.0244785 MBPS)
Successfully updated the csu inventory for {FECCB1BF-038D-41C2-861B-4560E7667005} AdobeColorEU CS5.5 3.1.0.0 return values 0:0
Calling the custom action code for post-install for payload {FECCB1BF-038D-41C2-861B-4560E7667005} AdobeColorEU CS5.5 3.1.0.0
[ 0] Sat May 5 20:21:12 2012 INFO
Calling the custom action code for pre-install for payload {A80C015C-1939-42A5-AD2F-E76C7F194505}
::START TIMER:: [Payload Operation :{A80C015C-1939-42A5-AD2F-E76C7F194505}]
[ 1] Sat May 5 20:21:12 2012 INFO
[ 1] Sat May 5 20:21:13 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirShfbrZEt/Install.db
[ 1] Sat May 5 20:21:14 2012 INFO
Completing installation for payload at /private/tmp/.tempdirShfbrZEt/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{A80C015C-1939-42A5-AD2F-E76C7F194505}.db
[ 0] Sat May 5 20:21:15 2012 INFO
:: END TIMER :: [Payload Operation :{A80C015C-1939-42A5-AD2F-E76C7F194505}] took 3012 milliseconds (3.012 seconds) DTR = 22.5764 KBPS (0.0220472 MBPS)
Successfully updated the csu inventory for {A80C015C-1939-42A5-AD2F-E76C7F194505} AdobeColorJA CS5.5 3.1.0.0 return values 0:0
Calling the custom action code for post-install for payload {A80C015C-1939-42A5-AD2F-E76C7F194505} AdobeColorJA CS5.5 3.1.0.0
Calling the custom action code for pre-install for payload {11E1188F-E576-47BC-B215-600C02C7EABF}
::START TIMER:: [Payload Operation :{11E1188F-E576-47BC-B215-600C02C7EABF}]
[ 1] Sat May 5 20:21:15 2012 INFO
[ 1] Sat May 5 20:21:17 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirlHPJBrGa/Install.db
Completing installation for payload at /private/tmp/.tempdirlHPJBrGa/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{11E1188F-E576-47BC-B215-600C02C7EABF}.db
[ 0] Sat May 5 20:21:18 2012 INFO
:: END TIMER :: [Payload Operation :{11E1188F-E576-47BC-B215-600C02C7EABF}] took 3014 milliseconds (3.014 seconds) DTR = 17.2528 KBPS (0.0168485 MBPS)
Successfully updated the csu inventory for {11E1188F-E576-47BC-B215-600C02C7EABF} AdobeColorNA CS5.5 3.1.0.0 return values 0:0
Calling the custom action code for post-install for payload {11E1188F-E576-47BC-B215-600C02C7EABF} AdobeColorNA CS5.5 3.1.0.0
Calling the custom action code for pre-install for payload {007A2A28-D6A8-4D91-9A2B-568FF8052215}
::START TIMER:: [Payload Operation :{007A2A28-D6A8-4D91-9A2B-568FF8052215}]
[ 1] Sat May 5 20:21:18 2012 INFO
[ 1] Sat May 5 20:21:21 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirOVMKc2xV/Install.db
[ 1] Sat May 5 20:21:23 2012 INFO
Completing installation for payload at /private/tmp/.tempdirOVMKc2xV/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{007A2A28-D6A8-4D91-9A2B-568FF8052215}.db
[ 0] Sat May 5 20:21:24 2012 INFO
:: END TIMER :: [Payload Operation :{007A2A28-D6A8-4D91-9A2B-568FF8052215}] took 5016 milliseconds (5.016 seconds) DTR = 1916.27 KBPS (1.87136 MBPS)
Successfully updated the csu inventory for {007A2A28-D6A8-4D91-9A2B-568FF8052215} Adobe WinSoft Linguistics Plugin CS5 1.2.0.0 return values 0:0
Calling the custom action code for post-install for payload {007A2A28-D6A8-4D91-9A2B-568FF8052215} Adobe WinSoft Linguistics Plugin CS5 1.2.0.0
Calling the custom action code for pre-install for payload {03FB981A-5170-11E0-A90E-3CEDE2AB3DC5}
::START TIMER:: [Payload Operation :{03FB981A-5170-11E0-A90E-3CEDE2AB3DC5}]
[ 1] Sat May 5 20:21:24 2012 INFO
[ 1] Sat May 5 20:21:28 2012 INFO
Beginning installation for payload at /private/tmp/.tempdircfRgwJY4/Install.db
[ 1] Sat May 5 20:22:56 2012 INFO
Completing installation for payload at /private/tmp/.tempdircfRgwJY4/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{03FB981A-5170-11E0-A90E-3CEDE2AB3DC5}.db
[ 0] Sat May 5 20:22:58 2012 INFO
:: END TIMER :: [Payload Operation :{03FB981A-5170-11E0-A90E-3CEDE2AB3DC5}] took 94119 milliseconds (94.119 seconds) DTR = 1208.6 KBPS (1.18027 MBPS)
Successfully updated the csu inventory for {03FB981A-5170-11E0-A90E-3CEDE2AB3DC5} Adobe InDesign CS5.5 Application Base Files2 7.5.0.0 return values 0:0
Calling the custom action code for post-install for payload {03FB981A-5170-11E0-A90E-3CEDE2AB3DC5} Adobe InDesign CS5.5 Application Base Files2 7.5.0.0
Calling the custom action code for pre-install for payload {CE6E1448-516F-11E0-B3C0-13EDE2AB3DC5}
::START TIMER:: [Payload Operation :{CE6E1448-516F-11E0-B3C0-13EDE2AB3DC5}]
[ 1] Sat May 5 20:22:58 2012 INFO
[ 1] Sat May 5 20:23:00 2012 INFO
Beginning installation for payload at /private/tmp/.tempdir38Q9Ip40/Install.db
[ 1] Sat May 5 20:23:01 2012 INFO
Completing installation for payload at /private/tmp/.tempdir38Q9Ip40/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{CE6E1448-516F-11E0-B3C0-13EDE2AB3DC5}.db
[ 0] Sat May 5 20:23:01 2012 INFO
:: END TIMER :: [Payload Operation :{CE6E1448-516F-11E0-B3C0-13EDE2AB3DC5}] took 3010 milliseconds (3.01 seconds) DTR = 503.654 KBPS (0.49185 MBPS)
[ 0] Sat May 5 20:23:02 2012 INFO
Successfully updated the csu inventory for {CE6E1448-516F-11E0-B3C0-13EDE2AB3DC5} Adobe InDesign CS5.5 Application Feature Set Files 7.5.0.0 return values 0:0
Calling the custom action code for post-install for payload {CE6E1448-516F-11E0-B3C0-13EDE2AB3DC5} Adobe InDesign CS5.5 Application Feature Set Files 7.5.0.0
Calling the custom action code for pre-install for payload {F313167E-5172-11E0-ACE7-30C2E3AB3DC5}
::START TIMER:: [Payload Operation :{F313167E-5172-11E0-ACE7-30C2E3AB3DC5}]
[ 1] Sat May 5 20:23:02 2012 INFO
[ 1] Sat May 5 20:23:04 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirv18Yjkfb/Install.db
Completing installation for payload at /private/tmp/.tempdirv18Yjkfb/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{F313167E-5172-11E0-ACE7-30C2E3AB3DC5}.db
[ 0] Sat May 5 20:23:04 2012 INFO
:: END TIMER :: [Payload Operation :{F313167E-5172-11E0-ACE7-30C2E3AB3DC5}] took 2009 milliseconds (2.009 seconds) DTR = 109.507 KBPS (0.106941 MBPS)
Successfully updated the csu inventory for {F313167E-5172-11E0-ACE7-30C2E3AB3DC5} Adobe InDesign CS5.5 Common Base Files 7.5.0.0 return values 0:0
Calling the custom action code for post-install for payload {F313167E-5172-11E0-ACE7-30C2E3AB3DC5} Adobe InDesign CS5.5 Common Base Files 7.5.0.0
[ 0] Sat May 5 20:23:05 2012 INFO
Calling the custom action code for pre-install for payload {EF45880C-DD84-46C3-A054-0BC5F76A6BBE}
::START TIMER:: [Payload Operation :{EF45880C-DD84-46C3-A054-0BC5F76A6BBE}]
[ 1] Sat May 5 20:23:05 2012 INFO
[ 1] Sat May 5 20:23:06 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirDAj3tGn1/Install.db
[ 1] Sat May 5 20:23:07 2012 INFO
Completing installation for payload at /private/tmp/.tempdirDAj3tGn1/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{EF45880C-DD84-46C3-A054-0BC5F76A6BBE}.db
[ 0] Sat May 5 20:23:08 2012 INFO
:: END TIMER :: [Payload Operation :{EF45880C-DD84-46C3-A054-0BC5F76A6BBE}] took 3010 milliseconds (3.01 seconds) DTR = 381.395 KBPS (0.372456 MBPS)
Successfully updated the csu inventory for {EF45880C-DD84-46C3-A054-0BC5F76A6BBE} Adobe Photoshop CS5.1 Support 12.1.0.0 return values 0:0
Calling the custom action code for post-install for payload {EF45880C-DD84-46C3-A054-0BC5F76A6BBE} Adobe Photoshop CS5.1 Support 12.1.0.0
Calling the custom action code for pre-install for payload {BD85DFD4-005F-4219-8E27-C922CC4D8A61}
::START TIMER:: [Pre payload :{BD85DFD4-005F-4219-8E27-C922CC4D8A61}]
:: END TIMER :: [Pre payload :{BD85DFD4-005F-4219-8E27-C922CC4D8A61}] took 1 milliseconds (0.001 seconds)
::START TIMER:: [Payload Operation :{BD85DFD4-005F-4219-8E27-C922CC4D8A61}]
[ 1] Sat May 5 20:23:08 2012 INFO
[ 1] Sat May 5 20:23:11 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirWd4aGyc8/Install.db
[ 1] Sat May 5 20:23:14 2012 INFO
Completing installation for payload at /private/tmp/.tempdirWd4aGyc8/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{BD85DFD4-005F-4219-8E27-C922CC4D8A61}.db
[ 0] Sat May 5 20:23:15 2012 INFO
:: END TIMER :: [Payload Operation :{BD85DFD4-005F-4219-8E27-C922CC4D8A61}] took 7013 milliseconds (7.013 seconds) DTR = 1109.94 KBPS (1.08392 MBPS)
[ 0] Sat May 5 20:23:16 2012 INFO
Successfully updated the csu inventory for {BD85DFD4-005F-4219-8E27-C922CC4D8A61} Adobe CSXS Extensions CS5.5 2.5.0.0 return values 0:0
Calling the custom action code for post-install for payload {BD85DFD4-005F-4219-8E27-C922CC4D8A61} Adobe CSXS Extensions CS5.5 2.5.0.0
::START TIMER:: [Post payload :{BD85DFD4-005F-4219-8E27-C922CC4D8A61}]
:: END TIMER :: [Post payload :{BD85DFD4-005F-4219-8E27-C922CC4D8A61}] took 8 milliseconds (0.008 seconds) DTR = 500 KBPS (0.488281 MBPS)
Calling the custom action code for pre-install for payload {4B204697-D302-42D9-94B4-8BDDE6DD359C}
::START TIMER:: [Payload Operation :{4B204697-D302-42D9-94B4-8BDDE6DD359C}]
[ 1] Sat May 5 20:23:16 2012 INFO
[ 1] Sat May 5 20:23:18 2012 INFO
Beginning installation for payload at /private/tmp/.tempdiroybVaa37/Install.db
[ 1] Sat May 5 20:23:19 2012 INFO
Completing installation for payload at /private/tmp/.tempdiroybVaa37/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{4B204697-D302-42D9-94B4-8BDDE6DD359C}.db
[ 0] Sat May 5 20:23:19 2012 INFO
:: END TIMER :: [Payload Operation :{4B204697-D302-42D9-94B4-8BDDE6DD359C}] took 3012 milliseconds (3.012 seconds) DTR = 658.699 KBPS (0.64326 MBPS)
Successfully updated the csu inventory for {4B204697-D302-42D9-94B4-8BDDE6DD359C} Adobe ReviewPanel CS5.5 3.0.0.0 return values 0:0
Calling the custom action code for post-install for payload {4B204697-D302-42D9-94B4-8BDDE6DD359C} Adobe ReviewPanel CS5.5 3.0.0.0
[ 0] Sat May 5 20:23:20 2012 INFO
Calling the custom action code for pre-install for payload {A2502D10-2D75-4620-8A8B-73F39D5C1243}
::START TIMER:: [Payload Operation :{A2502D10-2D75-4620-8A8B-73F39D5C1243}]
[ 1] Sat May 5 20:23:20 2012 INFO
[ 1] Sat May 5 20:23:21 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirOBEx6NCU/Install.db
[ 1] Sat May 5 20:23:28 2012 INFO
Completing installation for payload at /private/tmp/.tempdirOBEx6NCU/Install.db
[ 1] Sat May 5 20:23:29 2012 INFO
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{A2502D10-2D75-4620-8A8B-73F39D5C1243}.db
[ 0] Sat May 5 20:23:30 2012 INFO
:: END TIMER :: [Payload Operation :{A2502D10-2D75-4620-8A8B-73F39D5C1243}] took 10015 milliseconds (10.015 seconds) DTR = 76.2856 KBPS (0.0744976 MBPS)
Successfully updated the csu inventory for {A2502D10-2D75-4620-8A8B-73F39D5C1243} PDF Settings CS5 10.0.0.0 return values 0:0
Calling the custom action code for post-install for payload {A2502D10-2D75-4620-8A8B-73F39D5C1243} PDF Settings CS5 10.0.0.0
Calling the custom action code for pre-install for payload {E39A5ABD-516B-46F9-A042-694BBA6A4E08}
::START TIMER:: [Pre payload :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}]
Font Installer: Using [AdobeCommon] path: /Library/Application Support/Adobe
:: END TIMER :: [Pre payload :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}] took 19 milliseconds (0.019 seconds)
::START TIMER:: [Payload Operation :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}]
[ 1] Sat May 5 20:23:30 2012 INFO
[ 1] Sat May 5 20:23:33 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirx6xuGp9O/Install.db
[ 1] Sat May 5 20:24:03 2012 INFO
Evaluating condition# 1(Seq 67)
Condition failed(Seq 67)
Completing installation for payload at /private/tmp/.tempdirx6xuGp9O/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{E39A5ABD-516B-46F9-A042-694BBA6A4E08}.db
[ 0] Sat May 5 20:24:04 2012 INFO
:: END TIMER :: [Payload Operation :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}] took 34038 milliseconds (34.038 seconds) DTR = 1823.61 KBPS (1.78087 MBPS)
[ 0] Sat May 5 20:24:05 2012 INFO
Successfully updated the csu inventory for {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation 1.0.0.0 return values 0:0
Calling the custom action code for post-install for payload {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation 1.0.0.0
::START TIMER:: [Post payload :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}]
Font Installer: Did not find any font files under:/Library/Application Support/Adobe/SavedFonts/current
:: END TIMER :: [Post payload :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}] took 0 milliseconds (0 seconds) DTR = inf KBPS (inf MBPS)
Calling the custom action code for pre-install for payload {CBDD7465-CE11-4A58-9497-C370B65923F1}
::START TIMER:: [Pre payload :{CBDD7465-CE11-4A58-9497-C370B65923F1}]
:: END TIMER :: [Pre payload :{CBDD7465-CE11-4A58-9497-C370B65923F1}] took 0 milliseconds (0 seconds)
::START TIMER:: [Payload Operation :{CBDD7465-CE11-4A58-9497-C370B65923F1}]
[ 1] Sat May 5 20:24:05 2012 INFO
[ 1] Sat May 5 20:24:08 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirlMLEP0Hi/Install.db
[ 1] Sat May 5 20:24:25 2012 INFO
Evaluating condition# 1(Seq 43)
Condition failed(Seq 43)
[ 1] Sat May 5 20:24:26 2012 INFO
Completing installation for payload at /private/tmp/.tempdirlMLEP0Hi/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{CBDD7465-CE11-4A58-9497-C370B65923F1}.db
[ 0] Sat May 5 20:24:26 2012 INFO
:: END TIMER :: [Payload Operation :{CBDD7465-CE11-4A58-9497-C370B65923F1}] took 21027 milliseconds (21.027 seconds) DTR = 7.03857 KBPS (0.0068736 MBPS)
[ 0] Sat May 5 20:24:27 2012 INFO
Successfully updated the csu inventory for {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation 1.0.0.0 return values 0:0
Calling the custom action code for post-install for payload {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation 1.0.0.0
::START TIMER:: [Post payload :{CBDD7465-CE11-4A58-9497-C370B65923F1}]
:: END TIMER :: [Post payload :{CBDD7465-CE11-4A58-9497-C370B65923F1}] took 0 milliseconds (0 seconds) DTR = inf KBPS (inf MBPS)
[ 0] Sat May 5 20:24:28 2012 INFO
Calling the custom action code for pre-install for payload {EE85C227-0148-4825-B659-6A1E142571EE}
::START TIMER:: [Payload Operation :{EE85C227-0148-4825-B659-6A1E142571EE}]
[ 1] Sat May 5 20:24:28 2012 INFO
[ 1] Sat May 5 20:24:31 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirBuUAKKRY/Install.db
[ 1] Sat May 5 20:25:23 2012 INFO
Evaluating condition# 30(Seq 1544)
Condition failed(Seq 1544)
Evaluating condition# 17(Seq 1545)
Condition failed(Seq 1545)
Evaluating condition# 26(Seq 1546)
Condition failed(Seq 1546)
Evaluating condition# 35(Seq 1547)
Condition failed(Seq 1547)
Evaluating condition# 31(Seq 1548)
Condition failed(Seq 1548)
Evaluating condition# 33(Seq 1549)
Condition failed(Seq 1549)
Evaluating condition# 2(Seq 1550)
Condition failed(Seq 1550)
Evaluating condition# 1(Seq 1551)
Condition failed(Seq 1551)
Evaluating condition# 25(Seq 1552)
Condition passed(Seq 1552)
Evaluating condition# 8(Seq 1553)
Condition failed(Seq 1553)
Evaluating condition# 13(Seq 1554)
Condition failed(Seq 1554)
Evaluating condition# 5(Seq 1555)
Condition failed(Seq 1555)
Evaluating condition# 27(Seq 1556)
Condition failed(Seq 1556)
Evaluating condition# 22(Seq 1557)
Condition failed(Seq 1557)
Evaluating condition# 16(Seq 1558)
Condition failed(Seq 1558)
Evaluating condition# 37(Seq 1559)
Condition failed(Seq 1559)
Evaluating condition# 29(Seq 1560)
Condition failed(Seq 1560)
Evaluating condition# 21(Seq 1561)
Condition failed(Seq 1561)
Evaluating condition# 19(Seq 1562)
Condition failed(Seq 1562)
Evaluating condition# 6(Seq 1563)
Condition failed(Seq 1563)
Evaluating condition# 4(Seq 1564)
Condition failed(Seq 1564)
Evaluating condition# 10(Seq 1565)
Condition failed(Seq 1565)
Evaluating condition# 20(Seq 1566)
Condition failed(Seq 1566)
Evaluating condition# 23(Seq 1567)
Condition failed(Seq 1567)
Evaluating condition# 28(Seq 1568)
Condition failed(Seq 1568)
Evaluating condition# 12(Seq 1569)
Condition failed(Seq 1569)
Evaluating condition# 34(Seq 1570)
Condition failed(Seq 1570)
Evaluating condition# 9(Seq 1571)
Condition failed(Seq 1571)
Evaluating condition# 36(Seq 1572)
Condition failed(Seq 1572)
Evaluating condition# 18(Seq 1573)
Condition failed(Seq 1573)
Evaluating condition# 32(Seq 1574)
Condition failed(Seq 1574)
Evaluating condition# 11(Seq 1575)
Condition failed(Seq 1575)
Evaluating condition# 3(Seq 1576)
Condition failed(Seq 1576)
Evaluating condition# 24(Seq 1577)
Condition failed(Seq 1577)
Evaluating condition# 7(Seq 1578)
Condition failed(Seq 1578)
Evaluating condition# 14(Seq 1579)
Condition failed(Seq 1579)
Evaluating condition# 15(Seq 1580)
Condition failed(Seq 1580)
[ 1] Sat May 5 20:25:26 2012 INFO
Completing installation for payload at /private/tmp/.tempdirBuUAKKRY/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{EE85C227-0148-4825-B659-6A1E142571EE}.db
[ 0] Sat May 5 20:25:27 2012 INFO
:: END TIMER :: [Payload Operation :{EE85C227-0148-4825-B659-6A1E142571EE}] took 59061 milliseconds (59.061 seconds) DTR = 3929.63 KBPS (3.83753 MBPS)
[ 0] Sat May 5 20:25:28 2012 INFO
Successfully updated the csu inventory for {EE85C227-0148-4825-B659-6A1E142571EE} Adobe Bridge CS5.1 4.1.0.0 return values 0:0
Calling the custom action code for post-install for payload {EE85C227-0148-4825-B659-6A1E142571EE} Adobe Bridge CS5.1 4.1.0.0
[ 0] Sat May 5 20:25:29 2012 INFO
Calling the custom action code for pre-install for payload {A44863BF-8DB8-4D22-88DB-5A02BE319840}
::START TIMER:: [Payload Operation :{A44863BF-8DB8-4D22-88DB-5A02BE319840}]
[ 1] Sat May 5 20:25:29 2012 INFO
[ 1] Sat May 5 20:25:32 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirqLEUyKuM/Install.db
[ 1] Sat May 5 20:25:50 2012 INFO
Completing installation for payload at /private/tmp/.tempdirqLEUyKuM/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{A44863BF-8DB8-4D22-88DB-5A02BE319840}.db
[ 0] Sat May 5 20:25:51 2012 INFO
:: END TIMER :: [Payload Operation :{A44863BF-8DB8-4D22-88DB-5A02BE319840}] took 22025 milliseconds (22.025 seconds) DTR = 1771.44 KBPS (1.72992 MBPS)
[ 0] Sat May 5 20:25:52 2012 INFO
Successfully updated the csu inventory for {A44863BF-8DB8-4D22-88DB-5A02BE319840} Adobe Linguistics CS5 5.0.0.0 return values 0:0
Calling the custom action code for post-install for payload {A44863BF-8DB8-4D22-88DB-5A02BE319840} Adobe Linguistics CS5 5.0.0.0
Calling the custom action code for pre-install for payload {3450d4c5-a82b-4428-a512-842ee1555a14}
::START TIMER:: [Payload Operation :{3450d4c5-a82b-4428-a512-842ee1555a14}]
[ 1] Sat May 5 20:25:52 2012 INFO
[ 1] Sat May 5 20:25:54 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirAhq1qTKn/Install.db
[ 1] Sat May 5 20:25:55 2012 INFO
Completing installation for payload at /private/tmp/.tempdirAhq1qTKn/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{3450d4c5-a82b-4428-a512-842ee1555a14}.db
[ 0] Sat May 5 20:25:55 2012 INFO
:: END TIMER :: [Payload Operation :{3450d4c5-a82b-4428-a512-842ee1555a14}] took 3011 milliseconds (3.011 seconds) DTR = 179.342 KBPS (0.175139 MBPS)
Successfully updated the csu inventory for {3450d4c5-a82b-4428-a512-842ee1555a14} CSXS Story Extension 2.5.0.0 return values 0:0
Calling the custom action code for post-install for payload {3450d4c5-a82b-4428-a512-842ee1555a14} CSXS Story Extension 2.5.0.0
Calling the custom action code for pre-install for payload {270C312D-7EC7-474C-BEB2-79CD398E02A3}
::START TIMER:: [Payload Operation :{270C312D-7EC7-474C-BEB2-79CD398E02A3}]
[ 1] Sat May 5 20:25:57 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirclPyEtVK/Install.db
Completing installation for payload at /private/tmp/.tempdirclPyEtVK/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{270C312D-7EC7-474C-BEB2-79CD398E02A3}.db
[ 0] Sat May 5 20:25:57 2012 INFO
:: END TIMER :: [Payload Operation :{270C312D-7EC7-474C-BEB2-79CD398E02A3}] took 2009 milliseconds (2.009 seconds) DTR = 209.059 KBPS (0.204159 MBPS)
[ 0] Sat May 5 20:25:58 2012 INFO
Successfully updated the csu inventory for {270C312D-7EC7-474C-BEB2-79CD398E02A3} HIL Help Search 1.0.0.0 return values 0:0
Calling the custom action code for post-install for payload {270C312D-7EC7-474C-BEB2-79CD398E02A3} HIL Help Search 1.0.0.0
Calling the custom action code for pre-install for payload {DD18D60C-87B1-47D9-8312-67508B402FB9}
::START TIMER:: [Payload Operation :{DD18D60C-87B1-47D9-8312-67508B402FB9}]
[ 1] Sat May 5 20:25:58 2012 INFO
[ 1] Sat May 5 20:25:59 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirnqDiJrrT/Install.db
[ 1] Sat May 5 20:26:00 2012 INFO
Completing installation for payload at /private/tmp/.tempdirnqDiJrrT/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{DD18D60C-87B1-47D9-8312-67508B402FB9}.db
[ 0] Sat May 5 20:26:01 2012 INFO
:: END TIMER :: [Payload Operation :{DD18D60C-87B1-47D9-8312-67508B402FB9}] took 3010 milliseconds (3.01 seconds) DTR = 228.571 KBPS (0.223214 MBPS)
Successfully updated the csu inventory for {DD18D60C-87B1-47D9-8312-67508B402FB9} SiteCatalyst NetAverages CS5.5 2.0.0.0 return values 0:0
Calling the custom action code for post-install for payload {DD18D60C-87B1-47D9-8312-67508B402FB9} SiteCatalyst NetAverages CS5.5 2.0.0.0
Calling the custom action code for pre-install for payload {4A8546D0-CEDF-48C1-9BA1-DD5B4ADFC154}
::START TIMER:: [Payload Operation :{4A8546D0-CEDF-48C1-9BA1-DD5B4ADFC154}]
[ 1] Sat May 5 20:26:01 2012 INFO
[ 1] Sat May 5 20:26:03 2012 INFO
Beginning installation for payload at /private/tmp/.tempdird50ZseTV/Install.db
[ 1] Sat May 5 20:26:04 2012 INFO
Completing installation for payload at /private/tmp/.tempdird50ZseTV/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{4A8546D0-CEDF-48C1-9BA1-DD5B4ADFC154}.db
[ 0] Sat May 5 20:26:04 2012 INFO
:: END TIMER :: [Payload Operation :{4A8546D0-CEDF-48C1-9BA1-DD5B4ADFC154}] took 3011 milliseconds (3.011 seconds) DTR = 1572.9 KBPS (1.53603 MBPS)
[ 0] Sat May 5 20:26:05 2012 INFO
Successfully updated the csu inventory for {4A8546D0-CEDF-48C1-9BA1-DD5B4ADFC154} Adobe Mini Bridge CS5.1 1.1.0.0 return values 0:0
Calling the custom action code for post-install for payload {4A8546D0-CEDF-48C1-9BA1-DD5B4ADFC154} Adobe Mini Bridge CS5.1 1.1.0.0
Calling the custom action code for pre-install for payload {49E6D00F-3456-11E0-AE83-842B2B67A8CC}
::START TIMER:: [Payload Operation :{49E6D00F-3456-11E0-AE83-842B2B67A8CC}]
[ 1] Sat May 5 20:26:05 2012 INFO
[ 1] Sat May 5 20:26:08 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirjx20znWG/Install.db
[ 1] Sat May 5 20:26:09 2012 INFO
Evaluating condition# 1(Seq 12)
Condition failed(Seq 12)
Evaluating condition# 1(Seq 13)
Condition failed(Seq 13)
[ 1] Sat May 5 20:27:05 2012 INFO
Completing installation for payload at /private/tmp/.tempdirjx20znWG/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{49E6D00F-3456-11E0-AE83-842B2B67A8CC}.db
[ 0] Sat May 5 20:27:07 2012 INFO
:: END TIMER :: [Payload Operation :{49E6D00F-3456-11E0-AE83-842B2B67A8CC}] took 62069 milliseconds (62.069 seconds) DTR = 3128.32 KBPS (3.055 MBPS)
Successfully updated the csu inventory for {49E6D00F-3456-11E0-AE83-842B2B67A8CC} Adobe Device Central CS5.5 3.5.0.0 return values 0:0
Calling the custom action code for post-install for payload {49E6D00F-3456-11E0-AE83-842B2B67A8CC} Adobe Device Central CS5.5 3.5.0.0
Initializing the INSTALLDIR with PDB data for payload {49E6D00F-3456-11E0-AE83-842B2B67A8CC}
File Exists: /Applications/Adobe Device Central CS5.5/Adobe Device Central CS5.5.app/Contents/Resources/AMT/application.xml
Located the INSTALLDIR for payload '{49E6D00F-3456-11E0-AE83-842B2B67A8CC}' : '/Applications'
Calling the custom action code for pre-install for payload {22C26C10-5C22-4674-A52C-100112664305}
::START TIMER:: [Payload Operation :{22C26C10-5C22-4674-A52C-100112664305}]
[ 1] Sat May 5 20:27:08 2012 INFO
[ 1] Sat May 5 20:27:09 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirX1UpP6K4/Install.db
Completing installation for payload at /private/tmp/.tempdirX1UpP6K4/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{22C26C10-5C22-4674-A52C-100112664305}.db
[ 0] Sat May 5 20:27:11 2012 INFO
:: END TIMER :: [Payload Operation :{22C26C10-5C22-4674-A52C-100112664305}] took 3076 milliseconds (3.076 seconds) DTR = 133.94 KBPS (0.130801 MBPS)
Successfully updated the csu inventory for {22C26C10-5C22-4674-A52C-100112664305} Adobe Device Central CS5.5_DeviceCentral3.5LP-en_US 3.5.0.0 return values 0:0
Calling the custom action code for post-install for payload {22C26C10-5C22-4674-A52C-100112664305} Adobe Device Central CS5.5_DeviceCentral3.5LP-en_US 3.5.0.0
Calling the custom action code for pre-install for payload {D682C558-6F3F-4800-885C-4C5EB1B7338C}
::START TIMER:: [Payload Operation :{D682C558-6F3F-4800-885C-4C5EB1B7338C}]
[ 1] Sat May 5 20:27:11 2012 INFO
[ 1] Sat May 5 20:27:13 2012 INFO
Beginning installation for payload at /private/tmp/.tempdiryUoJUdFs/Install.db
Completing installation for payload at /private/tmp/.tempdiryUoJUdFs/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{D682C558-6F3F-4800-885C-4C5EB1B7338C}.db
[ 0] Sat May 5 20:27:14 2012 INFO
:: END TIMER :: [Payload Operation :{D682C558-6F3F-4800-885C-4C5EB1B7338C}] took 3010 milliseconds (3.01 seconds) DTR = 554.153 KBPS (0.541165 MBPS)
[ 0] Sat May 5 20:27:15 2012 INFO
Successfully updated the csu inventory for {D682C558-6F3F-4800-885C-4C5EB1B7338C} Adobe Buzzword CS5.5 1.0.0.0 return values 0:0
Calling the custom action code for post-install for payload {D682C558-6F3F-4800-885C-4C5EB1B7338C} Adobe Buzzword CS5.5 1.0.0.0
Calling the custom action code for pre-install for payload {83478D6E-4AA8-11E0-A479-24B1F9D7AC32}
::START TIMER:: [Payload Operation :{83478D6E-4AA8-11E0-A479-24B1F9D7AC32}]
[ 1] Sat May 5 20:27:15 2012 INFO
Running the application : /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeContentViewer-mul/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
command line arguments in order are : /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AdobeContentViewer-mul/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
command line arguments in order are : -silent
command line arguments in order are : -eulaAccepted
command line arguments in order are : DesktopPreviewer.air
[ 1] Sat May 5 20:27:30 2012 INFO
Third party application output: failed due to bad configuration
[ 0] Sat May 5 20:27:31 2012 INFO
:: END TIMER :: [Payload Operation :{83478D6E-4AA8-11E0-A479-24B1F9D7AC32}] took 16025 milliseconds (16.025 seconds) DTR = 0.74883 KBPS (0.000731279 MBPS)
Successfully updated the csu inventory for {83478D6E-4AA8-11E0-A479-24B1F9D7AC32} Adobe Content Viewer 1.0.0.0 return values 0:0
Calling the custom action code for post-install for payload {83478D6E-4AA8-11E0-A479-24B1F9D7AC32} Adobe Content Viewer 1.0.0.0
Calling the custom action code for pre-install for payload {62ED7AE1-01FA-4066-97B7-1CD93A68DD0D}
::START TIMER:: [Payload Operation :{62ED7AE1-01FA-4066-97B7-1CD93A68DD0D}]
[ 1] Sat May 5 20:27:31 2012 INFO
[ 1] Sat May 5 20:27:34 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirylu3RP3T/Install.db
[ 1] Sat May 5 20:27:56 2012 INFO
Completing installation for payload at /private/tmp/.tempdirylu3RP3T/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{62ED7AE1-01FA-4066-97B7-1CD93A68DD0D}.db
[ 0] Sat May 5 20:27:56 2012 INFO
:: END TIMER :: [Payload Operation :{62ED7AE1-01FA-4066-97B7-1CD93A68DD0D}] took 25028 milliseconds (25.028 seconds) DTR = 4311.81 KBPS (4.21075 MBPS)
[ 0] Sat May 5 20:27:57 2012 INFO
Successfully updated the csu inventory for {62ED7AE1-01FA-4066-97B7-1CD93A68DD0D} Adobe Hunspell Linguistics Plugin CS5.5 1.0.0.0 return values 0:0
Calling the custom action code for post-install for payload {62ED7AE1-01FA-4066-97B7-1CD93A68DD0D} Adobe Hunspell Linguistics Plugin CS5.5 1.0.0.0
Calling the custom action code for pre-install for payload {F8ABD584-A99C-4304-AC4B-CCFD0914D871}
::START TIMER:: [Payload Operation :{F8ABD584-A99C-4304-AC4B-CCFD0914D871}]
[ 1] Sat May 5 20:27:57 2012 INFO
Installer Operation: PayloadInstaller
Request to install payload
[ 1] Sat May 5 20:28:00 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirWrjZwbwT/Install.db
[ 1] Sat May 5 20:28:18 2012 INFO
Completing installation for payload at /private/tmp/.tempdirWrjZwbwT/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{F8ABD584-A99C-4304-AC4B-CCFD0914D871}.db
[ 0] Sat May 5 20:28:18 2012 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{F8ABD584-A99C-4304-AC4B-CCFD0914D871}] took 21028 milliseconds (21.028 seconds) DTR = 1884.53 KBPS (1.84037 MBPS)
[ 0] Sat May 5 20:28:19 2012 INFO
Successfully updated the csu inventory for {F8ABD584-A99C-4304-AC4B-CCFD0914D871} Adobe Linguistics CS5.5 5.5.0.0 return values 0:0
Calling the custom action code for post-install for payload {F8ABD584-A99C-4304-AC4B-CCFD0914D871} Adobe Linguistics CS5.5 5.5.0.0
Calling the custom action code for pre-install for payload {4C08199E-0D93-4227-8325-F024E71CA7A1}
::START TIMER:: [Payload Operation :{4C08199E-0D93-4227-8325-F024E71CA7A1}]
[ 1] Sat May 5 20:28:19 2012 INFO
[ 1] Sat May 5 20:28:21 2012 INFO
Beginning installation for payload at /private/tmp/.tempdir3OBZStSn/Install.db
[ 1] Sat May 5 20:28:23 2012 INFO
Completing installation for payload at /private/tmp/.tempdir3OBZStSn/Install.db
[ 1] Sat May 5 20:28:24 2012 INFO
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{4C08199E-0D93-4227-8325-F024E71CA7A1}.db
[ 0] Sat May 5 20:28:24 2012 INFO
:: END TIMER :: [Payload Operation :{4C08199E-0D93-4227-8325-F024E71CA7A1}] took 5013 milliseconds (5.013 seconds) DTR = 16.7564 KBPS (0.0163637 MBPS)
User specified overrideFile:
Successfully updated the csu inventory for {4C08199E-0D93-4227-8325-F024E71CA7A1} Adobe SING CS5 3.0.0.0 return values 0:0
Calling the custom action code for post-install for payload {4C08199E-0D93-4227-8325-F024E71CA7A1} Adobe SING CS5 3.0.0.0
Calling the custom action code for pre-install for payload {A1181890-9FA4-11DF-A25D-A35DF04EC7B1}
::START TIMER:: [Payload Operation :{A1181890-9FA4-11DF-A25D-A35DF04EC7B1}]
[ 1] Sat May 5 20:28:26 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirfIczJ99J/Install.db
Completing installation for payload at /private/tmp/.tempdirfIczJ99J/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{A1181890-9FA4-11DF-A25D-A35DF04EC7B1}.db
[ 0] Sat May 5 20:28:26 2012 INFO
:: END TIMER :: [Payload Operation :{A1181890-9FA4-11DF-A25D-A35DF04EC7B1}] took 2014 milliseconds (2.014 seconds) DTR = 313.803 KBPS (0.306449 MBPS)
[ 0] Sat May 5 20:28:27 2012 INFO
Successfully updated the csu inventory for {A1181890-9FA4-11DF-A25D-A35DF04EC7B1} Adobe Toolhints CS5.5 1.5.0.0 return values 0:0
Calling the custom action code for post-install for payload {A1181890-9FA4-11DF-A25D-A35DF04EC7B1} Adobe Toolhints CS5.5 1.5.0.0
Calling the custom action code for pre-install for payload {419B81A0-6282-456C-9B1E-8DBABA0DE2DC}
::START TIMER:: [Payload Operation :{419B81A0-6282-456C-9B1E-8DBABA0DE2DC}]
[ 1] Sat May 5 20:28:27 2012 INFO
[ 1] Sat May 5 20:28:29 2012 INFO
Beginning installation for payload at /private/tmp/.tempdircuSZMztz/Install.db
[ 1] Sat May 5 20:28:31 2012 INFO
Completing installation for payload at /private/tmp/.tempdircuSZMztz/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{419B81A0-6282-456C-9B1E-8DBABA0DE2DC}.db
[ 0] Sat May 5 20:28:32 2012 INFO
:: END TIMER :: [Payload Operation :{419B81A0-6282-456C-9B1E-8DBABA0DE2DC}] took 5012 milliseconds (5.012 seconds) DTR = 1916.2 KBPS (1.87129 MBPS)
Successfully updated the csu inventory for {419B81A0-6282-456C-9B1E-8DBABA0DE2DC} Adobe WinSoft Linguistics Plugin CS5.5 1.2.0.0 return values 0:0
Calling the custom action code for post-install for payload {419B81A0-6282-456C-9B1E-8DBABA0DE2DC} Adobe WinSoft Linguistics Plugin CS5.5 1.2.0.0
Calling the custom action code for pre-install for payload {4603E0C5-6880-4A4F-BCF8-DF1F6AE0E317}
::START TIMER:: [Payload Operation :{4603E0C5-6880-4A4F-BCF8-DF1F6AE0E317}]
[ 1] Sat May 5 20:28:32 2012 INFO
[ 1] Sat May 5 20:28:34 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirrWp6SQrS/Install.db
Completing installation for payload at /private/tmp/.tempdirrWp6SQrS/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{4603E0C5-6880-4A4F-BCF8-DF1F6AE0E317}.db
[ 0] Sat May 5 20:28:35 2012 INFO
:: END TIMER :: [Payload Operation :{4603E0C5-6880-4A4F-BCF8-DF1F6AE0E317}] took 3010 milliseconds (3.01 seconds) DTR = 23.9203 KBPS (0.0233596 MBPS)
[ 0] Sat May 5 20:28:36 2012 INFO
Successfully updated the csu inventory for {4603E0C5-6880-4A4F-BCF8-DF1F6AE0E317} AdobeColorPhotoshop CS5.5 3.1.0.0 return values 0:0
Calling the custom action code for post-install for payload {4603E0C5-6880-4A4F-BCF8-DF1F6AE0E317} AdobeColorPhotoshop CS5.5 3.1.0.0
Calling the custom action code for pre-install for payload {EB186BF2-0A84-40A2-B794-0326D3DF9973}
::START TIMER:: [Payload Operation :{EB186BF2-0A84-40A2-B794-0326D3DF9973}]
[ 1] Sat May 5 20:28:36 2012 INFO
[ 1] Sat May 5 20:28:37 2012 INFO
Beginning installation for payload at /private/tmp/.tempdir792enml8/Install.db
Completing installation for payload at /private/tmp/.tempdir792enml8/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{EB186BF2-0A84-40A2-B794-0326D3DF9973}.db
[ 0] Sat May 5 20:28:38 2012 INFO
:: END TIMER :: [Payload Operation :{EB186BF2-0A84-40A2-B794-0326D3DF9973}] took 2010 milliseconds (2.01 seconds) DTR = 25.8706 KBPS (0.0252643 MBPS)
Successfully updated the csu inventory for {EB186BF2-0A84-40A2-B794-0326D3DF9973} AdobeColorVideoProfilesCS CS5.5 3.1.0.0 return values 0:0
Calling the custom action code for post-install for payload {EB186BF2-0A84-40A2-B794-0326D3DF9973} AdobeColorVideoProfilesCS CS5.5 3.1.0.0
Calling the custom action code for pre-install for payload {99BDA97A-4AA8-11E0-9E8D-32B2F9D7AC32}
::START TIMER:: [Payload Operation :{99BDA97A-4AA8-11E0-9E8D-32B2F9D7AC32}]
[ 1] Sat May 5 20:28:38 2012 INFO
[ 1] Sat May 5 20:28:40 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirhpwHtdQb/Install.db
[ 1] Sat May 5 20:28:41 2012 INFO
Completing installation for payload at /private/tmp/.tempdirhpwHtdQb/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{99BDA97A-4AA8-11E0-9E8D-32B2F9D7AC32}.db
[ 0] Sat May 5 20:28:42 2012 INFO
:: END TIMER :: [Payload Operation :{99BDA97A-4AA8-11E0-9E8D-32B2F9D7AC32}] took 4011 milliseconds (4.011 seconds) DTR = 1242.58 KBPS (1.21346 MBPS)
Successfully updated the csu inventory for {99BDA97A-4AA8-11E0-9E8D-32B2F9D7AC32} Digital Publishing 1.0.0.0 return values 0:0
Calling the custom action code for post-install for payload {99BDA97A-4AA8-11E0-9E8D-32B2F9D7AC32} Digital Publishing 1.0.0.0
Initializing the INSTALLDIR with PDB data for payload {99BDA97A-4AA8-11E0-9E8D-32B2F9D7AC32}
Located the INSTALLDIR for payload '{99BDA97A-4AA8-11E0-9E8D-32B2F9D7AC32}' : '/Applications'
Calling the custom action code for pre-install for payload {C1646326-4AA6-11E0-AE8E-4C9CF9D7AC32}
::START TIMER:: [Payload Operation :{C1646326-4AA6-11E0-AE8E-4C9CF9D7AC32}]
[ 1] Sat May 5 20:28:43 2012 INFO
[ 1] Sat May 5 20:28:44 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirTlqdfMcX/Install.db
[ 1] Sat May 5 20:28:45 2012 INFO
Completing installation for payload at /private/tmp/.tempdirTlqdfMcX/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{C1646326-4AA6-11E0-AE8E-4C9CF9D7AC32}.db
[ 0] Sat May 5 20:28:46 2012 INFO
:: END TIMER :: [Payload Operation :{C1646326-4AA6-11E0-AE8E-4C9CF9D7AC32}] took 3082 milliseconds (3.082 seconds) DTR = 375.081 KBPS (0.36629 MBPS)
Successfully updated the csu inventory for {C1646326-4AA6-11E0-AE8E-4C9CF9D7AC32} Adobe Digital Publishing Application Language Files_AdobeDigitalPublishingAppLang-en_US 1.0.0.0 return values 0:0
Calling the custom action code for post-install for payload {C1646326-4AA6-11E0-AE8E-4C9CF9D7AC32} Adobe Digital Publishing Application Language Files_AdobeDigitalPublishingAppLang-en_US 1.0.0.0
Calling the custom action code for pre-install for payload {0D96CFE6-376D-44B8-808A-16F3BEB73263}
::START TIMER:: [Payload Operation :{0D96CFE6-376D-44B8-808A-16F3BEB73263}]
[ 1] Sat May 5 20:28:46 2012 INFO
[ 1] Sat May 5 20:28:50 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirYTIJaCPA/Install.db
[ 1] Sat May 5 20:31:55 2012 INFO
Completing installation for payload at /private/tmp/.tempdirYTIJaCPA/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{0D96CFE6-376D-44B8-808A-16F3BEB73263}.db
[ 0] Sat May 5 20:31:57 2012 INFO
:: END TIMER :: [Payload Operation :{0D96CFE6-376D-44B8-808A-16F3BEB73263}] took 191184 milliseconds (191.184 seconds) DTR = 3452.61 KBPS (3.37169 MBPS)
[ 0] Sat May 5 20:31:58 2012 INFO
Successfully updated the csu inventory for {0D96CFE6-376D-44B8-808A-16F3BEB73263} Adobe Media Encoder CS5.5 5.5.0.0 return values 0:0
Calling the custom action code for post-install for payload {0D96CFE6-376D-44B8-808A-16F3BEB73263} Adobe Media Encoder CS5.5 5.5.0.0
Calling the custom action code for pre-install for payload {AC76BA86-1033-F400-7760-000000000005}
::START TIMER:: [Pre payload :{AC76BA86-1033-F400-7760-000000000005}]
Custom action return code: 0
:: END TIMER :: [Pre payload :{AC76BA86-1033-F400-7760-000000000005}] took 1 milliseconds (0.001 seconds)
::START TIMER:: [Payload Operation :{AC76BA86-1033-F400-7760-000000000005}]
[ 1] Sat May 5 20:31:58 2012 INFO
Running Apple Package : /Volumes/CS5_5 Design Std 1/Adobe CS5_5 Design Standard/payloads/AcrobatProfessional10.0-EFG/Adobe Acrobat X Pro Installer.pkg
[ 1] Sat May 5 20:32:05 2012 INFO
installer: Package name is Adobe Acrobat X Pro
installer: Installing at base path /
installer:PHASE:Preparing for installation…
[ 1] Sat May 5 20:32:06 2012 INFO
installer:PHASE:Preparing the disk…
installer:PHASE:Preparing Adobe Acrobat X Pro …
installer:PHASE:Waiting for other installations to complete…
installer:PHASE:Configuring the installation…
installer:STATUS:
[ 1] Sat May 5 20:32:07 2012 INFO
installer:%2.200000
installer:PHASE:Validating packages…
installer:%3.175000
installer:PHASE:Writing files…
[ 1] Sat May 5 20:32:08 2012 INFO
installer:%3.175000
installer:%3.175000
[ 1] Sat May 5 20:32:09 2012 INFO
installer:%3.175000
installer:%3.175000
[ 1] Sat May 5 20:32:10 2012 INFO
installer:%3.175000
installer:%3.175000
[ 1] Sat May 5 20:32:11 2012 INFO
installer:%3.175000
installer:%3.175000
[ 1] Sat May 5 20:32:12 2012 INFO
installer:%3.175000
installer:%3.175000
[ 1] Sat May 5 20:32:13 2012 INFO
installer:%3.175000
installer:%3.175000
[ 1] Sat May 5 20:32:14 2012 INFO
installer:%3.175000
installer:%3.175000
[ 1] Sat May 5 20:32:15 2012 INFO
installer:%3.175000
installer:%3.175000
[ 1] Sat May 5 20:32:16 2012 INFO
installer:%3.175000
installer:%3.175000
[ 1] Sat May 5 20:32:17 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:18 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:19 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:20 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:21 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:22 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:23 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:24 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:25 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:26 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:27 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:28 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:29 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:30 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:31 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:32 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:33 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:34 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:35 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:36 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:37 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:38 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:39 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:40 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:41 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:42 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:43 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:44 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:45 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:46 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:47 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:48 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:49 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:50 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:51 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:52 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:53 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:54 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:55 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:56 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:57 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:58 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:32:59 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:00 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:01 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:02 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:03 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:04 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:05 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:06 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:07 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:08 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:09 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:10 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:11 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:12 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:13 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:14 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:15 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:16 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:17 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:18 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:19 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:20 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:21 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:22 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:23 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:24 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:25 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:26 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:27 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:28 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:29 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:30 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:31 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:32 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:33 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:34 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:35 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:36 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:37 2012 INFO
installer:%8.144618
installer:%8.144618
[ 1] Sat May 5 20:33:38 2012 INFO
installer:%8.661689
installer:%9.695832
[ 1] Sat May 5 20:33:39 2012 INFO
installer:%10.729975
installer:%11.764118
[ 1] Sat May 5 20:33:40 2012 INFO
installer:%12.798261
installer:%14.349475
[ 1] Sat May 5 20:33:41 2012 INFO
installer:%15.383618
installer:%15.900690
[ 1] Sat May 5 20:33:42 2012 INFO
installer:%16.934833
installer:%17.968976
[ 1] Sat May 5 20:33:43 2012 INFO
installer:%19.003118
installer:%20.037261
[ 1] Sat May 5 20:33:44 2012 INFO
installer:%20.554333
installer:%21.588476
[ 1] Sat May 5 20:33:45 2012 INFO
installer:%23.139690
installer:%24.173833
[ 1] Sat May 5 20:33:46 2012 INFO
installer:%25.207976
installer:%26.759190
[ 1] Sat May 5 20:33:47 2012 INFO
installer:%28.310405
installer:%30.378691
[ 1] Sat May 5 20:33:48 2012 INFO
installer:%31.412834
installer:%32.964048
[ 1] Sat May 5 20:33:49 2012 INFO
installer:%34.515262
installer:%35.549405
[ 1] Sat May 5 20:33:50 2012 INFO
installer:%36.583548
installer:%38.134763
[ 1] Sat May 5 20:33:51 2012 INFO
installer:%39.168906
installer:%40.203048
[ 1] Sat May 5 20:33:52 2012 INFO
installer:%41.754263
installer:%42.271334
[ 1] Sat May 5 20:33:53 2012 INFO
installer:%43.305477
installer:%43.822549
[ 1] Sat May 5 20:33:54 2012 INFO
installer:%45.373763
[ 1] Sat May 5 20:33:55 2012 INFO
installer:%46.924978
installer:%47.442049
[ 1] Sat May 5 20:33:56 2012 INFO
installer:%48.476192
installer:%49.510335
[ 1] Sat May 5 20:33:57 2012 INFO
installer:%51.061549
installer:%52.612764
[ 1] Sat May 5 20:33:58 2012 INFO
installer:%53.646907
installer:%55.198121
[ 1] Sat May 5 20:33:59 2012 INFO
installer:%55.715192
[ 1] Sat May 5 20:34:00 2012 INFO
[ 1] Sat May 5 20:34:01 2012 INFO
[ 1] Sat May 5 20:34:02 2012 INFO
[ 1] Sat May 5 20:34:03 2012 INFO
[ 1] Sat May 5 20:34:04 2012 INFO
[ 1] Sat May 5 20:34:05 2012 INFO
installer:%58.836497
installer:PHASE:Running package scripts…
[ 1] Sat May 5 20:34:06 2012 INFO
installer:%59.095011
installer:%59.353524
[ 1] Sat May 5 20:34:07 2012 INFO
installer:%62.123337
installer:PHASE:Moving items into place…
installer:%62.381716
[ 1] Sat May 5 20:34:08 2012 INFO
installer:%97.750000
installer: The install failed (The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.)
[ 1] Sat May 5 20:34:09 2012 ERROR
DW006: Apple Package failed to install successfully.
[ 1] Sat May 5 20:34:09 2012 INFO
Third party payload completed. Testing return code: 1
[ 0] Sat May 5 20:34:10 2012 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{AC76BA86-1033-F400-7760-000000000005}] took 132138 milliseconds (132.138 seconds) DTR = 6774.13 KBPS (6.61536 MBPS)
The csu inventory was not updated for payload {AC76BA86-1033-F400-7760-000000000005} Acrobat Professional 10.0.0.0, value of local var is -1
Calling the ROLLBACK custom action code for pre-install for payload {AC76BA86-1033-F400-7760-000000000005} Acrobat Professional 10.0.0.0
In PrePayloadInstallProc
Calling the custom action code for pre-install for payload {78E6AED6-9091-425A-A2F6-47D15A2D845D}
::START TIMER:: [Payload Operation :{78E6AED6-9091-425A-A2F6-47D15A2D845D}]
[ 1] Sat May 5 20:34:10 2012 INFO
[ 1] Sat May 5 20:34:12 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirUykGXPzG/Install.db
[ 1] Sat May 5 20:34:13 2012 INFO
Completing installation for payload at /private/tmp/.tempdirUykGXPzG/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{78E6AED6-9091-425A-A2F6-47D15A2D845D}.db
[ 0] Sat May 5 20:34:14 2012 INFO
:: END TIMER :: [Payload Operation :{78E6AED6-9091-425A-A2F6-47D15A2D845D}] took 4011 milliseconds (4.011 seconds) DTR = 809.773 KBPS (0.790794 MBPS)
[ 0] Sat May 5 20:34:15 2012 INFO
The csu inventory was not updated for payload {78E6AED6-9091-425A-A2F6-47D15A2D845D} Creative Suite 5.5 Design Standard 5.5.0.0, value of local var is -1
Calling the custom action code for post-install for payload {78E6AED6-9091-425A-A2F6-47D15A2D845D} Creative Suite 5.5 Design Standard 5.5.0.0
Calling the custom action code for pre-install for payload {A516708E-EC03-40F5-B82E-0851A44B3780}
::START TIMER:: [Payload Operation :{A516708E-EC03-40F5-B82E-0851A44B3780}]
[ 1] Sat May 5 20:34:15 2012 INFO
[ 1] Sat May 5 20:34:18 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirdBsASl7c/Install.db
[ 1] Sat May 5 20:36:16 2012 INFO
Evaluating condition# 1(Seq 7533)
Condition failed(Seq 7533)
Evaluating condition# 1(Seq 7534)
Condition failed(Seq 7534)
Evaluating condition# 1(Seq 7535)
Condition failed(Seq 7535)
Completing installation for payload at /private/tmp/.tempdirdBsASl7c/Install.db
[ 1] Sat May 5 20:36:17 2012 INFO
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{A516708E-EC03-40F5-B82E-0851A44B3780}.db
[ 0] Sat May 5 20:36:21 2012 INFO
:: END TIMER :: [Payload Operation :{A516708E-EC03-40F5-B82E-0851A44B3780}] took 126123 milliseconds (126.123 seconds) DTR = 2920.86 KBPS (2.85241 MBPS)
Successfully updated the csu inventory for {A516708E-EC03-40F5-B82E-0851A44B3780} Adobe Illustrator CS5.1 15.1.0.0 return values 0:0
Calling the custom action code for post-install for payload {A516708E-EC03-40F5-B82E-0851A44B3780} Adobe Illustrator CS5.1 15.1.0.0
Initializing the INSTALLDIR with PDB data for payload {A516708E-EC03-40F5-B82E-0851A44B3780}
File Exists: /Applications/Adobe Illustrator CS5.1/Adobe Illustrator.app/Contents/Resources/AMT/application.xml
Located the INSTALLDIR for payload '{A516708E-EC03-40F5-B82E-0851A44B3780}' : '/Applications'
Calling the custom action code for pre-install for payload {9F747BEC-FB4E-4830-8C58-363B8DCC26EB}
::START TIMER:: [Payload Operation :{9F747BEC-FB4E-4830-8C58-363B8DCC26EB}]
[ 1] Sat May 5 20:36:22 2012 INFO
[ 1] Sat May 5 20:36:25 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirSwDXbHWn/Install.db
[ 1] Sat May 5 20:38:59 2012 INFO
Evaluating condition# 1(Seq 394)
Condition passed(Seq 394)
Evaluating condition# 1(Seq 395)
Condition passed(Seq 395)
Evaluating condition# 1(Seq 396)
Condition passed(Seq 396)
Evaluating condition# 1(Seq 397)
Condition passed(Seq 397)
Evaluating condition# 1(Seq 398)
Condition passed(Seq 398)
Evaluating condition# 1(Seq 399)
Condition passed(Seq 399)
Evaluating condition# 1(Seq 400)
Condition passed(Seq 400)
Completing installation for payload at /private/tmp/.tempdirSwDXbHWn/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{9F747BEC-FB4E-4830-8C58-363B8DCC26EB}.db
[ 0] Sat May 5 20:39:00 2012 INFO
:: END TIMER :: [Payload Operation :{9F747BEC-FB4E-4830-8C58-363B8DCC26EB}] took 158240 milliseconds (158.24 seconds) DTR = 2698.74 KBPS (2.63548 MBPS)
Successfully updated the csu inventory for {9F747BEC-FB4E-4830-8C58-363B8DCC26EB} Adobe Illustrator CS5.1_AdobeIllustrator15_1en_USLanguagePack 15.1.0.0 return values 0:0
Calling the custom action code for post-install for payload {9F747BEC-FB4E-4830-8C58-363B8DCC26EB} Adobe Illustrator CS5.1_AdobeIllustrator15_1en_USLanguagePack 15.1.0.0
Calling the custom action code for pre-install for payload {08EF22BC-43B2-4B4E-BA12-52B18F418F38}
::START TIMER:: [Payload Operation :{08EF22BC-43B2-4B4E-BA12-52B18F418F38}]
[ 1] Sat May 5 20:39:00 2012 INFO
[ 1] Sat May 5 20:39:05 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirRZmOIdfg/Install.db
[ 1] Sat May 5 20:41:43 2012 INFO
Completing installation for payload at /private/tmp/.tempdirRZmOIdfg/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{08EF22BC-43B2-4B4E-BA12-52B18F418F38}.db
[ 0] Sat May 5 20:41:44 2012 INFO
:: END TIMER :: [Payload Operation :{08EF22BC-43B2-4B4E-BA12-52B18F418F38}] took 164169 milliseconds (164.169 seconds) DTR = 4341.48 KBPS (4.23972 MBPS)
[ 0] Sat May 5 20:41:45 2012 INFO
Successfully updated the csu inventory for {08EF22BC-43B2-4B4E-BA12-52B18F418F38} Adobe Photoshop CS5.1 Core 12.1.0.0 return values 0:0
Calling the custom action code for post-install for payload {08EF22BC-43B2-4B4E-BA12-52B18F418F38} Adobe Photoshop CS5.1 Core 12.1.0.0
Initializing the INSTALLDIR with PDB data for payload {08EF22BC-43B2-4B4E-BA12-52B18F418F38}
File Exists: /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Resources/AMT/application.xml
Located the INSTALLDIR for payload '{08EF22BC-43B2-4B4E-BA12-52B18F418F38}' : '/Applications'
Calling the custom action code for pre-install for payload {EDE888ED-3BD7-4D8C-AB35-7E4C661A94D9}
::START TIMER:: [Payload Operation :{EDE888ED-3BD7-4D8C-AB35-7E4C661A94D9}]
[ 1] Sat May 5 20:41:45 2012 INFO
[ 1] Sat May 5 20:41:48 2012 INFO
Beginning installation for payload at /private/tmp/.tempdir7YtQdQCt/Install.db
[ 1] Sat May 5 20:41:59 2012 INFO
Completing installation for payload at /private/tmp/.tempdir7YtQdQCt/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{EDE888ED-3BD7-4D8C-AB35-7E4C661A94D9}.db
[ 0] Sat May 5 20:42:00 2012 INFO
:: END TIMER :: [Payload Operation :{EDE888ED-3BD7-4D8C-AB35-7E4C661A94D9}] took 15088 milliseconds (15.088 seconds) DTR = 1789.77 KBPS (1.74782 MBPS)
Successfully updated the csu inventory for {EDE888ED-3BD7-4D8C-AB35-7E4C661A94D9} Adobe Photoshop CS5.1 English Language Pack_AdobePhotoshop12-en_US 12.1.0.0 return values 0:0
Calling the custom action code for post-install for payload {EDE888ED-3BD7-4D8C-AB35-7E4C661A94D9} Adobe Photoshop CS5.1 English Language Pack_AdobePhotoshop12-en_US 12.1.0.0
Calling the custom action code for pre-install for payload {0CCF0458-5171-11E0-BC45-DC59E3AB3DC5}
::START TIMER:: [Payload Operation :{0CCF0458-5171-11E0-BC45-DC59E3AB3DC5}]
[ 1] Sat May 5 20:42:00 2012 INFO
[ 1] Sat May 5 20:42:04 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirBDFfBFQA/Install.db
[ 1] Sat May 5 20:44:26 2012 INFO
Evaluating condition# 21(Seq 9283)
Condition failed(Seq 9283)
Evaluating condition# 22(Seq 9283)
Evaluating condition# 23(Seq 9283)
Evaluating condition# 24(Seq 9283)
Evaluating condition# 1(Seq 9284)
Condition failed(Seq 9284)
Evaluating condition# 2(Seq 9284)
Evaluating condition# 3(Seq 9284)
Evaluating condition# 4(Seq 9284)
Evaluating condition# 5(Seq 9284)
Condition passed(Seq 9284)
Evaluating condition# 21(Seq 9296)
Condition failed(Seq 9296)
Evaluating condition# 22(Seq 9296)
Evaluating condition# 23(Seq 9296)
Evaluating condition# 24(Seq 9296)
Evaluating condition# 1(Seq 9297)
Condition failed(Seq 9297)
Evaluating condition# 2(Seq 9297)
Evaluating condition# 3(Seq 9297)
Evaluating condition# 4(Seq 9297)
Evaluating condition# 5(Seq 9297)
Condition passed(Seq 9297)
[ 1] Sat May 5 20:44:33 2012 INFO
Completing installation for payload at /private/tmp/.tempdirBDFfBFQA/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{0CCF0458-5171-11E0-BC45-DC59E3AB3DC5}.db
[ 0] Sat May 5 20:44:36 2012 INFO
:: END TIMER :: [Payload Operation :{0CCF0458-5171-11E0-BC45-DC59E3AB3DC5}] took 155164 milliseconds (155.164 seconds) DTR = 1903.74 KBPS (1.85912 MBPS)
Successfully updated the csu inventory for {0CCF0458-5171-11E0-BC45-DC59E3AB3DC5} Adobe InDesign CS5.5 Application Base Files 7.5.0.0 return values 0:0
Calling the custom action code for post-install for payload {0CCF0458-5171-11E0-BC45-DC59E3AB3DC5} Adobe InDesign CS5.5 Application Base Files 7.5.0.0
Initializing the INSTALLDIR with PDB data for payload {0CCF0458-5171-11E0-BC45-DC59E3AB3DC5}
File Exists: /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/Resources/AMT/application.xml
Located the INSTALLDIR for payload '{0CCF0458-5171-11E0-BC45-DC59E3AB3DC5}' : '/Applications'
Calling the custom action code for pre-install for payload {ED9DC850-516E-11E0-9096-1FE5E2AB3DC5}
::START TIMER:: [Payload Operation :{ED9DC850-516E-11E0-9096-1FE5E2AB3DC5}]
[ 1] Sat May 5 20:44:36 2012 INFO
[ 1] Sat May 5 20:44:38 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirNvpUT7mt/Install.db
[ 1] Sat May 5 20:44:40 2012 INFO
Completing installation for payload at /private/tmp/.tempdirNvpUT7mt/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{ED9DC850-516E-11E0-9096-1FE5E2AB3DC5}.db
[ 0] Sat May 5 20:44:41 2012 INFO
:: END TIMER :: [Payload Operation :{ED9DC850-516E-11E0-9096-1FE5E2AB3DC5}] took 5048 milliseconds (5.048 seconds) DTR = 431.062 KBPS (0.420959 MBPS)
Successfully updated the csu inventory for {ED9DC850-516E-11E0-9096-1FE5E2AB3DC5} Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-en_US 7.5.0.0 return values 0:0
Calling the custom action code for post-install for payload {ED9DC850-516E-11E0-9096-1FE5E2AB3DC5} Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-en_US 7.5.0.0
[ 0] Sat May 5 20:44:42 2012 INFO
Calling the custom action code for pre-install for payload {75CD59C0-516F-11E0-892C-26ECE2AB3DC5}
::START TIMER:: [Payload Operation :{75CD59C0-516F-11E0-892C-26ECE2AB3DC5}]
[ 1] Sat May 5 20:44:42 2012 INFO
[ 1] Sat May 5 20:44:44 2012 INFO
Beginning installation for payload at /private/tmp/.tempdirHJQHmJoY/Install.db
[ 1] Sat May 5 20:44:52 2012 INFO
Completing installation for payload at /private/tmp/.tempdirHJQHmJoY/Install.db
UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{75CD59C0-516F-11E0-892C-26ECE2AB3DC5}.db
[ 0] Sat May 5 20:44:53 2012 INFO
:: END TIMER :: [Payload Operation :{75CD59C0-516F-11E0-892C-26ECE2AB3DC5}] took 11086 milliseconds (11.086 seconds) DTR = 3706.66 KBPS (3.61978 MBPS)
Successfully updated the csu inventory for {75CD59C0-516F-11E0-892C-26ECE2AB3DC5} Adobe InDesign CS5.5 Common Language Files_AdobeInDesign7xCommonLang-en_US 7.5.0.0 return values 0:0
Calling the custom action code for post-install for payload {75CD59C0-516F-11E0-892C-26ECE2AB3DC5} Adobe InDesign CS5.5 Common Language Files_AdobeInDesign7xCommonLang-en_US 7.5.0.0
[ 0] Sat May 5 20:45:03 2012 INFO
No operation. We're done:
Updating driver data - Action: Remove driver entry
Updating driver data successful. Driver entry was added. ARP estimated size 4637295KB
[ 0] Sat May 5 20:45:05 2012 INFO
Successfully installed 62 components:
- Adobe WinSoft Linguistics Plugin CS5
- AdobeHelp
- Adobe InDesign CS5.5 Application Base Files2
- Adobe Photoshop CS5.1 Core
- Adobe Player for Embedding 3.1
- Adobe Media Encoder CS5.5
- AdobeColorNA CS5.5
- DynamiclinkSupport
- Adobe Device Central CS5.5_DeviceCentral3.5LP-en_US
- HIL Help Search
- CSXS Story Extension
- Photoshop Camera Raw
- Camera Profiles Installer
- Adobe Extension Manager CS5.5
- Adobe WinSoft Linguistics Plugin CS5.5
- AdobeColorCommonSetRGB
- AdobeColorPhotoshop CS5.5
- Adobe Mini Bridge CS5.1
- Adobe ReviewPanel CS5.5
- Adobe SING CS5
- Adobe SwitchBoard 2.0
- AdobeColorCommonSetCMYK
- Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll
- Adobe Hunspell Linguistics Plugin CS5.5
- AdobeTypeSupport CS5
- Adobe CSXS Infrastructure CS5.5
- Adobe InDesign CS5.5 Common Language Files_AdobeInDesign7xCommonLang-en_US
- Creative Suite 5.5 Design Standard
- Adobe Content Viewer
- Digital Publishing
- Adobe ExtendScript Toolkit CS5.5
- Adobe Illustrator CS5.1_AdobeIllustrator15_1en_USLanguagePack
- Adobe Toolhints CS5.5
- Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All
- PDF Settings CS5
- Adobe Linguistics CS5
- AdobeColorJA CS5.5
- AdobeOutputModule
- AdobePDFL CS5
- AdobeCMaps CS5
- Adobe CSXS Extensions CS5.5
- Adobe Digital Publishing Application Language Files_AdobeDigitalPublishingAppLang-en_US
- Required Common Fonts Installation
- Adobe InDesign CS5.5 Application Feature Set Files
- Adobe Buzzword CS5.5
- Adobe Utilities CS5.5
- SiteCatalyst NetAverages CS5.5
- Recommended Common Fonts Installation
- AdobeColorVideoProfilesCS CS5.5
- Suite Shared Configuration CS5.5
- Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-en_US
- Adobe Photoshop CS5.1 English Language Pack_AdobePhotoshop12-en_US
- Adobe Bridge CS5.1
- Adobe Photoshop CS5.1 Support
- Adobe InDesign CS5.5 Common Base Files
- Adobe Linguistics CS5.5
- Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All
- AdobeColorEU CS5.5
Total components repaired: 0
Total components removed: 0
[ 0] Sat May 5 20:45:05 2012 ERROR
DW050: The following payload errors were found during install:
DW050: - Acrobat Professional: Install failed
Call PostSession Custom Hook
:: END TIMER :: [Total Timer] took 1.87157e+06 milliseconds (1871.57 seconds) DTR = 2761.47 KBPS (2.69675 MBPS)
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 3 error(s), 0 warning(s)
----------- Payload: {AC76BA86-1033-F400-7760-000000000005} Acrobat Professional 10.0.0.0 -----------
ERROR: DW006: Apple Package failed to install successfully.
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Acrobat Professional: Install failed
Please search the above error/warning string(s) to find when the error occurred.
These errors resulted in installer Exit Code mentioned below.
Exit Code: 6 - Silent workflow completed with errors.
END - Installer Session
I can't see anything obvious. In fact it attempts to install Acro, then rolls back stating a user override - whatever that is supposed to mean. Any chance this is a global permissions issue and you need to install as root user? I'm really not sure what else to advise. any chance you have a previous version of Acrobat/ Reader on the system? If so, manualyl uninstalling those may also rectify the issue.
Mylenium
We had the same error with CS6. It did turn out to be a permissions error, which we discovered by looking at the installer log from within the installer program (while it was trying to install, rather than the one it spits out after it's done). That live log showed a number of sudo errors, even though root was enabled. When we tried to just run a sudo command at the terminal window and got a sudoers permission error which led us to this discussion board:
https://discussions.apple.com/thread/3680870?start=0&tstart=0
which suggested the problem was with the permissions on the /, /private, and /private/etc directories. The root folder turned out to have extended attributes (an @ symbol at the end of the owner/group/world permissions given by ls -al). Removing the extended attritbute with
xattr -d com.apple.quarantine
failed because we had disabled root access at some point. We re-enabled root (from the finder, type command-shift-G then go to /System/Library/CoreServices, then open directory utility, then go to Edit and enable root user), logged into the terminal as root, and removed the extended attributes. Finally this allowed us to change the permissions on the root directory. Once we had done this, we were able to use sudo commands ourselves, and the Adobe installer ran without a hitch!
