Flash professional crashing pc on compile errors
May 20, 2012 9:31 AM
Tags: #problem #air #error #adobe #flash #pro #flash_professional #flash_cs6
I seem to have put this in the wrong place before, so here it is in the correct area I hope
I have been working on an Air app in cs4. The version of Air is 1.5.
For some of the features in Air that would make things easyer for me, I need to upgrade.
So I downloaded cs6 to test out as it has Air 3.2
Problem I have found is that my project crashes the PC every time the compiler  catch's an error. Any error.
I also reinstalled in case it was a bad install.
My system stats are : XP Prp 32bit sp3 with 3GB ram and all the latest updates.
    May 20, 2012 10:41 AM   in reply to spacebaloon
    possible problems include,
    -having a bad sector on your harddrive- hdds mainly last 3-4 years, past that and they can have gradual minor read failures and become slower etc. and your running a 10+ yr OS so that gives some flags
    -since you have reinstalled flash the problem may lie in adobe air, as you compile or publish anything for mobile it uses the air sdk so you may want to update the SDK as well as the air software just incase the flash install doesn't overwrite once installed.
    -the problem could be caused from the OS, but theres no way to know without reinstalling windows.
    -if you downloaded it online and are reinstalling it from the same download you may want to redownload the original cs6 file. also you could always call your ISP and ask them if you have a high packet loss or google for ways to find out yourself, your internet connection doesn't have to show any signs of problems for you to have a high packet loss, files will still download but tiny fragments will be corrupted in turn not functon correctly
    TBH, I do think it is your adobe air install, replace files in your program files/adobe/flashcs6 with the new sdk ones just in case and update air
