can't install cs6 pb!?
May 17, 2012 10:37 PM
ran setup
all seemed ok till asked to insert 2nd disk. at which point error message said to restart and try again.
on second try there was no longer any cs6 folder on the first disk just the following folders:
cs6 speech anal models
encore cs6 functional content
premiere cs6 functional content.
tried installing direct from the premiere folder set up and received the following error message:
Exit Code: 7
Please see specific errors and warnings below for troubleshooting. For example,  ERROR: DW050, DW062 ...
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 2 error(s), 0 warning(s)
----------- Payload: {614020C8-2E16-4E16-A5F0-04DE2AB96097} Adobe Premiere Pro CS6 Functional Content 6.0.0.0 -----------
ERROR: DW062: Unable to locate folder for token SharedDocuments
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050:  - Adobe Premiere Pro CS6 Functional Content: Install failed
and yet again.....
Exit Code: 7
- 0 fatal error(s), 72 error(s), 0 warning(s)
----------- Payload: {DE88AA40-6766-43D3-A755-8FC374B3D2C3} DynamiclinkSupport 6.0.0.0 -----------
----------- Payload: {539AEF15-3A2B-4A31-A587-7E90F7D9C700} Camera Profiles Installer 7.0.0.0 -----------
----------- Payload: {8706963D-5F48-47CC-998B-DAB70B089DB8} Suite Shared Configuration CS6 3.0.0.0 -----------
ERROR: DW050:  - Adobe Bridge CS6 (64 Bit): Install failed
ERROR: DW050:  - AdobeColorVideoProfilesAE CS6: Install failed
ERROR: DW050:  - Dynamic Link Media Server: Install failed
ERROR: DW050:  - CS6 Production Premium: Install failed
ERROR: DW050:  - Adobe XMP Panels: Install failed
ERROR: DW050:  - AdobeColorCommonSetCMYK CS6: Install failed
ERROR: DW050:  - AdobeColorEU CS6: Install failed
ERROR: DW050:  - Adobe Encore CS6_AdobeEncore6en_USLanguagePack: Install failed
ERROR: DW050:  - SonicWrappers_ph: Install failed
ERROR: DW050:  - Adobe Flash CS6_AdobeFlash12.0-en_USLanguagePack: Install failed
ERROR: DW050:  - Adobe Prelude CS6 Support: Install failed
ERROR: DW050:  - Adobe Photoshop CS6 Support: Install failed
ERROR: DW050:  - AdobePDFL x64 CS6: Install failed
ERROR: DW050:  - AdobeColorJA CS6: Install failed
ERROR: DW050:  - Adobe Hunspell Linguistics Plugin CS6 x64: Install failed
ERROR: DW050:  - SonicWrappers_bl: Install failed
ERROR: DW050:  - Adobe Audition: Failed due to Language Pack installation failure
ERROR: DW050:  - Adobe Photoshop CS6 Core_x64: Failed due to Language Pack installation failure
ERROR: DW050:  - Adobe Player for Embedding 3.3: Install failed
ERROR: DW050:  - Adobe CSXS Infrastructure CS6: Install failed
ERROR: DW050:  - Adobe SpeedGrade CS6: Failed due to Language Pack installation failure
ERROR: DW050:  - AdobeColorNA CS6: Install failed
ERROR: DW050:  - Adobe Premiere Pro CS6: Failed due to Language Pack installation failure
ERROR: DW050:  - Adobe Prelude CS6_AdobePrelude1en_USLanguagePack: Install failed
ERROR: DW050:  - Adobe Encore CS6: Failed due to Language Pack installation failure
ERROR: DW050:  - AdobeMotionPicture CS6: Install failed
ERROR: DW050:  - Adobe After Effects CS6: Failed due to Language Pack installation failure
ERROR: DW050:  - AdobeColorPhotoshop CS6: Install failed
ERROR: DW050:  - Adobe Flash CS6: Failed due to Language Pack installation failure
ERROR: DW050:  - Camera Profiles Installer: Install failed
ERROR: DW050:  - AdobePDFL CS6: Install failed
ERROR: DW050:  - Photoshop Camera Raw 7 (64 bit): Install failed
ERROR: DW050:  - Adobe SpeedGrade CS6_AdobeSpeedGrade6.0en_USLanguagePack: Install failed
ERROR: DW050:  - Required Common Fonts Installation x64: Install failed
ERROR: DW050:  - AdobeColorVideoProfilesCS CS6: Install failed
ERROR: DW050:  - Adobe WinSoft Linguistics Plugin CS6 x64: Install failed
ERROR: DW050:  - PDF Settings CS6: Install failed
ERROR: DW050:  - Recommended Common Fonts Installation x64: Install failed
ERROR: DW050:  - Adobe Extension Manager CS6: Install failed
ERROR: DW050:  - Suite Shared Configuration CS6: Install failed
ERROR: DW050:  - Adobe Player for Embedding x64 3.3: Install failed
ERROR: DW050:  - Adobe WinSoft Linguistics Plugin CS6: Install failed
ERROR: DW050:  - Adobe Bridge CS6: Install failed
ERROR: DW050:  - Adobe After Effects CS6 Support: Install failed
ERROR: DW050:  - AdobeCMaps x64 CS6: Install failed
ERROR: DW050:  - Microsoft Visual C++ 2005 Redistributable Package (x64): Install failed
ERROR: DW050:  - AdobeTypeSupport CS6: Install failed
ERROR: DW050:  - Adobe Audition_AdobeAudition5en_USLanguagePack: Install failed
ERROR: DW050:  - AdobeTypeSupport x64 CS6: Install failed
ERROR: DW050:  - Adobe Mini Bridge CS6: Install failed
ERROR: DW050:  - Adobe Linguistics CS6 x64: Install failed
ERROR: DW050:  - AmericanEnglishSpeechAnalysisModels: Install failed
ERROR: DW050:  - AdobeColorCommonSetRGB CS6: Install failed
ERROR: DW050:  - Adobe Premiere Pro CS6 Support: Install failed
ERROR: DW050:  - Adobe SwitchBoard 2.0: Install failed
ERROR: DW050:  - Photoshop Camera Raw 7: Install failed
ERROR: DW050:  - Adobe Premiere Pro CS6_AdobePremierePro6.0en_USLanguagePack: Install failed
ERROR: DW050:  - AdobeHelp: Install failed
ERROR: DW050:  - Adobe After Effects CS6_AdobeAfterEffects11en_USLanguagePack: Install failed
ERROR: DW050:  - Adobe Encore CS6 Support: Install failed
ERROR: DW050:  - Adobe Linguistics CS6: Install failed
ERROR: DW050:  - DynamiclinkSupport: Install failed
ERROR: DW050:  - Adobe Prelude CS6: Failed due to Language Pack installation failure
ERROR: DW050:  - Adobe Photoshop CS6 International English Language Pack_x64_AdobePhotoshop13-en_GB_x64: Install failed
ERROR: DW050:  - Adobe After Effects CS6 Presets: Install failed
ERROR: DW050:  - AdobeCMaps CS6: Install failed
ERROR: DW050:  - Adobe CSXS Extensions CS6: Install failed
ERROR: DW050:  - Adobe ExtendScript Toolkit CS6: Install failed
ERROR: DW050:  - Adobe Media Encoder CS6 X64: Install failed
System Requirements
now i can't even install cs5.5 master suite!!!!!
Exit Code: 7
Please see specific errors and warnings below for troubleshooting. For example,  ERROR: DW050, DW062 ... WARNING: DW036 ...
- 0 fatal error(s), 100 error(s), 92 warning(s)
----------- Payload: {D1B83970-7269-48BE-8B0E-5120D9327E52} Adobe Player for Embedding 3.1 3.101.0.0 -----------
----------- Payload: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE 1.6.0.0 -----------
----------- Payload: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.0.0 -----------
WARNING: DW036: Payload cannot be installed due to dependent operation failure
----------- Payload: {152B1DA7-A342-4EAA-BD28-25DD7B74AB3C} Suite Shared Configuration CS5.5 2.5.0.0 -----------
ERROR: DW050:  - Adobe ExtendScript Toolkit CS5.5: Install failed
ERROR: DW050:  - GermanSpeechAnalysisModels: Install failed
ERROR: DW050:  - Adobe Dreamweaver CS5.5: Failed due to Language Pack installation failure
ERROR: DW050:  - Adobe Linguistics CS5 x64: Install failed
ERROR: DW050:  - Adobe Premiere Pro CS5.5 Support: Install failed
ERROR: DW050:  - Microsoft_VC80_ATL_x86: Install failed
ERROR: DW050:  - Adobe Photoshop CS5.1 Core_x64: Failed due to Language Pack installation failure
ERROR: DW050:  - Suite Shared Configuration CS5.5: Install failed
ERROR: DW050:  - AdobePDFL x64 CS5: Install failed
ERROR: DW050:  - Microsoft_VC80_MFCLOC_x86_x64: Install failed
ERROR: DW050:  - Adobe Encore CS5.1: Failed due to Language Pack installation failure
ERROR: DW050:  - ItalianSpeechAnalysisModels: Install failed
ERROR: DW050:  - Adobe XMP Panels CS5: Install failed
ERROR: DW050:  - Pixel Bender Toolkit: Install failed
ERROR: DW050:  - Photoshop Camera Raw (64 bit)_6.3_AdobeCameraRaw6.0All-x64: Install failed
ERROR: DW050:  - CSXS Story Extension: Install failed
ERROR: DW050:  - Adobe Dreamweaver CS5.5_AdobeDreamweaver11.5en_USLanguagePack: Install failed
ERROR: DW050:  - Photoshop Camera Raw: Install failed
ERROR: DW050:  - SpanishSpeechAnalysisModels: Install failed
ERROR: DW050:  - Adobe OnLocation CS5.1 Third Party Content: Install failed
ERROR: DW050:  - Adobe Extension Manager CS5.5: Install failed
ERROR: DW050:  - Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll: Install failed
ERROR: DW050:  - AdobeColorCommonSetRGB: Install failed
ERROR: DW050:  - Microsoft_VC80_CRT_x86_x64: Install failed
ERROR: DW050:  - AdobeColorPhotoshop CS5.5: Install failed
ERROR: DW050:  - Adobe Device Central CS5.5: Failed due to Language Pack installation failure
ERROR: DW050:  - Adobe Mini Bridge CS5.1: Install failed
ERROR: DW050:  - AdobeMotionPicture CS5.5: Install failed
ERROR: DW050:  - Adobe Photoshop CS5.1 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64: Install failed
ERROR: DW050:  - AdobeColorCommonSetCMYK: Install failed
ERROR: DW050:  - Adobe After Effects CS5.5 Third Party Content: Install failed
ERROR: DW050:  - Photoshop Camera Raw (64 bit): Install failed
ERROR: DW050:  - Adobe After Effects CS5.5 Template Projects & Footage: Install failed
ERROR: DW050:  - Adobe Media Encoder CS5.5 X64: Install failed
ERROR: DW050:  - Adobe Linguistics CS5: Install failed
ERROR: DW050:  - PDF Settings CS5: Install failed
ERROR: DW050:  - AdobeTypeSupport CS5: Install failed
ERROR: DW050:  - Adobe CSXS Infrastructure CS5.5: Install failed
ERROR: DW050:  - Adobe After Effects CS5.5 Support: Install failed
ERROR: DW050:  - AdobeColorEU CS5.5: Install failed
ERROR: DW050:  - Microsoft_VC90_ATL_x86_x64: Install failed
ERROR: DW050:  - KoreanSpeechAnalysisModels: Install failed
ERROR: DW050:  - Adobe Story: Install failed
ERROR: DW050:  - Microsoft_VC90_MFCLOC_x86_x64: Install failed
ERROR: DW050:  - Microsoft_VC80_ATL_x86_x64: Install failed
ERROR: DW050:  - Microsoft_VC90_CRT_x86_x64: Install failed
ERROR: DW050:  - Adobe Device Central CS5.5_DeviceCentral3.5LP-en_GB: Install failed
ERROR: DW050:  - AdobeCMaps x64 CS5: Install failed
ERROR: DW050:  - AdobeTypeSupport x64 CS5: Install failed
ERROR: DW050:  - Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All: Install failed
ERROR: DW050:  - Microsoft_VC90_MFC_x86_x64: Install failed
ERROR: DW050:  - AdobeColorJA CS5.5: Install failed
ERROR: DW050:  - FrenchSpeechAnalysisModels: Install failed
ERROR: DW050:  - AdobeOutputModule: Install failed
ERROR: DW050:  - Adobe Audition_AdobeAudition4en_USLanguagePack: Install failed
ERROR: DW050:  - Adobe Premiere Pro CS5.5 Functional Content: Install failed
ERROR: DW050:  - Adobe WinSoft Linguistics Plugin CS5 x64: Install failed
ERROR: DW050:  - AdobePDFL CS5: Install failed
ERROR: DW050:  - AdobeCMaps CS5: Install failed
ERROR: DW050:  - Adobe CSXS Extensions CS5.5: Install failed
ERROR: DW050:  - Adobe Encore CS5.1_AdobeEncore5.1en_USLanguagePack: Install failed
ERROR: DW050:  - Adobe After Effects CS5.5: Failed due to Language Pack installation failure
ERROR: DW050:  - Adobe After Effects CS5.5 Presets: Install failed
ERROR: DW050:  - JapaneseSpeechAnalysisModels: Install failed
ERROR: DW050:  - Adobe After Effects CS5.5 Third Party Content Wrapper: Install failed
ERROR: DW050:  - Adobe After Effects CS5.5_AdobeAfterEffects10.5en_USLanguagePack: Install failed
ERROR: DW050:  - Microsoft_VC80_MFC_x86_x64: Install failed
ERROR: DW050:  - ph: Install failed
ERROR: DW050:  - Adobe ReviewPanel CS5.5: Install failed
ERROR: DW050:  - Required Common Fonts Installation: Install failed
ERROR: DW050:  - AdobeColorVideoProfilesAE CS5.5: Install failed
ERROR: DW050:  - Adobe Player for Embedding x64 3.1: Install failed
ERROR: DW050:  - HIL Help Search: Install failed
ERROR: DW050:  - Adobe Player for Embedding 3.1: Install failed
ERROR: DW050:  - CS5.5 Master Collection: Install failed
ERROR: DW050:  - SiteCatalyst NetAverages CS5.5: Install failed
ERROR: DW050:  - Recommended Common Fonts Installation: Install failed
ERROR: DW050:  - AdobeColorNA CS5.5: Install failed
ERROR: DW050:  - AdobeJRE: Install failed
ERROR: DW050:  - AdobeColorVideoProfilesCS CS5.5: Install failed
ERROR: DW050:  - Adobe Bridge CS5.1: Install failed
ERROR: DW050:  - Adobe Photoshop CS5.1 Support: Install failed
ERROR: DW050:  - Adobe Premiere Pro CS5.5: Failed due to Language Pack installation failure
ERROR: DW050:  - Adobe Encore CS5.1 Library: Install failed
ERROR: DW050:  - Adobe Dreamweaver Widget Browser: Install failed
ERROR: DW050:  - InternationalEnglishSpeechAnalysisModels: Install failed
ERROR: DW050:  - Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All: Install failed
ERROR: DW050:  - Adobe Premiere Pro CS5.5_AdobePremierePro5.5en_USLanguagePack: Install failed
    May 18, 2012 12:26 AM   in reply to leslie wand
    Well, did you do anything to that folder?
    Mylenium
    May 18, 2012 2:48 AM   in reply to leslie wand
    This refers to your global "All Users" folder. On Win Vista/ Win7 it's a hidden folder in C:\Users\Default. I'd check that, in particular file permissions. Also make sure to make your security stuff behave. It may be all too eagerly "protecting" this folder from changes.
    Mylenium
  • Sharad Saxena
    Apr 30, 2010
    May 18, 2012 5:46 AM   in reply to leslie wand
    Please do ensure the permission/existence of following folder as well as suggested by Mylenium -
    (Vista/Win7 onwards) C:\Users\Public\Documents
    (XP) C:\Documents and Settings\All Users\Documents
  • Sharad Saxena
    Apr 30, 2010
    May 21, 2012 12:01 AM   in reply to leslie wand
    Actually had it been just folder missing case installer might have recovered from that. It seems that registry entries of your machine are also missing. So adding folders manually may not resolve your issue.
    Those who have faced this issue on Windows7 have tried repairing their Windows registry entries. You may try the solutions posted at (http://www.sevenforums.com/tutorials/69334-public-folders-restore.html) if you wish.
  • Sharad Saxena
    Apr 30, 2010
    May 21, 2012 1:51 AM   in reply to leslie wand
    Thanks for the update and please keep us posted.
