Dear all,
I am try to incorporate a datepicker from jquirey some thing like http://jqueryui.com/demos/datepicker/#date-range
How can in corporate in website plz help me. I am download entire thing but lots of thing clubed.
Regards
Manoj
ya i am try it, some problem with coding because nothing happend with calander field?
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<title>jQuery UI Datepicker - Select a Date Range</title>
<link type="text/css" href="css/ui-lightness/jquery-ui-1.7.3.custom.css" rel="stylesheet" />
<script type="text/javascript" src="js/jquery-1.3.2.min.js"></script>
<script type="text/javascript" src="js/jquery-ui-1.7.3.custom.min.js"></script>
<script type="text/javascript">
$(function(){
// Accordion
$("#accordion").accordion({ header: "h3" });
// Tabs
$('#tabs').tabs();
// Dialog
$('#dialog').dialog({
autoOpen: false,
width: 600,
buttons: {
"Ok": function() {
$(this).dialog("close");
"Cancel": function() {
// Dialog Link
$('#dialog_link').click(function(){
$('#dialog').dialog('open');
return false;
// Datepicker
$('#datepicker').datepicker({
inline: true
// Slider
$('#slider').slider({
range: true,
values: [17, 67]
// Progressbar
$("#progressbar").progressbar({
value: 20
//hover states on the static widgets
$('#dialog_link, ul#icons li').hover(
function() { $(this).addClass('ui-state-hover'); },
function() { $(this).removeClass('ui-state-hover'); }
</script>
</head>
<body>
<div class="demo">
<label for="from">From</label>
<input type="text" id="from" name="from"/>
<label for="to">to</label>
<input type="text" id="to" name="to"/>
</div><!-- End demo -->
<div class="demo-description">
<p>Select the date range to search for.</p>
</div><!-- End demo-description -->
</body>
</html>
when these files are stored in your according directory/ies it should work.
Use an offline browser or load it up to your server to control it.
Hans-Günter
I think it is because you're missing the CSS file that defines the date picker popup styles.
<link rel="stylesheet" href="../demos.css">
as found in http://jqueryui.com/demos/datepicker/date-range.html
Hello Manoj,
in addition to Sudarshan's hint about the missing "<link rel="stylesheet" href="../demos.css">" you should have a look whether you could download all the necessary files, needed for the datepicker. Here ist the original source code, maybe you could work first/again with it:
<!DOCTYPE html>
<html lang="en">
<head>
<link rel="stylesheet" href="../../themes/base/jquery.ui.all.css">
<script src="../../jquery-1.7.2.js"></script>
<script src="../../ui/jquery.ui.core.js"></script>
<script src="../../ui/jquery.ui.widget.js"></script>
<script src="../../ui/jquery.ui.datepicker.js"></script>
<script>
$(function() {
var dates = $( "#from, #to" ).datepicker({
defaultDate: "+1w",
changeMonth: true,
numberOfMonths: 3,
onSelect: function( selectedDate ) {
var option = this.id == "from" ? "minDate" : "maxDate",
instance = $( this ).data( "datepicker" ),
date = $.datepicker.parseDate(
instance.settings.dateFormat ||
$.datepicker._defaults.dateFormat,
selectedDate, instance.settings );
dates.not( this ).datepicker( "option", option, date );
</script>
</head>
<body>
<div class="demo">
</body>
</html>
Here my DW with your source code:
and here with the original source code:
As you can see that in your code are only three advices, the original code "wants" six.
... and don't forget to control the pathes!
Hans-Günter
thanks hans-g. i am really sorry to late reply.
Please chek my link some alignment problem or some code is missing http://www.newtonclients.com/date/date-range.html
Master link
how can i rectify
