Date picker
May 1, 2012 1:59 AM
Dear all,
I am try to incorporate a datepicker from jquirey some thing like http://jqueryui.com/demos/datepicker/#date-range
How can in corporate in website plz help me. I am download entire thing but lots of thing clubed.
Regards
Manoj
    May 1, 2012 2:43 AM   in reply to manojb05
    Hello Manoj,
    nice to see you! What concerns "datepicker": can you see "New window"?
    Clicking there you will get a website only with the datepicker. From there you could copy the necessary parts of the source code:
    Good luck!
    Hans-Günter
    May 1, 2012 7:00 AM   in reply to manojb05
    Hello Manoj,
    click his download menu, clik download again in th new website and you will see this:
    Click "speichern" (you will see store I think) > done.
    Hans-Günter
  • Sudarshan Thiagarajan
    Oct 15, 2010
    May 1, 2012 7:29 AM   in reply to manojb05
    Post an active link to your page.
    May 1, 2012 7:30 AM   in reply to manojb05
    when these files are stored in your according directory/ies it should work.
    <link type="text/css" href="css/ui-lightness/jquery-ui-1.7.3.custom.css" rel="stylesheet" />
                        <script type="text/javascript" src="js/jquery-1.3.2.min.js"></script>
                        <script type="text/javascript" src="js/jquery-ui-1.7.3.custom.min.js"></script>
    Use an offline browser or load it up to your server to control it.
    Hans-Günter
    Oct 15, 2010
    May 1, 2012 7:38 AM   in reply to manojb05
    I think it is because you're missing the CSS file that defines the date picker popup styles.
    <link rel="stylesheet" href="../demos.css">
    as found in http://jqueryui.com/demos/datepicker/date-range.html
    May 2, 2012 5:58 AM   in reply to manojb05
    Hello Manoj,
    in addition to Sudarshan's hint about the missing "<link rel="stylesheet" href="../demos.css">" you should have a look whether you could download all the necessary files, needed for the datepicker. Here ist the original source code, maybe you could work first/again with it:
    <!DOCTYPE html>
    <html lang="en">
    <head>
    <meta charset="utf-8">
    <title>jQuery UI Datepicker - Select a Date Range</title>
    <link rel="stylesheet" href="../../themes/base/jquery.ui.all.css">
    <script src="../../jquery-1.7.2.js"></script>
    <script src="../../ui/jquery.ui.core.js"></script>
    <script src="../../ui/jquery.ui.widget.js"></script>
    <script src="../../ui/jquery.ui.datepicker.js"></script>
    <script>
    $(function() {
      var dates = $( "#from, #to" ).datepicker({
       defaultDate: "+1w",
       changeMonth: true,
       numberOfMonths: 3,
       onSelect: function( selectedDate ) {
        var option = this.id == "from" ? "minDate" : "maxDate",
         instance = $( this ).data( "datepicker" ),
         date = $.datepicker.parseDate(
          instance.settings.dateFormat ||
          $.datepicker._defaults.dateFormat,
          selectedDate, instance.settings );
        dates.not( this ).datepicker( "option", option, date );
    </script>
    </head>
    <body>
    <div class="demo">
    <label for="from">From</label>
    <input type="text" id="from" name="from"/>
    <label for="to">to</label>
    <input type="text" id="to" name="to"/>
    </div><!-- End demo -->
    <div class="demo-description">
    <p>Select the date range to search for.</p>
    </div><!-- End demo-description -->
    </body>
    </html>
    Here my DW with your source code:
    and here with the original source code:
    As you can see that in your code are only three advices, the original code "wants" six.
    ... and don't forget to control the pathes!
    Hans-Günter
    May 21, 2012 2:37 AM   in reply to manojb05
    Hello manoj,
    you should control control your pathes  > ../ or ../../ eg.
    Hans-Günter
    P.S.
    Cant see a succes of my former maeesage.
    May 21, 2012 4:11 AM   in reply to manojb05
    look a bit more attentively at my screenshots from above
