Chelsea66
Hyperlinks not working on vertical on iPad
May 21, 2012 4:42 AM
I am putting together an iPad app and have set the hyperlinks in both the H and V files within InDesign but when I put into folio builder/Articles and add h layout then add v layout, it all views ok and the horizontal layout hyperlinks work but not the vertical. Can anybody please help?
Brian
    May 21, 2012 6:16 AM   in reply to Chelsea66
    Did you copy and paste the hyperlinks from the H orientation to the V?
    as in, not set them up on the V doc
    sometimes the interactive features aren't copied along with the content
    Cheers
    Tim
    May 21, 2012 7:05 AM   in reply to Chelsea66
    this is through the hyperlinks panel as a pose to the buttons panel??
    Cheers
    Tim
    May 21, 2012 7:13 AM   in reply to Chelsea66
    You must navto:// to an article name, not a file name.
    Bob
  • Bob Bringhurst
    May 29, 2007
    May 21, 2012 7:13 AM   in reply to tim.hughes
    The navto link needs to point to the article name as it appears in the Folio Builder panel, not the file name.
    May 21, 2012 8:12 AM   in reply to Bob Bringhurst
    Anyway also with link to article name, the links works in a random state, in the same page some works and some not. When the links don't works I simply update the article (without touch the navto link) and after this works. This seem a bug.
    May 21, 2012 8:42 AM   in reply to Siduno
    I have done hundreds of links, I know how to do link. But sometimes the link don't work. If I update the same folio without any modification, the link works. I call this a bug.
    May 21, 2012 8:49 AM   in reply to Chelsea66
    Brian -
    Make sure you did not cut and paste a link tagged as a Shared Hyperlink Destination.
    If you hover over the non-working link in the hyperlinks panel...see if there is a reference to the document name of the alternate layout immediately preceding the "navto://"
    If so then you have picked up a Shared Destination.
    Delete the existing link and recreate it without tagging it as a shared resource.
    You can then copy and paste from one doc to another...just as long as the link remains un-tagged as a shared resource
