I Tunes sync failed to install
May 17, 2012 10:46 AM
I have been trying desperately to figure this out and cannot. I'm testing a simple two button app created using Flash CS5.5 publishing to AIR for IOS, I get no errors, the adl playback is fine, my trace statements work yet when I drag the .ipa into Itunes I see it in my app section, soon as I go to sync I get the msg
I Tunes Sync
appname failed to install.
Very very frustrating as I checked every possible thing I could think of, errors in the actionscript etc.
anybody ????????
RD
    May 17, 2012 7:09 PM   in reply to mentlity
    Is the Device UDID in the Provisioning Profile?
    What device are you testing on?
    What does your application descriptor look like?
    May 18, 2012 8:19 AM   in reply to mentlity
    The app descriptor, I mean the XML file that you're using to build.
    If its failing to install I don't think it has anything to do with your code as it's not getting that far.
    Are you targeting the correct type of .ipa when you build?
    May 18, 2012 9:53 AM   in reply to mentlity
    This part is wrong:
    com.dagwaremediaM73KBC8LMX.ralphiedee
    The M73KBC8LMX bit should not be there. Maybe you meant this:
    com.dagwaremedia.ralphiedee
    or:
    com.dagwaremedia.newiostestone
    May 21, 2012 7:12 AM   in reply to mentlity
    It's not getting as far as your code - it's the provisioning profile and build. I had the same problem - installed on iPad 2 and iPhone 4, but not a 4S until the icons were available.
    Instead of iTunes, deploy your App using TestFlight - that will make sure you have the correct devices UDID's in your provisioning profile.
    Just register and upload your build - ignore all the 'SDK' stuff.
    Think the URL is testflightapp.com
    May 22, 2012 7:06 AM   in reply to mentlity
    I don't use an asterisk in the app name.
    I'm using Flash Develop on Windows, and building my .ipa's using the command line adt command.
    I don't know what hardware you're using, but I followed this:
    http://www.emanueleferonato.com/2011/09/22/creation-of-an-iphone-app-w ith-flash-and-without-a-mac-for-all-windows-lovers/
