chateau21
Lightbox - insert into page
May 21, 2012 10:16 AM
Tags: #image #mac #dreamweaver #images #code #lightbox #dw
Hello all,
I am new to dreamweaver but have successfully created most of my site.
It is an art based website (not yet live) so I have made a lightbox of images.
I created this in a new html page to check it all worked fine, and it works perfectly.
I have a template page for the header etc that is represented on each individual page - these are sepreate html pages (contact, about etc)
I simply want my lightbox to feature on my 'illustration portfolio' page but I can't work out how.
There isn't the usual <head> <body> places to paste on this illustration page only <title> and <content> and pasting the code into these places doesn't work.
I can only see the usual <head> <body> areas to insert code in the template page - but how do I connect this only to the illustration page?
Totally stuck!
I'd really appreciate any help!
    May 21, 2012 10:40 AM   in reply to chateau21
    You can safely add links to Lightbox Scripts & CSS files to your Template <head>.   It won't effect other pages until the the script is actually called on by the content in your <body>.
    Nancy O.
    Alt-Web Design & Publishing
    Web | Graphics | Print | Media  Specialists
    http://alt-web.com/
    May 21, 2012 10:56 AM   in reply to chateau21
    The same way you did in your lightbox TEST page.
    Nancy O.
    http://alt-web.com/
    May 22, 2012 10:28 AM   in reply to chateau21
    You created a Lightbox test page, right?  It works in preview, right?
    Open Lightbox test page in Code View.
    There are two parts to most widgets:
    1. Code inside the <head> tags = links to supporting Scripts, external CSS files & function code to make the widget work.
    2. Code inside the <body> tags =  div tags & images.
    Relevant code from Part 1 goes into Template.dwt file.
    Relevant code from Part 2 goes into Portfolio.html file.
    HTML & CSS Tutorials - http://w3schools.com/
    Working with jQuery  -  http://docs.jquery.com/How_jQuery_Works
    Nancy O.
