hello everyone
im using PrPro CS6. im having mutiple issues
I rendered my whole video, there is no red render bars but i have some green . Every time export it you tube template. I see " ERROR COMPILING VIDEO- UNKNOWN ERROR".
I HAVE NO IDEA WHAT IS GOING. PLEASE HELP ME OUT HERE
1. IM USING VERSION 6.0.0 319 MC:264587 CS6
2. IT IS UPDATED TO LATEST UPDATE
3. WINDOW 7 64 BIT
4. SOURCE FOOTAGE MXF FILES FROM CANON XF 305 CAMERA AT 1920 BY 1080 30P 50MBPS
5.ERROR COMPILING MOVIE - UNKNOWN ERROR
6. I WAS EXPORTING THE PROJECT TO H.264 YOU TUBE UPLOAD
7. NO THIRD PARTY EFFECTS JUST THE ONE FROM PR PRO CS6
8. NO MERCURY PLAYBACK
9 ONLY WHEN EXPORTING
HERE IS THE IMAGE OF MY PROJECT:
Most likely that it is then. You need to trim the end of first clip and beginning of next clip, then butt them together, so there is "overlap", or extra frames available for the transition between the clips. One way to do this is to put the mouse pointer on the end of the clip and then press CTRL key, bracket will change then you can trim end of clip with a Ripple Edit (everything after moves as you adjust). Quucikly trim ins and outs this way so you can add transition
jeff
For those Clips, you have too few Frames, past the Out Point, or before the In Point. Those are called Handles. This ARTICLE will go into more detail.
Good luck,
Hunt
You can not transition between two clips if there are no frames to make the transition with. eg "Handles"
You can not make "handles" but you can make your in and out points on the clips at a different place so as you have spare overlap frames ( which become the handles).
The Transition effect uses these spare frames to build the effect
SOULTION for others who are in same situation:
First update your software to the latest update.
I believe you have more than one clip.
Make sure you don't have a one-frame gap between any clips, these can be invisible until you zoom in closer
At the end and begining of the clip you should have little grey triangle shape.
They are called handles, meaning extra space at end point and at begining. Usaually for transition.
If you dont see it on both clips (as in picture above) then the one clip which is misiing need to be trimed little or more until handles disappear or some time you see full triangle (as in picture).
Do same if there are more.
Then just try to export the ending where clips attach each other.
Set in and out points as I did in the picture above.
Export and make sure to choose sequence in and out setting.
I hope it works. I dont use this software anymore. I had a trail version. Used for two weeks. Every day same problem then finally figured it out and moved back to Edius 6. Thanks
