When NEF (raw files) in LR4 are edited, it generates two additional files: tiff and jpg (by "save as"). Later on, when I want to furhter edit those images, how do I start with? Obviously, I could re-edit from history panel of the orignal NEF file or tiff file using CS5. I wonder which approach is more efficient or convenient?
I'm not quite sure how to answer the question because I'm unclear about your workflow. My typical workflow is to import the raw images and work exclusively on those. In most instances, I find that I can do all of my editing in Lightroom. The only time I create a JPEG or TIF image is if I need that image format for a specific purpose. For instance, if I want to e-mail an image, I will export a JPEG image for that purpose. When it has been emailed then I usually delete the image because it isn't needed anymore. Then, if I decide later on to further edit the raw image I just start with the raw image and make whatever changes are needed. Sometimes I will create a virtual copy so that I can keep what I have already done.
hummer777,
You have to give a bit more info and describe your workflow in more detail. You say "When NEF (raw files) in LR4 are edited, it generates two additional files: tiff and jpg (by "save as")." As there is no <Save as> command in Lr - what do you do? Edit your Raw images in CS5? And why would you create two files? And why would you <Save as> instead of simply <Save>?
Generally speaking, you do not need to edit your NEF files in CS5. You can do that in Lr4 and - in most cases - easier and better than in CS5.
So please explain your workflow in detail and the reasons why you chose to work in such a way, in order that we can help you.
I am a weekend hobbyist with Nikon cameras.
What I do normally is initially to edit raw files in LR4. Then, send them to photoshop CS5 by Edit In Photoshop CS5. While sending them to photoshop, LR4 generates tif files (e.g., DSC_0001-Edit.tif). I hate tif files because of their huge file size. In the photoshop, I edit them again if necessary. I resize them to 1920 x 1270 px size before saving as jpg format. Generally, I use them for screen saver (built in Windows 7). This size fits to my monitors. If I like some images, I sent them to MPIX to print.
Later, I found that some images are less than satisfaction. I feel like to re-edit them. So I am wondering whether I should edit from edit.tif files using photoshop or start from some steps in history panel of those NEf files in LR4. Since I am new to LR4, I am looking for your suggestion.
The only reason you would retain a TIF file is if you did some work in Photoshop that you could not do in Lightroom. That doesn't happen to me very often. Most of the time I do all of my editing in Lightroom, clear to the finished image. So TIF files or JPEG files are only created for a specific purpose. And once that purpose is fulfilled (e-mail, printing, etc.) That file is deleted. The only file I keep in most instances is the original raw file. There is not a separate database for TIF files so I don't understand your question. If you delete the file it is removed from the catalog.
>.So TIF files or JPEG files are only created for a specific purpose. And once that purpose is fulfilled (e-mail, printing, etc.) That file is deleted. The only file I keep in most instances is the original >raw file. There is not a separate database for TIF files so I don't understand your question
I have a hummingbird folder and also its LR hummingbird catalog. Upon reading your post, I deleted all hummingbird tif files (which were generated when edited NEF files were sent to photoshop by "Edit In Photoshop CS5"0 from hummingbird folder. There is no single tif file in the folder. But I kept the original NEF and jpeg files.
When the hummingbird catalog was opened in LR4, the libray grid still shows all deleted tif images but with a question mark in the images, indicating that these tif files are missing.(see the attachment below).
This indicates that simply deleting tif files does not remove their database from the hummingbird catalog. This explains my previous question about how to delete all information related to tif files from hummingbird catalog database. .
If you didn't delete the images from within Lightroom, then you are correct. The database still thinks those images are there, and will continue to display the preview. But if you will right-click on the folder, one of the options is to synchronize that folder. If you click on that option those images will disappear.
