taglife
Why can not receive auto update notification?
May 21, 2012 3:25 PM
Tags: #auto #adobe #flash #update #windows #xp #check #auto_update
    May 21, 2012 9:30 PM   in reply to taglife
    Can you post the contents of your FlashInstall.log file in
    • C:\Windows\system32\Macromed\Flash (if you are on a 32-bit system)
    • C:\Windows\syswow64\Macromed\Flash (if you are on a 64-bit system)
    May 21, 2012 9:34 PM   in reply to taglife
    Also, in Control Panel, Administrative Tools, Scheduled Tasks, is Adobe Flash Player Updater enabled?
  • Chris Campbell
    May 4, 2010
    May 23, 2012 6:56 PM   in reply to taglife
    The old updater (ie. not the new silent auto update service) is on a 7-day check interval and will only notify you after a reboot of your system.
  • Chris Campbell
    May 4, 2010
    May 23, 2012 7:01 PM   in reply to Chris Campbell
    It should be noted that while both Mac and Win have a 7 day interval, the Mac does not require a reboot of the system for the notification to appear.
  • Chris Campbell
    May 4, 2010
    May 31, 2012 3:05 PM   in reply to taglife
    To confirm, have you also rebooted your system?  Can you check to see if you have a mms.cfg file in your C:\WINDOWS\system32\Macromed\Flash\ folder and if so, please post the contents of the file in a reply?
  • Chris Campbell
    May 4, 2010
    Jun 1, 2012 6:11 PM   in reply to taglife
    Thanks.  Looking for additional tests that you can try.  Will let you know what I hear.
  • Chris Campbell
    May 4, 2010
    Jun 6, 2012 5:12 PM   in reply to Chris Campbell
    Ok, I found out that you can try to trigger this notification manually.  To do this, open a command line prompt and go to c:\windows\system32\macromed\flash.  Once there, run "FlashUtil -update activex" or "FlashUtil -update plugin" depending on the type of Flash Player you'd like to update.  That should trigger the notification.
