Export the overprint preview as jpeg/pdf.
May 21, 2012 6:23 AM
Hi all,
Is there any way to export the overprint preview as jpeg/pdf ?
Thanks.
    May 21, 2012 4:08 PM   in reply to AI_learner
    Save a screen shot. How you make it depends on your OS.
    In Illustrator 15 Save for Web shows overprints…
    Or you can use Flatten Transparency. If all you have are overprints and all objects have 100% Normal opacity then you need to force flattening. Draw a white rectangle over everything and set it to Multiply.
    May 22, 2012 6:49 AM   in reply to AI_learner
    May 22, 2012 7:23 AM   in reply to AI_learner
    CS 6 also shows thee preview in save for the web and in Acrobat I believe if you use output preview in the productions tools you see see the preview as well but only while the output preview window is opened.
