Animation Moving in Slow Motion
May 21, 2012 6:45 PM
Hello,
  I've encountered yet another problem. I'm working with the Armature on one layer of the Time Line and animating each pose over 10 frames. I made a 40 frame movie that plays much longer than the nearly two second span. Everything appears in slow motion!
  My animations are set to 24fps, but they are moving at least 10 times slower. This happens within Flash and in the exported swf files.
  I'm getting errors dealing with "text field variable names" and "Symbol 'fps' ".
I've included a few pics of the errors.
  Does anybody know what these are and how to remedy them?
Thank you for any comments on the matter,
     Mike
    May 22, 2012 4:31 AM   in reply to flashAnimate
    To help explain the errors you should show the code that is contained in the fps moviewclip and indicate the line numbering relative to the errors.
    The second image you show would seem to indicate you have taken an AS1/2 file and are trying to use it as an AS3 file, wherein variable name is assigned for a textfield in the properties panel.
    May 22, 2012 1:07 PM   in reply to flashAnimate
    My only guess is that you have copied content from another file that is an AS1/2 design.  Otherwise the errors would not indicate AS1/2 code and features that AS3 will not allow.  If you are opening the file as an AS3 file then chances are you won't find the var issue because AS3 Fash does not provide an option for it... if you could open the file as an AS2 file you might find it.
    What happens when you double click on any of the erros that are shown?
    Maybe are you using a Virtual Cam or copied some movie clip from another project
