pawel.nejman
Flash CS6 crashes while loading
May 17, 2012 8:01 AM
Tags: #flash #crash #cs6
Hi everyone,
I have problem with loading fresh installed Flash CS6.
Yesterday I reinstalled system (win7, 64bit), and start downloading and installing Adobe programs. Everything worked fine, Flash started, I made few banners, and gone to sleep.
Today, when I started computer, I got notification that there are some updates, also for Flash.
After installing that I can't start Flash. I'm clicking on icon, I see welcome screen, and while 'Initializing fonts' everything just dissapear. No error, no alert, nothing.
Any idea?
Pawel
    May 17, 2012 10:05 PM   in reply to pawel.nejman
    Please follow this process before launching the application.
    1. Launch the application
    2. Immediately press the CTRL +SHIFT+ ALT (Before open the intial screen)
    3. Delete the professional setting Yes/ no pop up would appear
    4. Select YES
    Please let me know if its works for you.
    May 21, 2012 12:29 PM   in reply to pawel.nejman
    I seem to be having this same exact issue on Windows 7 (64-bit). Fresh installation that started once, and then crashed on subsequent loads. Resetting the preferences, as suggested does the trick, but future launches continue to crash while the Fonts are initializing.
    Any ideas as to what to do to make this a permanent "stick"?
    May 21, 2012 12:35 PM   in reply to MacGyver97
    Actually, just solved the problem (permanently):
    If you go to:
    C:\Users\«YourUserName»\AppData\Local\Adobe\Flash CS6\en_US\Configuration
    there is a fontinfo.txt file. Open this in notepad and delete everything in it and save it, but before starting Flash again, change the properties of that fontinfo.txt file to read only so Flash can't overwrite it again.  Seems to clear up the loading crash issue.
    May 21, 2012 7:45 PM   in reply to MacGyver97
    Hi
    Could you please share fontinfo.txt file.
    May 22, 2012 9:27 AM   in reply to pawel.nejman
    @ pawel.nejman: You're welcome! Glad I could help. I remembered once encountering this problem with Flash a few versions ago. Looks like it persists, depending on what fonts or number of fonts installed on your system
    @jose_flash_ookken: There's nothing to share since the file is going to end up being a 0KB (empty) file. Just locate it on your hard drive, and follow my instructions. The problem could stem from some fonts that have strange characters in their font names (like "!"). !PaulMaul is an example.
    May 23, 2012 12:52 AM   in reply to MacGyver97
    Thanks, I had the same problem. Crashed on load (while installing fonts). Was driving me crackers.
    You're brilliant!
    May 23, 2012 10:54 PM   in reply to bernromy2
    Hi All,
    We are investigating if this is a possible bug. Can some of you who have encountered the bug confirm the following?
    • On your Win7 machine, have you turned your UAC on?
    • Is Firewall enabled on your systems?
    • Did you clear Flash Pro preferences and set your systems to a clean state before you installed the update?
    Please let us know.
    Suhas Yogin
    May 24, 2012 1:31 PM   in reply to Suhas Yogin
    Hi Suhas,
    1. UAC is off
    2. Firewall is on (using Windows 7 Firewall)
    3. System was brand new, and even after repeatedly clearing the Preference files for Flash, I kept crashing. Note that this bug has appeared in the past for me on other systems with earlier versions of Flash. Probably just a distaste for some of the fonts I have installed.
    May 24, 2012 9:23 PM   in reply to MacGyver97
    Thanks, guys! However, this doesn't get us too far ahead. Could you upload and share your log files with me?
    Suhas Yogin
    May 30, 2012 5:09 AM   in reply to pawel.nejman
    Same problem here.  Even Flash CS5.5 does not work.
    I really need this fixed asap!
    I tried to look in the fontinfo.txt file for weird characters, but could not find any.  The file itself as the configuration folder is with "read-only" disabled. So the answer for the topic is not correct.
    Are there some other suggestions maybe?
    Thank you.
    Jun 1, 2012 7:12 AM   in reply to brdcphoto
    @brdcphoto,
    Did you actually delete everything in the fontinfo.txt file, or just look for weird characters? I don't know for a fact that weird characters in the file fail to cause Flash to launch. It could also be the sheer number of fonts too if the .txt file is large enough. Empty the .txt file, save as Read Only (you need to ENABLE this option, not Disable as in your post), and then try restarting Flash.
    My fix works on Flash CS5.5 and CS6.
    Jun 1, 2012 7:14 AM   in reply to Suhas Yogin
    Suhas,
    What is the file location path to the log file that you're asking for?
    Thanks.
    Jun 5, 2012 1:00 AM   in reply to MacGyver97
    Hello,
    The logs can be found at:
    Win: Program Files\Common files\Adobe\Installers or \Documents and Settings\<user>\Local Settings\ApplicationData\Adobe\AAMUpdater\1.0\
    Mac: /Library/Logs/Adobe/Installers or ~/ Library/ApplicationSupport/Adobe/AAMUpdater/1.0/
    Suhas Yogin
    Jun 5, 2012 12:53 PM   in reply to MacGyver97
    This worked!  For CS5 and CS6!
    Thx
    Jun 23, 2012 3:23 PM   in reply to MacGyver97
    Thanks MacGyver....saved me a lot of head scratching!!
    Sep 19, 2012 2:32 PM   in reply to Jose_Flash_ookken
    GOD Bless you ... T _ T all f***n day trying ... just now mi free ...
    Mar 18, 2013 9:55 PM   in reply to Jose_Flash_ookken
    I did this and it worked Flash CS 6 is working fine but one issue i am facing after doing this that is while working on any file whenever i am attempting to change the font property (like from arial to somethign else) it is being hanged for few moments like 1 to 2 minutes.
    Can you also help in solving this issue.
    Apr 29, 2013 5:05 AM   in reply to MacGyver97
    Worked for me. Awesome ! Thanks !
