Maxwithershins
Installation Problems
Jun 6, 2012 2:01 PM
Tags: ##cc_aam_acorbatx
During Craetive Cloud installation, Acrobat X Pro installed "with errors." Neither Acrobat nor Distiller will launch. I clicked "retry" in Application Manager several times; no joy. Suspecting a download file corruption, I tried to re-download it. But, since Application Manager 'thinks' it's been installed, I am unable to do this. What is the solution??? TIA...
    May 19, 2012 10:43 AM   in reply to Maxwithershins
    Hi
    If you're on a Mac, this might help. The Acrobat X Uninstaller in the Acrobat folder doesn’t remove the application completely. As a result AAM identifies it as still installed. You'll want to use the uninstaller in the Applications > Utilities > Adobe Installers and run the Acrobat X Pro uninstaller from this location. The uninstaller is named "Acrobat X Pro. We have a tech doc here:
    http://helpx.adobe.com/creative-cloud/kb/cant-install-acrobat-aam.html
    This is currently a work around but we are indeed investigating this issue. If you are not on a Mac, please let me know.
    Victoria
    May 19, 2012 12:11 PM   in reply to vselwyn
    Hi Victoria I too am experiencing the similar problem am running windows 7 Ultimate 64bit. Can you please direct me to the windows version of the workaround. Gerry
    May 19, 2012 1:11 PM   in reply to Maxwithershins
    It appears another customer may have encountered a similar issue. http://forums.adobe.com/message/4407050 Are you seeing the same error? Perhaps try logging in as root in safe boot and seeing if that perhaps corrects the issue?
    May 20, 2012 7:49 AM   in reply to Maxwithershins
    Could you send your contact information to me at cfirst@adobe.com and I'll have someone follow up with you on Monday? Thanks so much for your patience.
    Victoria
    May 22, 2012 4:20 PM   in reply to Maxwithershins
    My recommendation would be
    - Uninstall all CS6 app via Mac HD > Applications > Utilities > Adobe Installers
    Uninstall Acrobat X (if listed) then all CS6 products
    - Download and run the CS6 Cleaner Tool and remove everything CS6 related
    - Reboot
    - Reinstall Acrobat X through AAM and install updates
    - Reinstall remaining CS6 products
    If this method doesn't work for you the best bet would be to contact and work with our technical support department  directly
    -Dave
    May 22, 2012 5:38 PM   in reply to Maxwithershins
    You might try replacing the original Media_db.db and pdb.db files in their original locations prior to running the Cleaner Tool. If this fails you'll need to manually uninstall everything working with our support.
    May 23, 2012 12:26 PM   in reply to Maxwithershins
    Thanks for the update, keep us posted
    Jun 4, 2012 9:31 AM   in reply to Maxwithershins
    Just so you ALL know, especially the Adobe team. I am having the same issue. So ... I can just hope you'll find a solution quickly.
    Aug 4, 2012 3:09 PM   in reply to borisgeissler83
    Hey did anyone ever come to any resolution on this? I'm troubled by this problem as well!!!
    Sep 18, 2012 2:13 PM   in reply to Maxwithershins
    Has this been figured out already? I'm currently having the same issue and I can't open Acrobat :s
Bookmarked By (1)
