U44M1P7 error on CS5 Adobe Extension Manager Update
May 21, 2012 7:44 AM
I received the error:  U44M1P7  on attempting to update CS6 Adobe Extension Manager on Creative Cloud.  How do I resolve this?
Charles Schwartz, MD
cschwartz@nni.com
    May 21, 2012 8:25 AM   in reply to cschwartz@nni.com
    I am having the same problem with CS6.
    May 21, 2012 3:02 PM   in reply to buidlmacha
    Moving this discussion to the Extension Manager forum.
    May 21, 2012 6:46 PM   in reply to buidlmacha
    Receiving this message: Adobe Extension Manager CS6 Update Installation failed. Error Code: U44M1P7
    May 21, 2012 7:39 PM   in reply to rrc907
    Which OS are you using? Please make sure you have the Extension Manager CS6 GM build installed. The version number should be 6.0.0.412 in About dialog box.
    You can download the updater installer from http://www.adobe.com/downloads/updates/ then run it manually to update Extension Manager.
    May 21, 2012 9:47 PM   in reply to Carl Sun
    Running OS 10.7.4 on my Mac and I try your download and got this message:
    Installation failed. Error Code: U44M2P7
    Roy Chamberlin
    May 21, 2012 9:55 PM   in reply to rrc907
    Running OS 10.7.4 and am getting this message after manually downloading the Extension Manager update 6.0.1:
    May 22, 2012 1:19 AM   in reply to rrc907
    I tried to update Extension Manager CS6 on Mac OS X 10.7.4 and the update was successful. Please follow these steps to generate a log file so that we can tell the root cause.
    1. Open a Terminal window.
    2. Run command: cd /tmp
    3. Run command: touch ribs3debug
    4. After that a new file named "ribs3debug" should be created in /tmp folder.
    5. Delete "/Library/Logs/Adobe/Installers/Adobe Extension Manager CS6 6.0.1 05-22-2012.log.gz" if it exists. (Maybe the file name is "...05-21-2012.log.gz" for you.)
    6. Update Extension Manager CS6, via Adobe Application Manager or running updater installer manually.
    7. The new log file "/Library/Logs/Adobe/Installers/Adobe Extension Manager CS6 6.0.1 05-22-2012.log.gz" will be created.
    8. If you can upload attachment in this forum, upload this file.
    9. If you cannot upload attachment, Unzip this file, you will get"Adobe Extension Manager CS6 6.0.1 05-22-2012.log". Open this file with TextEdit, then paste the content to the forum.
    May 22, 2012 7:13 AM   in reply to Carl Sun
    Still get error message:
    In terminal I do the following:
    Last login: Tue May 22 06:46:41 on ttys000
    roy-chamberlins-imac:~ rrc907$ cd /tmp
    roy-chamberlins-imac:tmp rrc907$ touch ribs3debug
    I delete: Adobe Extension Manager CS6 6.0.1 05-22-2012.log.gz
    I run the update manually and get this:
    Roy
    May 22, 2012 8:39 AM   in reply to cschwartz@nni.com
    My error message was even more confusing:
    Adobe Extension Manager CS6 Update Installation Successful. Error Code: U44M1I0
    May 22, 2012 6:12 PM   in reply to rrc907
    Please follow the step 7-9 to paste the content of the new log file here. The purpose of the steps above is only for troubleshooting, it doesn't mean that the update will be successful if the steps are followed.
    May 22, 2012 6:16 PM   in reply to mokolabs
    Please run Extension Manager and click "Help"->"About Extension Manager" menuitem, if the version information displayed in the dialog box is 6.0.1.26, then the update is indeed successful.
    May 22, 2012 6:21 PM   in reply to Carl Sun
    In the about Extension Manager it shows it as Version 6.0.335.0
    May 22, 2012 6:25 PM   in reply to Carl Sun
    Log file that shows up is: Adobe Extension Manager CS6 6.0.1 05-22-2012.log.gz
    I still get the message: Update Failed, Updates could not be applied.
    The error log shows this: Adobe Extension Manager CS6 Update
    Roy
    May 22, 2012 6:31 PM   in reply to rrc907
    This update have to be applied to Extension Manager CS6 GM build, which is 6.0.0.412. You should install the GM build first (It can be downloaded from http://www.adobe.com/exchange/em_download/), then update it.
    May 22, 2012 6:49 PM   in reply to Carl Sun
    That worked, thanks!
    May 22, 2012 6:54 PM   in reply to cschwartz@nni.com
    The key information in the log file is:
    [   1] Tue May 22 21:21:18 2012  INFO
    Attempting to patch file: "/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/Resources/de.lproj/MainMenu.nib"(Seq 5)
    [   1] Tue May 22 21:21:18 2012 ERROR
    DF019: Unable to locate file to patch at "/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/Resources/de.lproj/MainMenu.nib"(Seq 5)
    DW063: Command ARKPatchCommand failed.(Seq 5)
    It seems that you have deleted the non-English resource files. Updater cannot find the German resrouce file, so the update failed. Anyway, glad to hear that your problem has been solved.
    May 23, 2012 10:29 AM   in reply to cschwartz@nni.com
    Have you ever run Monolingual?  If so this may help...
    I've had exactly the same problem for the past few days (U44M1P7).
    Carl Sun's above comment "It seems that you have deleted the non-English resource files...." helped me to find the problem.  I occasionally run Monolingual as part of my Mac-maintenance routine to get rid of anything that isn't in some type of English (this app is recommended by some forums/Apple magazines).  I suspect running this app has removed something that the updater tries to reference.
    So, I reinstalled Extension Manager to put back all the missing language stuff, didn't run Monolingual again, and it updated without errors straight away.
    Not sure how popular Monolingual is out there, but I thought this might help someone.
    May 25, 2012 5:24 PM   in reply to Carl Sun
    Hi Carl.  I am still having no luck.  I downloaded Extension Manager 6.0 and tried to upgrade it from 6.0.355.  I got the following code:
    Exit Code: 15
    -------------------------------------- Summary --------------------------------------
    - 0 fatal error(s), 2 error(s), 0 warning(s)
    ERROR: ASU has quit unexpectedly.
    ERROR: Media DB Error : 18
    Then I downloaded and tried to update to 6.0.1 and that wont work either.  I keep getting the U44M1P7 error?  What else can I try?
    May 26, 2012 2:34 AM   in reply to socalpaul
    Could you uninstall 6.0.0.355 first then install the GM build 6.0.0.412? If you can't, please generate log file then paste its content here, just as Schwartz did. The previous post describes how to generate log file on Mac. If you are on Windows, please see my post in another thread for the method.
    May 26, 2012 2:07 PM   in reply to Carl Sun
    Hi Carl.  I do not have an uninstall option.  Here is the log file:
    RIBS version: 6.0.98.0
    OSX version: 10.7.4
    ::START TIMER:: [Total Timer]
    CHECK: Single instance running
    CHECK : Credentials
    Load Deployment File
    deploymentFile option not given
    CHECK : Another Native OS installer already running
    Create Required Folders
    Assuming install mode
    Looking up install source path
    Sync Media DB ...
    ::START TIMER:: [Sync Media DB]
    Pre check media db sync
    End of Pre check media db sync. Exit code: 0
    :: END TIMER :: [Sync Media DB] took 14 milliseconds (0.014 seconds) DTR = 2000 KBPS (1.95312 MBPS)
    Ready to initialize session to start with ...
    ::START TIMER:: [CreatePayloadSession]
    -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
    Updated source path: /Users/dajicp/Library/Caches/Adobe/AAMUpdater/AdobeExtensionManagerCS 6-6.0/6.0.1
    Updating media info for: {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9}
    Ignoring original data since install source is local
      Type: 0, Volume Order: 1, Media Name: AdobeExtensionManager-6.0.1-mul-AdobeUpdate
      Path: /Users/dajicp/Library/Caches/Adobe/AAMUpdater/AdobeExtensionManagerCS 6-6.0/6.0.1/payloads/AdobeExtensionManager6.0All-100512200826/AdobeExt ensionManager6.0All-100512200826.dmg
    --------------------  END  - Updating Media Sources -  END  --------------------
    [       0] Fri May 25 17:19:50 2012 DEBUG
    InstallerSession.CreatePayloadSession: Checking for unsupported payloads
    [       0] Fri May 25 17:19:50 2012  INFO
    Supported RIBS version range: [0.0.66.0,6.0.98.0]
    ______ InstallerSession.CreatePayloadSession: Checking session payloads ______
    ----------------- CreatePayloadSession: machine is x86 ---------------
    InstallerSession.CreatePayloadSession: Load PDB
    [       0] Fri May 25 17:19:56 2012 DEBUG
    ______ InstallerSession.CreatePayloadSession: Checking incompatible payloads ______
    ______ GetIncompatiblePayloadBuildsInstalled ______
    ______ InstallerSession.CreatePayloadSession: Checking already installed payloads ______
    {007A2A28-D6A8-4D91-9A2B-568FF8052215} Adobe WinSoft Linguistics Plugin CS5
    {01367616-4132-4311-911F-49D2EA82F7C2} Adobe OnLocation CS5 Royalty Content Wrapper
    {0175676F-8C92-49F2-9131-D0D6AD654B41} AdobeHelp
    {01CABE2B-CE62-4924-8F8F-D9EF7491B23B} GermanSpeechAnalysisModels
    {025363D2-CB60-4869-96B6-C6160D00E2F3} Adobe Premiere Pro CS5 Third Party Content Wrapper_5.0.4_AdobePremierePro5ProtectedWrapperAll
    {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5
    {02EFB598-92AB-4DCB-A417-FE0FCBCD2266} AdobeColorVideoProfilesAE CS6
    {03740852-60C2-4B1A-A3DA-1EDB082C6401} Adobe Linguistics CS6
    {0377892E-FCAC-46EC-AA70-C6AC8A86A81F} Dynamic Link Media Server
    {03AA8100-8A65-11DF-9F66-0013724DD917} DeviceCentral_3.0.1_AdobeDeviceCentral3-all
    {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages
    {07E80932-FFB1-402D-9198-18C58EBAF216} Adobe Encore CS6 Library
    {07FCA43D-C332-4888-9316-A1427B764C37} CS6 Production Premium
    {08EF22BC-43B2-4B4E-BA12-52B18F418F38} Adobe Photoshop CS5.1 Core
    {0A186736-9C62-48B2-B1DF-8A9C5CF7C997} Adobe Premiere Pro CS5.5 Support
    {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support
    {0AA9D11A-227D-45AB-A5D5-6F5F6E81D5E3} Adobe Player for Embedding 3.1
    {0B754B55-6F63-461E-BB75-E8C883BDF88F} Adobe Premiere Pro CS5
    {0C4E7429-E920-4125-980E-029A87AE0A4D} AdobeColorCommonSetCMYK CS6
    {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5
    {0D96CFE6-376D-44B8-808A-16F3BEB73263} Adobe Media Encoder CS5.5
    {0D9E083D-1ABE-4B41-B04D-B79947317FF8} AdobeIdeaPluginCS6
    {0E3C6C75-872D-4B0D-B0B2-31C717250691} Adobe Encore CS5 Third Party Royalty Content
    {0E659C1D-7686-4322-A501-58E3FEB4E743} Adobe After Effects CS5
    {0EDAD58E-71F3-4D0E-9D32-A205533FC0E9} KoreanSpeechAnalysisModels
    {11E1188F-E576-47BC-B215-600C02C7EABF} AdobeColorNA CS5.5
    {128cd5a7-6018-4360-b4c0-b0258b1a5a34} Adobe Story
    {145F0B3B-2643-43A0-9BBC-ADAA51223F5F} Adobe Encore CS6_AdobeEncore6en_USLanguagePack
    {148542D8-49CA-482A-A334-1D54C5A9D53B} Adobe XMP Panels
    {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack
    {18B12757-2C22-44CA-B1B7-E6C6A0639F46} Adobe Media Encoder CS5 Dolby WRAPPER
    {1A1E5FF9-D0FD-42A3-8E18-E5E7E95E1AB4} DynamiclinkSupport
    {1A48007B-34D2-44BD-8708-B570F5339C14} Adobe Encore CS5 Royalty Codecs Installer Wrapper
    {1B947DEB-869E-4DA3-8368-64A79749384D} Adobe Media Encoder CS5 PCI WRAPPER
    {1CB2200F-16E5-49DF-B280-2E52254DE033} Adobe Media Encoder CS5 PCI_5.0.1_AMEPCI5All
    {1DA9F06C-F5A2-439C-88E0-642A4BE46AB0} Adobe Media Encoder CS5 Dolby_5.0.1_AMEDolby5All
    {1E621A15-CD9F-4543-B3F6-8032B3647A6A} Adobe Flash CS6_AdobeFlash12.0-en_USLanguagePack
    {1F955A4A-F365-4379-AEE2-B7C83E1AA883} Adobe Photoshop CS6 Support
    {20F72893-AEC7-4954-9EAA-F07FD6184781} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper
    {22C1290B-8DC3-4C8B-93E2-4373B9AAB1CC} TLF For Adobe Flash Pro_1.0.1_TLF_Flash11-mul
    {22C26C10-5C22-4674-A52C-100112664305} Adobe Device Central CS5.5_DeviceCentral3.5LP-en_US
    {22F41D72-2E97-46AE-B8C4-EF66876C7838} Adobe Premiere Pro CS5 Third Party Content Wrapper
    {234A555C-70F5-48FB-A7E2-32410EB5AF64} ItalianSpeechAnalysisModels
    {2373AB3E-A20E-4E37-BDA6-53562CE2171F} Adobe Extension Manager CS5.5_5.5.1_AdobeExtensionManager5.5All
    {237410EB-78A3-4797-95D0-F41DA1697D7D} Adobe Extension Manager CS5.5_5.5.2_AdobeExtensionManager5.5All
    {2591B843-8028-4395-9DEE-03AF8D631539} Adobe Player for Embedding 3.3
    {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US
    {26F763C9-076F-473D-9A0E-4050C973737C} AdobeColorJA CS6
    {270C312D-7EC7-474C-BEB2-79CD398E02A3} HIL Help Search
    {273F2A32-EC95-4AF7-BF26-EF4A57368DC9} Adobe CSXS Infrastructure CS5_2.0.1_AdobeCSXSInfrastructure2-mul
    {273F6D81-E280-4B31-90E7-8B337DB641CF} Adobe Encore CS5.1
    {277DDEAC-D86F-404B-BC5F-AC5B3E073671} ItalianSpeechAnalysisModels
    {28AE9069-B8E0-4E45-879B-4EEB6680036B} Adobe Flash CS5_11.0.1_AdobeFlash11-mul
    {298CF0B0-8B47-46DF-B726-8E4BFAD5432E} AdobeHelp
    {2996CAAB-680B-42DE-A798-B2871F93ED14} Pixel Bender Toolkit_2.5_aifsdk-mac
    {2AF31A97-817A-4D06-8210-4F789A0FF908} Adobe After Effects CS5 Third Party Content_10.0.2_AdobeAfterEffects10ProtectedAll
    {2C8C0585-5083-4032-94B8-A9AD04ED0716} Adobe AIR
    {2D8CB69A-662E-45E9-A445-2B3711B9E4A7} Adobe Flash CS6_12.0.1_AdobeFlash12.0-en_USLanguagePack
    {2EA9B52E-8613-41A0-9EEF-FF54AD4CC810} Adobe Flash CS5.5_AdobeMobileExtension_Flash11.5-en_US
    {2F6D8E64-EDE3-4FD1-93EF-3A89238F46AC} Creative Suite 5 Production Premium
    {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro
    {3071EDD7-EA5B-4CAC-B4D0-4D4D664154D1} Adobe Photoshop CS6 English Language Pack_AdobePhotoshop13-en_US
    {30FD541D-3C9D-41C4-B240-A994EE4E0231} Adobe Audition
    {311CDC89-AC18-4344-9EC9-0225328C73D3} Required Common Fonts Installation
    {3450d4c5-a82b-4428-a512-842ee1555a14} CSXS Story Extension
    {34F82E6B-8096-45CA-B604-ACACAC22E553} Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack
    {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6
    {36D02DA9-35F2-4686-A2FE-EF3014D2E226} SpanishSpeechAnalysisModels
    {379B5E99-3A86-4388-96AE-544950E08947} Adobe Media Encoder CS5 Dolby WRAPPER_5.0.1_AMEDolbyWrapper5All
    {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw
    {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK
    {3A95850D-2A0E-48FC-95C0-3F27B95DA7EC} SpanishSpeechAnalysisModels
    {3D46121C-A0E6-4259-B7E0-5127C218A096} Adobe SpeedGrade CS6
    {3D51982E-45C6-4B4B-9362-B356E1610821} Adobe OnLocation CS5.1_AdobeOnLocation5.1en_USLanguagePack
    {3E7A8DA8-0298-42F2-B927-4DB00E2F8FEE} DeviceCentral_DeviceCentral3LP-en_US
    {3EE734CB-F7AD-4691-9712-066E9FEC3E62} Adobe OnLocation CS5.1 Third Party Content
    {3FA63389-0091-497A-8522-998E43648AEF} Adobe Player for Embedding 3.2
    {4058E728-84D8-45CE-8E2D-5F35BD6659A1} Adobe Extension Manager CS5.5
    {406D22BD-7910-479B-96AA-0DB8A36C694B} Adobe After Effects CS5 Third Party Content Wrapper
    {41BFF2C7-9F45-4CF3-A257-E80E14802157} Adobe Media Encoder CS5.5_5.5.1_AMECore5.5All
    {42CCA701-73BF-48D4-86DA-27AE807163EF} Adobe Player for Embedding_3.1_AdobeAPE3-mul
    {42CED1DA-1C36-45D2-88C0-C32DB6B82B49} Adobe Premiere Pro CS6
    {4355EE3F-2FDD-4EF4-83EA-2465FBF95B16} GermanSpeechAnalysisModels
    {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5
    {4482EF4A-376B-46DE-9B17-E377232328E0} PDF Settings CS6
    {45063C56-A2A2-4FD1-A56A-A964723EEE1E} AdobeColorCommonSetRGB
    {4603E0C5-6880-4A4F-BCF8-DF1F6AE0E317} AdobeColorPhotoshop CS5.5
    {46251F95-B2F8-484A-9B5B-8C0E5A43A202} Adobe Encore CS6
    {463D65D7-CD43-4FAC-A6C7-7D24CB5DB93B} Adobe Media Player
    {4687A306-D716-4D7A-B0AA-EAB65D17F149} Adobe Player for Embedding
    {4758849A-8C03-4F90-A024-3D4C7A035B5A} AdobeMotionPicture CS6
    {47DF3210-E261-4D06-A073-92F6C426C352} Adobe Media Encoder CS5
    {4817D846-700B-474E-A31B-80892B3E92E3} Adobe After Effects CS6
    {48623899-C152-457D-9B30-1F957332AC2F} AdobeColorPhotoshop CS6
    {48D97F53-D68B-4675-9A3B-2724BF727F99} Adobe Prelude CS6 Support
    {49E6D00F-3456-11E0-AE83-842B2B67A8CC} Adobe Device Central CS5.5
    {4A8546D0-CEDF-48C1-9BA1-DD5B4ADFC154} Adobe Mini Bridge CS5.1
    {4B204697-D302-42D9-94B4-8BDDE6DD359C} Adobe ReviewPanel CS5.5
    {4B51E596-6BB0-4244-9AB9-344AD5FA6726} AdobeMotionPicture CS5.5
    {4BE1791F-1D8A-4B8E-B803-D97C5D7CB245} Adobe Soundbooth CS5 Codecs Wrapper
    {4E1B59A1-029E-4C16-BBB3-F10D40EBB6EE} Photoshop Camera Raw_6.7_AdobeCameraRaw6.0All
    {4F0DC67D-A80E-4B6A-A4BB-5D14CEDFEE75} Adobe Premiere Pro CS5_5.0.4_AdobePremierePro5AllRetail
    {4F427880-01EA-4E0F-AAE2-9ADE97563A21} Adobe Utilities CS6
    {4FAB339E-2132-434F-9376-9CD735E4C69C} Adobe Flash CS6
    {4FFA83C0-007A-4DB3-955C-B5EEE73BEDAF} Adobe SwitchBoard 2.0
    {50491591-A44F-429E-B7C8-87E03FECFD78} Adobe Flash Catalyst CS5.5
    {50F5A7C9-1E43-4860-AED8-7F8722691F17} Adobe ExtendScript Toolkit CS6
    {51C77DC1-5C75-4491-8645-A17CC33F5A36} AdobeColorEU CS6
    {52B09838-E7B4-4D45-8D7D-FCB2F3910C9C} Adobe ExtendScript Toolkit CS5_3.5.0_AdobeExtendScriptToolkit3.5.0-mul
    {539AEF15-3A2B-4A31-A587-7E90F7D9C700} Camera Profiles Installer
    {54D89F03-8EED-4FF9-BCDF-3B2E11D448A6} AdobeColorCommonSetCMYK
    {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5
    {557F9FD3-EED8-43D7-AF29-0F19CA832728} AdobePDFL CS6
    {565DE707-5798-4FC3-8DF6-0F58A348A9B0} Adobe Premiere Pro CS5 Third Party Royalty Content
    {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul
    {5A39FDD0-686E-49BD-A6FF-02F7E8256DBF} Adobe Media Encoder CS5 PCI
    {5A60CD44-B38B-47CD-BE38-219C81AE3345} Adobe ExtendScript Toolkit CS5
    {5AF84E15-9A23-4295-8508-F2901A923E83} Adobe OnLocation CS5 Royalty Content_5.0.1_AdobeOnLocation5RoyaltyAll
    {5C0FEBDA-5A0E-4FC8-91CB-229A4C1561E9} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll
    {5C5F61E0-E13B-4FD6-9F4B-C034FFD0672A} Players For Adobe Flash Pro
    {5D2A85AB-7391-4EAC-AA61-D5D9C09E4F17} Adobe OnLocation CS5.1
    {5D76C825-9827-4D93-813E-6C3754D504B1} Adobe SpeedGrade CS6_AdobeSpeedGrade6.0en_USLanguagePack
    {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live
    {6025BAFC-3C31-4FA5-91A4-467E5478DAB2} Adobe After Effects CS5 Third Party Content Wrapper_10.0.2_AdobeAfterEffects10ProtectedWrapperAll
    {6040E054-500A-427A-9DA2-349F0FEB19D1} Adobe Illustrator CS6 Core_AdobeIllustrator16en_USLanguagePack
    {606A0AC5-5F90-4379-81AE-11B44707E094} Adobe After Effects CS5.5 Third Party Content
    {614020C8-2E16-4E16-A5F0-04DE2AB96097} Adobe Premiere Pro CS6 Functional Content
    {61D7BE95-B5C3-4257-A773-64596D72E848} Adobe After Effects CS5.5 Template Projects & Footage
    {62466A6D-1130-4D66-9D65-ED3E1A988E12} iPhone Publishing_1.0.1_iPhone_Flash11-mul
    {627D49F9-9F71-436C-9B85-9ACAA9E78561} Adobe Media Encoder CS5 Dolby
    {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing
    {64C19EC0-24A3-4F6F-A0AD-C701C8C48700} Adobe OnLocation CS5_5.0.1_AdobeOnLocation5All
    {64D991B0-4E64-47AC-8A35-291DA2E7D02F} Adobe After Effects CS5 Support
    {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension
    {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US
    {6A2E619B-E4AC-433B-A648-D458CE543A96} Adobe XMP Panels CS5
    {6A75E573-6909-4D48-BDFA-D8ED118605A5} Adobe Illustrator CS5
    {6ACDB89B-63FB-4C7D-8490-7528E248F25B} Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack
    {6BA6F6D7-1D30-482A-B9B8-20E79D6DB4F9} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper
    {6BC81374-1E33-4495-93E2-DD2B10D358EE} AIR for APPLE IOS Support (FP)
    {6C6D990F-FC88-4F07-912C-DA37468D9A3C} Adobe OnLocation CS5 Royalty Content Wrapper_5.0.1_AdobeOnLocation5RoyaltyWrapperAll
    {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral
    {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5
    {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5
    {70CAC073-3CDD-498C-80F7-79B76A61D7E6} Adobe Flash CS5_11.0.2_AdobeFlash11-mul
    {71BC8278-815D-4F8C-8FA5-C6F782C73892} Adobe CSXS Infrastructure CS5.5
    {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5
    {771C9F59-3F22-4610-A23E-321A98ECA264} Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack
    {7745F18B-FD8A-4011-BE16-588900C503D0} Adobe Flash Fonts1
    {7816FDDE-40D4-482D-AD7D-97858985DB3E} Adobe OnLocation CS5 Royalty Content
    {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB
    {78E38D75-4D92-4F6E-B631-17A436BED680} AdobeColorVideoProfilesCS CS6
    {78E50DF8-A115-42F9-B859-4F74903B0492} Adobe Premiere Pro CS5 Third Party Royalty Content_5.0.4_AdobePremierePro5RoyaltyAll
    {796659A8-114A-4E16-9994-14DF6A1B1683} Adobe Utilities CS5
    {7A75E573-6909-4D48-BDFA-D8ED118605A7} Adobe Illustrator CS5_15.0.2_AdobeIllustrator15-mul
    {7CAD45EF-24AD-4281-9236-7F8DDB0B9538} Adobe After Effects CS5.5 Support
    {7CF76BDA-73EA-4C46-A59D-FC3142D83E65} Adobe OnLocation CS5.1 Third Party Content Wrapper
    {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core
    {7F7421AA-3A80-49B2-B88B-611A50C23D30} Adobe Bridge CS5_4.0.5_AdobeBridge4-mul
    {809CAFEA-B905-4940-8451-DBA0AE0AA825} Adobe Photoshop CS5 Core_12.0.4_AdobePhotoshop12-Core
    {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6
    {8467887D-92F1-435C-B387-A7551B88EC70} Adobe NPS Panel
    {84901376-1C55-4BD3-AD2C-F9BDB4449DAC} PDF Settings CS5
    {85A65551-7D55-4AB5-83EB-2B352A0DDD08} KoreanSpeechAnalysisModels
    {88BE801D-C8EC-46A4-92AC-06CE56FE0E0A} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-mul
    {8A5387E2-7F1A-4FDD-883F-511DC8AA2295} Adobe After Effects CS5 Third Party Royalty Content_10.0.2_AdobeAfterEffects10RoyaltyAll
    {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5
    {8EDF2712-3B35-484B-9AD2-A3F7214A7E3A} Adobe Flash CS6_12.0.1_AdobeFlash12.0-mul
    {9124DF4E-617D-486B-A970-8FA632244F24} Adobe Photoshop CS6 Core
    {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule
    {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US
    {970C9F3A-39C5-480B-BE51-7C70AB9F84DB} Adobe Flash CS5.5_AdobeFlash11.5-en_USLanguagePack
    {977F44E9-6607-4C2D-A563-A383FAFFC406} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper_5.0.4_AdobePremierePro5RoyaltyWrapperAll
    {97BA0109-F6BE-4F50-8904-C19442D7216E} Adobe Bridge CS6
    {98970962-1D70-43D4-B268-EDF57E451BA9} Adobe After Effects CS6 Support
    {98D9F7CA-641D-4832-92B8-E846FE8AFB50} Adobe CSXS Infrastructure CS6_3.0.1_AdobeCSXSInfrastructure3-mul
    {9AF7B703-B806-4C74-94E5-82963EFC0188} Adobe Extension Manager CS5_5.0.1_AdobeExtensionManager5.0All
    {9BA136BE-0077-41E1-AD56-56AB5D4A1A67} Adobe ExtendScript Toolkit CS5.5
    {9F747BEC-FB4E-4830-8C58-363B8DCC26EB} Adobe Illustrator CS5.1_AdobeIllustrator15_1en_USLanguagePack
    {9FBC5BF9-5019-49D6-A1B3-6BB0E2A1FA54} Pixel Bender Toolkit
    {A0F72081-99FB-4FFA-AE1A-62B5A656CAC1} AdobeTypeSupport CS6
    {A1E0C87F-BFE5-490A-898E-05BD4DD2BADF} InternationalEnglishSpeechAnalysisModels
    {A32910E5-4084-4A0E-9FFF-D2E9C1B1C134} Adobe Encore CS5 Library
    {A44863BF-8DB8-4D22-88DB-5A02BE319840} Adobe Linguistics CS5
    {A4EE8093-4250-4D8B-BDE4-A4675BB44953} Adobe Flash Catalyst CS5
    {A516708E-EC03-40F5-B82E-0851A44B3780} Adobe Illustrator CS5.1
    {A5A8E72E-1B9D-4F99-ADED-F3595CB3D03E} AdobeColorVideoProfilesAE CS5
    {A69CC698-119E-450F-9AEC-2F377C03B33B} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-en_US
    {A7A95754-A63E-4052-8945-BBDC27009E7E} Adobe Audition_AdobeAudition5en_USLanguagePack
    {A80C015C-1939-42A5-AD2F-E76C7F194505} AdobeColorJA CS5.5
    {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport
    {A92DAC1E-9F7C-46A3-BD06-8E629A5E1D07} FrenchSpeechAnalysisModels
    {A9E40F78-E54D-494F-94A9-5D502F8DD1E1} Adobe WinSoft Linguistics Plugin CS6
    {AA0D312F-1570-4E7E-9A7D-E191E0090FEC} AdobeHelp
    {AA52817B-75CD-403A-90E1-6430ABD290E2} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper_10.0.2_AdobeAfterEffects10RoyaltyWrapperAll
    {AAF0D225-F129-40F2-916E-12E28DBD19ED} Adobe Illustrator CS6 Core
    {ABDC1F61-2C50-4BB1-ACDA-66D412D72582} Adobe OnLocation CS5
    {AC003BC0-704F-4F02-A72E-AC8B7044DE24} AdobeOutputModule
    {AC85D480-BE25-4B01-84BE-E8A5932E39DB} Adobe Hunspell Linguistics Plugin CS6
    {AD60EB24-4CEE-4CA0-A6AA-526EAF41F2DB} Adobe Audition_AdobeAudition4en_USLanguagePack
    {ADAF6949-4547-4B3D-97C5-6FB4D0C08A1E} Adobe Soundbooth CS5 Royalty Codecs Wrapper
    {AF37BA1C-5667-4A9B-A933-02E0A8440F88} Adobe Premiere Pro CS5.5_5.5.2_AdobePremierePro5.5AllRetail
    {B0D32525-8AFA-43C4-B84D-AB2A844D5EAD} Adobe Premiere Pro CS5.5 Functional Content
    {B4975576-60AD-4181-AED4-253FC150B404} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack
    {B5BC75FC-908D-4E1E-A1EE-09A3FDBBEC77} AdobeIdeaPluginCS6-loc
    {B67ED9AA-F372-40CC-89AB-F5D8FBF56CD4} Adobe Illustrator CS6 Support
    {B842A584-A0BF-4870-A850-9C0E52FD6A20} Adobe Encore CS5_AdobeEncore5en_USLanguagePack
    {B8D286BC-A68D-4E74-9F68-8756A49896D8} Adobe Premiere Pro CS5 Third Party Content
    {B8E14946-984D-4404-B6B9-5DDB727B724A} Adobe Prelude CS6_AdobePrelude1en_USLanguagePack
    {B98E0DCB-1A75-4394-9813-3A114AA3891D} Adobe Mini Bridge CS6
    {BA952839-8055-4F36-A149-32520F40E7F2} Adobe Media Encoder CS6_6.0.1_AMECore6All
    {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5
    {BB66788C-4C4F-4EB0-B146-9178857DE287} AdobeColorNA CS6
    {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5
    {BD85DFD4-005F-4219-8E27-C922CC4D8A61} Adobe CSXS Extensions CS5.5
    {BD9938F0-B9D1-4270-8A14-6C73BD2476D5} Adobe After Effects CS6_11.0.1_AdobeAfterEffects11AllTrial
    {BF093B6B-F94F-4D77-99C9-4C0F6B2F44B6} Adobe Encore CS5.1_AdobeEncore5.1en_USLanguagePack
    {C0329E33-DEB4-48D9-B7B6-19493A6F062E} Adobe After Effects CS5.5
    {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content
    {C1302004-7A3C-467A-80AC-4D0C9F6982C1} Adobe After Effects CS5.5 Presets
    {C24D91B7-406B-4C50-879A-44478359B772} Adobe Extension Manager CS5_5.0.2_AdobeExtensionManager5.0All
    {C25C56B5-DF4B-4D25-B25F-9E7953648016} JapaneseSpeechAnalysisModels
    {C2F8BD34-1692-40F9-BA1B-1CFB2B5FED3A} Adobe After Effects CS5.5 Third Party Content Wrapper
    {C346BBCF-A687-4500-BB19-EE9C2D6FF284} Suite Shared Configuration CS6
    {C5CA53A2-E722-4D76-B5AC-71522CC48AB3} AmericanEnglishSpeechAnalysisModels
    {C61B093E-259E-45D8-B9B6-24630A700398} Adobe After Effects CS5.5_AdobeAfterEffects10.5en_USLanguagePack
    {C7B1C1B3-368D-4C32-A818-83F1554EB398} AdobeColorCommonSetRGB CS6
    {CBE4F6C3-788E-4CAC-BA25-26FE39A3BC8C} Adobe Soundbooth
    {CC006FD6-00EF-46FC-ACA0-7A28EFF44D20} Adobe Media Encoder CS6
    {CC0EF75D-9336-4E4F-B4A2-99E2E60E161F} Adobe After Effects CS5 Presets
    {CC35904A-0197-4F06-BD70-9CE3DB24DBFD} AdobeColorVideoProfilesAE CS5.5
    {CCB778B5-25B8-4E57-9F20-72B11B443EF9} AmericanEnglishSpeechAnalysisModels
    {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} Adobe After Effects CS5 Third Party Royalty Content
    {CD693E49-C5EF-4FA6-9037-9B636931C02B} AmericanEnglishSpeechAnalysisModels
    {CDAC14AB-1424-4E9C-8515-EA89D7F37243} Adobe Premiere Pro CS6 Support
    {CFC3110A-491C-4DBF-A97D-66C567600A2F} Photoshop Camera Raw 7
    {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5
    {D094CE41-D4F5-473E-8915-B1D026CB193E} Adobe Premiere Pro CS6_AdobePremierePro6.0en_USLanguagePack
    {D2583A3E-399C-45D7-8AF1-FE5BAFC946CF} AIR for Apple iOS support (FP)
    {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5
    {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5
    {D3E89C12-49DE-4A2C-9D24-1A8D704679D5} Adobe After Effects CS6_AdobeAfterEffects11en_USLanguagePack
    {D5B1535A-FDFC-4B40-B2E2-21DA83D9CB57} Adobe Audition
    {D5E7D8B9-9B8F-4DA0-9B2C-167DC889B0E1} Adobe After Effects CS5 Template Projects & Footage
    {D6A4C9B1-5AE2-4118-AD9D-24313C79F2B6} Adobe Photoshop CS5 Support_12.0.4_AdobePhotoshop12-Support
    {D7EC9AC4-B2A7-48D5-8555-CB6FF029EAF7} Adobe Media Encoder CS5_5.0.1_AMECore5All
    {D8465547-5D5B-4856-A93A-8AC0A05C5D4D} Adobe Encore CS5
    {D8B9B5FB-D388-4D79-AA4B-6C09641189F6} Adobe Utilities CS5.5
    {D97AF04B-B70A-4862-BC25-31E6D9C4A529} Adobe Flash CS5.5
    {D9F625C8-FD5B-4C13-9B3C-5B9F09BA0DC0} Adobe Flash CS5.5_11.5.1_AdobeFlash11.5-mul
    {DBCFA16A-59EC-4DAF-98D1-B4E2C2A9E7B4} Adobe Encore CS6 Support
    {DD18D60C-87B1-47D9-8312-67508B402FB9} SiteCatalyst NetAverages CS5.5
    {DE5DE662-2ECB-4D93-967B-221FBCC8A736} Adobe Soundbooth CS5 Codecs
    {DE7C6FA1-AF75-48A8-B495-CFAD529BCC3D} Recommended Common Fonts Installation
    {DE88AA40-6766-43D3-A755-8FC374B3D2C3} DynamiclinkSupport
    {DEA79551-23E3-430A-9B15-B544479B7DB2} Flash Player
    {DF3E1042-6235-410C-986D-65A2138CCB69} CS5.5 Production Premium
    {E348E466-429A-4FB0-AFCF-8306C16BBFF1} Adobe Flash CS5.5_AdobeMobileExtension_Flash11.5-mul
    {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5
    {E6F68811-F702-492C-A7DA-D22CA670BC22} Adobe Soundbooth_AdobeSoundbooth3en_USLanguagePack
    {E787BAD7-B750-4E1C-A149-965CF1DEE4AB} Adobe After Effects CS6 Presets
    {E7F2C606-8529-4028-B26E-8407DB43DD45} FrenchSpeechAnalysisModels
    {E8B1DAAA-0B6B-44E6-A2D3-8E418EA0EA85} AdobeCMaps CS6
    {E9047020-446C-4C64-8477-E52ACD204DEE} Adobe Media Encoder CS5 PCI WRAPPER_5.0.1_AMEPCIWrapper5All
    {EB186BF2-0A84-40A2-B794-0326D3DF9973} AdobeColorVideoProfilesCS CS5.5
    {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6
    {EB552CA2-03BA-45DE-B539-FEEA56055F4D} Adobe Premiere Pro CS6_6.0.1_AdobePremierePro6.0AllTrial
    {EBB922EB-B85B-4BC5-9FCA-6B4E60B92E83} Adobe After Effects CS5_10.0.2_AdobeAfterEffects10AllRetail
    {ED28819E-310F-4F17-925C-C69B0A1C1F7F} Suite Shared Configuration CS5.5
    {EDE888ED-3BD7-4D8C-AB35-7E4C661A94D9} Adobe Photoshop CS5.1 English Language Pack_AdobePhotoshop12-en_US
    {EE85C227-0148-4825-B659-6A1E142571EE} Adobe Bridge CS5.1
    {EEAE1D88-B258-4A44-A6BE-32CCC8D641D6} Adobe Prelude CS6
    {EF45880C-DD84-46C3-A054-0BC5F76A6BBE} Adobe Photoshop CS5.1 Support
    {EFB5A1C3-ECCA-4D8A-B598-81D21DE25C34} Adobe Premiere Pro CS5.5
    {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro
    {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} Adobe Soundbooth CS5 Royalty Codecs
    {F3AEA2B8-DC79-470F-9D16-A4E9CF2F8810} InternationalEnglishSpeechAnalysisModels
    {F3ECF5C7-9A9D-460A-B3D6-C7E4C1DFD040} AdobeMotionPicture CS5
    {F46A4C18-2EAD-49F0-A244-994226F93B39} JapaneseSpeechAnalysisModels
    {F4EC52C6-1223-4EA9-8C48-F4E6AB2EEC19} Adobe Premiere Pro CS5 Functional Content
    {F637969B-336C-4533-9D4D-D0163A39C42F} Adobe Flash CS5_11.0.2_AdobeFlash11-en_USLanguagePack
    {F77882B9-A94F-44F4-A739-8370749255B6} Adobe Premiere Pro CS5 Support
    {F8918124-1CFB-4AB9-9BC2-39B961DBBBEE} Pixel Bender Toolkit
    {FE35B66A-C8F1-4D62-B823-C2EE2C7DA702} Adobe Premiere Pro CS5.5_AdobePremierePro5.5en_USLanguagePack
    {FECCB1BF-038D-41C2-861B-4560E7667005} AdobeColorEU CS5.5
    {FFEDE6AE-3052-11DF-89B7-E7102C404F28} Adobe ReviewPanel CS5
    [       0] Fri May 25 17:19:56 2012  INFO
    ______ Verify Dependency Subscribers ______
    ______ Checking payloads upgrade/conflict relationships ______
    Checking for payloads having same family and product names but different adobe codes
    ______ Checking payloads upgrade/conflict relationships : Passed ______
    Operation order summary:
    When distributing payloads across media, the following order must be preserved, except that
    adjacent payloads with the same mediaGroup can be re-ordered across media boundaries without introducing
    extraneous media swaps for the user.
    BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
      {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0: 0 (0,0)
    END Operation order for all session payloads: mediaGroup (requires,satisfies)
    :: END TIMER :: [CreatePayloadSession] took 6032 milliseconds (6.032 seconds) DTR = 15.252 KBPS (0.0148945 MBPS)
    Patch {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0 can be applied to product {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0
    *** Checking patch payload : {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0
    installDBPath : /Users/dajicp/Library/Caches/Adobe/AAMUpdater/AdobeExtensionManagerCS 6-6.0/6.0.1/payloads/AdobeExtensionManager6.0All-100512200826/Install. db
    Successfully Opened installDB
    Payload is not customized
    Parent AdobeCode : {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0
    Parent Installation directory : /Applications
    Overwrite property "extensionsOnly" to: 1
    Overwrite property "mode" to: silent
    Overwrite property "patchesOnly" to: 1
    Overwrite property "workflow" to: updater
    Found payload actions:
    Deciding what installer mode to use...
    Requested action "install" for {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0
    Using installer mode 0
    ::START TIMER:: [Setting Payload Actions]
    PayloadPolicyInit: BEGIN Updating installstate for payloads
    PayloadPolicyInit: END Updating installstate for payloads
    PayloadPolicyInit: BEGIN Creating policyNodes
    PayloadPolicyInit: END Creating policyNodes
    PayloadPolicyInit: BEGIN Calculating initial graph
    PayloadPolicyNode.ComputeConstraint: Static installMode 0 mode constraint is 2 12, Y for {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0
    PayloadPolicyNode._SetPayloadAction: install for {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0
    PayloadPolicyNode.SetAction: IY->IY for {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0
    PayloadPolicyInit: END Calculating initial graph
    BEGIN Setting requested payload actions
    Value returned on lookup of payload: {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0 is: false
    Action string for {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0  is install
    Setting action for {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0 per deployment file.
    END Setting requested payload actions
    :: END TIMER :: [Setting Payload Actions] took 56 milliseconds (0.056 seconds)
    Collected advanced path check information for INSTALLDIR
    INSTALLDIR is a well-formed path
    INSTALLDIR is not the root path
    INSTALLDIR is on a local volume
    INSTALLDIR is on a writable volume
    INSTALLDIR is not on a case sensitive volume
    INSTALLDIR passed path basic path validation: /Applications
    ::START TIMER:: [SimulatePayloadOperations]
    BEGIN InstallOperationsQueue Unordered operations
      {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0:  with operation install
    END InstallOperationsQueue Unordered operations
    BEGIN InstallOperationsQueue Ordered operations
    END InstallOperationsQueue Ordered operations
    Creating instruction for payload {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0
    EMPTY SET Dependent operations for DRIVER {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0
    Operation can be attempted
    Payloads passed preflight validation.
    :: END TIMER :: [SimulatePayloadOperations] took 201 milliseconds (0.201 seconds) DTR = 39.801 KBPS (0.0388682 MBPS)
    Call PreSession Custom Hook
    Opened installation queue
    Verifying payload '{C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0' in media
    Verification of payload '{C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0' in media is successful
    Calling the custom action code for pre-install for payload {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0
    Custom action code for pre- install for payload {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0 returned : 0
    ::START TIMER:: [Payload Operation :{C975B8D6-9B6F-4A95-A475-CFB14C3C33D9}]
    [       1] Fri May 25 17:19:56 2012  INFO
    Installer Operation: PayloadInstaller
    Request to install payload
    [       1] Fri May 25 17:19:56 2012 DEBUG
    ADOBE_SETUP                      = 1
    AddRemoveInfoEstimatedSize       = 16494
    CLE                              =
    ExtensionFamily                  = Creative Suites
    ExtensionParentAdobeCode         = {83463106-DD1C-4FE5-A61C-DF6715472AD4}
    ExtensionProduct                 = Adobe Extension Manager CS6
    ExtensionType                    = patch
    ExtensionVersion                 =
    INSTALLDIR                       = /Applications
    IsExtensionPayload               = 1
    MEDIATAG                         =
    OS64Bit                          = 0
    ProcessorFamily                  = All
    SessionID                        = {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9}
    StartMenuProgramsSubFolder       =
    adobeCode                        = {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9}
    defaultLanguage                  = en_US
    driverINSTALLDIR                 = /Applications
    extensionsOnly                   = 1
    installLanguage                  = en_US
    installSourcePath                = /Users/dajicp/Library/Caches/Adobe/AAMUpdater/AdobeExtensionManagerCS 6-6.0/6.0.1
    mediaName                        = AdobeExtensionManager-6.0.1-mul-AdobeUpdate
    mediaPath                        = /Users/dajicp/Library/Caches/Adobe/AAMUpdater/AdobeExtensionManagerCS 6-6.0/6.0.1/payloads/AdobeExtensionManager6.0All-100512200826/AdobeExt ensionManager6.0All-100512200826.dmg
    mediaSignature                   = {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9}
    mode                             = silent
    overrideFile                     =
    parentAdobeCode                  = {83463106-DD1C-4FE5-A61C-DF6715472AD4}
    patchPayload                     = 1
    patchesOnly                      = 1
    payloadType                      = SQLite
    platform                         = OSX
    setupVersion                     = 6.0.98.0
    workflow                         = updater
    Payload {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0: Calling ARKEngine from path /Applications/Utilities/Adobe Application Manager/DECore/DE6/resources
    Setting determined properties...
    Mounting payload image at /Users/dajicp/Library/Caches/Adobe/AAMUpdater/AdobeExtensionManagerCS 6-6.0/6.0.1/payloads/AdobeExtensionManager6.0All-100512200826/AdobeExt ensionManager6.0All-100512200826.dmg
    [       1] Fri May 25 17:19:58 2012 DEBUG
    Payload mounted at /private/tmp/.tempdir7LFrQZdu
    [       1] Fri May 25 17:19:58 2012  INFO
    CustomizedPatch property not found in database
    Beginning installation for payload at /private/tmp/.tempdir7LFrQZdu/Install.db
    Creating directory at "/Applications/Adobe/AdobePatchFiles/{C975B8D6-9B6F-4A95-A475-CFB14C3 C33D9}" with mode 775(Seq 1)
    Created(Seq 1)
    Copying file "/private/tmp/.tempdir7LFrQZdu/Assets1/761a3962aef46730d8f139c2d4c98f b9" to "/Applications/Adobe/AdobePatchFiles/{C975B8D6-9B6F-4A95-A475-CFB14C3 C33D9}/761a3962aef46730d8f139c2d4c98fb9"(Seq 2)
    Copied(Seq 2)
    Attempting to patch file: "/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS/ZStringResources/uk_UA.xml"(Seq 3)
    Saving prior original file at "/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS/ZStringResources/uk_UA.xml" to temporary location(Seq 3)
    Original file saved to "/tmp/.templ8K4QV"(Seq 3)
    Patched(Seq 3)
    Copying file "/private/tmp/.tempdir7LFrQZdu/Assets1/429985f9956e5924c3ef346e52f210 75" to "/Applications/Adobe/AdobePatchFiles/{C975B8D6-9B6F-4A95-A475-CFB14C3 C33D9}/429985f9956e5924c3ef346e52f21075"(Seq 4)
    Copied(Seq 4)
    [       1] Fri May 25 17:19:58 2012 ERROR
    Completing installation for payload at /private/tmp/.tempdir7LFrQZdu/Install.db
    Rolling back prior actions...
    Deleting file copy at "/Applications/Adobe/AdobePatchFiles/{C975B8D6-9B6F-4A95-A475-CFB14C3 C33D9}/429985f9956e5924c3ef346e52f21075"(Seq 4)
    Deleted(Seq 4)
    Deleting file at "/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS/ZStringResources/uk_UA.xml"(Seq 3)
    Deleted(Seq 3)
    Restoring file at "/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS/ZStringResources/uk_UA.xml"(Seq 3)
    Restored(Seq 3)
    Deleting file copy at "/Applications/Adobe/AdobePatchFiles/{C975B8D6-9B6F-4A95-A475-CFB14C3 C33D9}/761a3962aef46730d8f139c2d4c98fb9"(Seq 2)
    Deleted(Seq 2)
    Deleting directory "/Applications/Adobe/AdobePatchFiles/{C975B8D6-9B6F-4A95-A475-CFB14C3 C33D9}" Non-Recursive(Seq 1)
    Saved permissions of 0x1fd for "/Applications/Adobe/AdobePatchFiles/{C975B8D6-9B6F-4A95-A475-CFB14C3 C33D9}"(Seq 1)
    Saved owner of 0x0 and group of 0x50(Seq 1)
    Deleted(Seq 1)
    InstallPayload failed.
    [       0] Fri May 25 17:19:58 2012  INFO
    *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
    :: END TIMER :: [Payload Operation :{C975B8D6-9B6F-4A95-A475-CFB14C3C33D9}] took 1412 milliseconds (1.412 seconds) DTR = 62.3229 KBPS (0.0608623 MBPS)
    User specified overrideFile:
    The csu inventory was not updated for payload {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0, value of local var is -1
    Calling the ROLLBACK custom action code for pre-install for payload {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0
    No operation.  We're done:
    [       0] Fri May 25 17:20:00 2012  INFO
    Total components installed: 0
    Total components repaired: 0
    Total components removed: 0
    [       0] Fri May 25 17:20:00 2012 ERROR
    DW050: The following payload errors were found during install:
    DW050:  - Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All: Install failed
    Call PostSession Custom Hook
    :: END TIMER :: [Total Timer] took 14481 milliseconds (14.481 seconds) DTR = 19.6119 KBPS (0.0191523 MBPS)
    - 0 fatal error(s), 3 error(s), 0 warning(s)
    ----------- Payload: {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0 -----------
    ERROR: DF019: Unable to locate file to patch at "/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/Resources/de.lproj/MainMenu.nib"(Seq 5)
    ERROR: DW063: Command ARKPatchCommand failed.(Seq 5)
    ERROR: DW050: The following payload errors were found during install:
    ERROR: DW050:  - Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All: Install failed
    Please search the above error/warning string(s) to find when the error occurred.
    These errors resulted in installer Exit Code mentioned below.
    [       0] Fri May 25 17:20:01 2012  INFO
    Exit Code: 7 - Unable to complete Silent workflow.
    Please see specific errors and warnings for troubleshooting. For example, ERROR: DF019, DW063 ...
    END - Installer Session
    May 27, 2012 7:12 AM   in reply to socalpaul
    Your problem is exactly the same as Schwartz's problem in this thread. You have deleted the non-English resource files. Updater cannot find the German resrouce file, so the update failed. See the following snippet from log file.
    According to the log, although you get error code when updating Extension Manager from build 355 to 412, but the database has been updated. So you can install Extension Manager GM build 6.0.0.412 in another compupter, then copy the whole install folder to replace existing folder in your computer. Then the update to 6.0.1 patch should be successful.
    May 28, 2012 1:22 PM   in reply to Carl Sun
    Hi Carl.  I am good to go now, but I had to improvise.  Your directions stated to copy the new folder to replace my current folder.  That simply added the files to my current problematic folder.  What I ended up doing to correct this was to first delete the Adobe Extension Manger folder, empty trash and then copy the new folder.  Now I am good. Thanks for your help.
    Aug 31, 2012 9:36 AM   in reply to socalpaul
    This is ridiculous, I fixed extension manager, now Illustrator is having the same problem. How can Adobe not have fixed this before they released another patch that does the same thing?
    Sep 2, 2012 12:43 AM   in reply to LeeWarner
    Because Adobe CS products use the same way to update, you might have the similar problems in different products. In current implementation, the patch is a "delta" package, which includes the differences between the old verison and the new version. In order to make sure the patch won't overwrite some changed files, the patch installer will check the checksum of the files to be replaced. It the files cannot be found or the checksum does not match, the patch will not be installed.
    So using the same way above( copying files from another machine to yours ) might work for this case. Thanks.
    Sep 4, 2012 7:56 AM   in reply to Xiaoyi Tong
    I am able to get it to work by manually deleting the folders and reinstalling.
    All of this is a workaround. It's crazy that we need workarounds when this type of problem has been shown since CS5. It's irrelevant to the user what type of patch it is. "Delta" means nothing but a greek letter to many of us. It's incomprhensible why this type of thing still happens. I expect more from Adobe.
    Sep 4, 2012 8:53 AM   in reply to LeeWarner
    Hi LeeWarner,
    We fully undertand it is inconvenient for users to use this workaround, and we will forward your feedback to related department. Thanks a lot for your patience. Hopefully we can make things better.
    Dec 13, 2012 1:29 PM   in reply to Xiaoyi Tong
    Hello guys/gals - well, all the above is greek to me i am afraid. I am so new to Mac etc, but am getting the same error messages. My Mac OS version is in Swedish but the Updater is English - however, i get the following error messages after installing the update from the update manager:
    Extension Manager 6.0.4 update
    Installation failed. Code U44M1P7
    Adobe Illustrator CS6-update (version 16.0.3)
    I know nothing about logfiles or how to do what you guys have expalined above, as i am new to Mac.
    All i know is that this is the second time Adobe updater has tried and both times failed.
    Can someone please explain "how" and "where" to find these files you talk about (deleting - reinstalling etc)?
    When i paid for this product, i downloaded from Adobe to a file on my HDD.
    All my other Adobe products updated sweetly: Dreamweaver - Photoshop Camera Raw.
    Thank you for your patience
    Dec 17, 2012 6:20 AM   in reply to RaySwede
    Hi RaySwede,
    You can open your Finder and navigate to Extension Manager CS6( "/Applications/Adobe Extension Manager CS6" ), and drag it to Trash. Then download and install Extension Manager 6.0.4 full installer from http://download.macromedia.com/pub/dw_exchange/extension_manager/mac/A dobeExtensionManager6.0.4All.dmg
    After that, ingore the udpate message that "Extension Manager 6.0.4 is available". By doing this, you can solve your update issue in Extension Manager. Thanks.
    Xiaoyi
    Dec 17, 2012 7:52 AM   in reply to Xiaoyi Tong
    Many thanks Xiaoyi Tong - i shall get back when i have done that
    PS: What about Illustrator please?
    Dec 17, 2012 11:23 AM   in reply to RaySwede
    Worked like a dream, many thanks indeed
    Feb 20, 2013 6:33 PM   in reply to cschwartz@nni.com
    Hello
    I get that error too.
    Extension Manager 6.0.5-Update
    Installation fehlgeschlagen Fehlercode: U44M1P7
    (german cs6 - and i didn't delete/alter any language files)
    I have no Mac though (Win7 hp sp1 64bit) but I followed the suggestion to delete the original folder and download the full installation file of the extension manager but even installing that fails:
    Exit Code: 7
    Please see specific errors and warnings below for troubleshooting. For example,  ERROR: DS010, DW050 ...
    - 0 fatal error(s), 7 error(s), 0 warning(s)
    ----------- Payload: {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0 -----------
    ERROR: DS010: Invalid library file ARKCmdFS.dll. Cannot get GetCommandObject API address for command InstallAdobeVersionedFile(Seq 1)
    ERROR: DW050:  - Adobe Player for Embedding 3.3: Install failed
    ERROR: DW050:  - Adobe Extension Manager CS6: Install failed
    ERROR: DW050:  - Microsoft Visual C++ 2005 Redistributable Package (x86): Install failed
    ERROR: DW050:  - Microsoft Visual C++ 2008 Redistributable Package (x86): Install failed
    ERROR: DW050:  - Microsoft Visual C++ 2010 Redistributable Package (x86): Install failed
    ERROR: DW050:  - Adobe Extension Manager CS6_6.0.4_AdobeExtensionManager6.0All: Install failed
    I had problems with my main hard drive the other day (corrupted sectors on C:\ or whatever, some hardware stuff that got found by checkdisk before loading Windows).
    On my main hard drive is Windows on C:\; and all software installed on E:\ but there wasn't anything found on e: by checkdisk, only on c:
    I did a repair installation of Windows 7 because I had problems with other software too that got fixed after the repair installation. So I don't know whether the Adobe problem may be related to it or not. It's my only problem left now. The update problem was befor the repair installation too.
    Mopsi ^^
    Feb 26, 2013 2:14 AM   in reply to Mopsi Leet
    Hi all,
    For those still having trouble, we have posted a full installer of Extension Manager 6.0.5 here:
    It should solve all of your problems.
    Best regards,
    Hallgrimur
    Product Manager
    Feb 26, 2013 5:55 AM   in reply to Hallgrimur Bjornsson
    Thank you Hallgrimur - I have downloaded and installed - so far so good
    Now to wait and see what happens when the "Adobe Updater" kicks in sometime
    Once again, many thx!!
    May 6, 2013 8:27 AM   in reply to RaySwede
    I also installed this update manually but the update manager still show this update waiting to be installed. In the update Manager I still get the error message U44M1P7.
