Ack19105
Bad character spacing w/ Acrobat X, was fine with Acrobat 8
May 22, 2012 7:25 PM
Tags: #spacing #x #8 #kerning #character #2010 #conversion_error
I am converting a word document to pdf within MS Word using pdfmaker. Same original MS Word document in both cases, Times New Roman font, regular 11 pt.
One conversion is being done on older WinXP/SP2 system using Word2000 and Acrobat 8 pro, and the result looks fine.
The other is being done on a new Win7 system using Word2010 and Acrobat X pro, and the result is poor - a kerning or other kind of spacing problem so that every letter 'i' and 'j' is shifted to the right.  Other letters are affected as well, though to lesser degrees.
The conversion settings appear to be identical.  The Word file looks fine on both machines.  The pdf files look as they do below on both machines (it is not a viewer problem, must be a conversion problem)
I would sure appreciate some help fixing the new system - thanks!
    May 23, 2012 5:40 PM   in reply to Ack19105
    What is the default job setting file on each system?
    May 26, 2012 12:31 PM   in reply to Ack19105
    Change the settings so that you use Press Quality and see if it makes a difference. Standard does not embed the fonts in the pdf. So if you view a file on a machine that has the exact same font on the computer you could have the problems you are seeing.
    Jun 11, 2012 4:40 AM   in reply to Ack19105
    Is the issue resolved for you now with the Press Quality?
    Jun 11, 2012 5:50 AM   in reply to SomyaAgg
    You can always check the document to see if the fonts are embedded. When such problems occur, it is a result of not having the fonts embedded. The Std job settings do not embed all fonts and that is likely where the problem is.
