Mathias Wilkens
How to dismiss app.alert
May 23, 2012 1:03 AM
I have a message that displays when opening my PDF form.
The form will be opened several times, so I want to give users the option to dismiss the message, so it only appears the first time.
I have tried to use a script by Ted Padova, but I cannot make it work.
This is the code I have "borrowed":
________________________________________
if(typeof(global.bShowWarning1) ==
global.bShowWarning1 = true;
global.bPersistWarn1 = false;
if(global.bShowWarning1)
var oCk = {bAfterValue:false};
app.alert({cMsg:"Instructions: Fill out this form carefully and click the Submit Form button when finished.", nIcon:1,oCheckbox:oCk,cTitle:"Reminder"});
global.bShowWarning1 = !oCk.bAfterValue;
I get the following syntax error code:
SyntaxError: missing: after property id
3: at line 4
Ln 11, Col 2
Any help is greatly appreciated!
PS: I am using Acrobat X pro
/Mathias
    May 23, 2012 7:49 AM   in reply to Mathias Wilkens
    Have you defined the global variables bShowWarning1 and bPersistWarn1?
  • George Johnson
    Aug 11, 2002
    May 23, 2012 9:43 AM   in reply to Mathias Wilkens
    There very first line doesn't make sense. It should be something like:
    if (typeof global.bShowWarning1 == "undefined")
